MLP codec is not standard for BD disks
Failure26
Post by Failure26 » Thu Mar 17, 2022 1:06 pm
I have a problem with ripping TRUE_HD Dolby Atmos tracks. When remuxing the MKV to a Blu Ray Folder I get the warning "MLP codec is not standard for BD disks, the m2ts will not play on a Blu-ray player". The BD then doesn't play the movie when on this audio track. After changing to a different audio track it plays perfectly. The MKV plays perfectly on Kodi. The via Handbrake shrinked MKV including the passthrough TRUE HD track put on a BD is not playing on my Sony Player and the XBOX until I change to a different audio track. Then the movie again plays perfectly. What is my problem here, can anyone help?
Re: MLP codec is not standard for BD disks
Post by Coopervid » Thu Mar 17, 2022 5:00 pm
You must convert the True Atmos audio file with useac3to before muxing.
Failure26
Post by Failure26 » Thu Mar 17, 2022 5:25 pm
To AC3 or E-AC3?
Post by Coopervid » Thu Mar 17, 2022 5:42 pm
Failure26 wrote: Thu Mar 17, 2022 5:25 pm To AC3 or E-AC3?
See this picture:
https://forum.redfox.bz/threads/useac3t ... xer.78310/
hansolo
Post by hansolo » Fri Mar 18, 2022 10:26 am
On BD format TrueHD audio must include legacy core ac3. It is mandatory! Typically backup softwares e.g. MakeMKV remove this core part when matroska is chosen output format as it is considered redundant.
Use
eac3to source.thd target.thd+ac3
A core part will be re-encoded and interleaved to existing TrueHD only track. After this audio track is Blu-ray compatible and can be used as an asset e.g. in tsMuxeR.
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
Failure26
Post by Failure26 » Fri Mar 18, 2022 4:05 pm
hansolo wrote: Fri Mar 18, 2022 10:26 am On BD format TrueHD audio must include legacy core ac3. It is mandatory! Typically backup softwares e.g. MakeMKV remove this core part when matroska is chosen output format as it is considered redundant.
Use
Now I got it. Thanks a lot!
Newbie5678
Post by Newbie5678 » Wed May 28, 2025 8:24 pm
As you can tell by my username, I'm new to all of this. Thanks to this thread, I understand my problem with trying to create a Blu-ray folder from an MKV file and the fix. In which file do I insert the code to include TrueHD+AC3?
