Saw 4K Blu-Ray Error
SeppelLetsPlay
Post by SeppelLetsPlay »
*translated with Google(I am From Germany)*
Hello, I have a problem and I've probably already copied over 100 (including 4K) Blu-Rays and it always worked without any problems. And now I've bought the 4K Saw Blu-Ray and I get the following message: (PS: This is the second one, I've already sent the first one back)
Debug log started at Wed Mar 16 16:58:25 2022 , written by MakeMKV v1.16.7 darwin(x64-release)
001005:0000 MakeMKV v1.16.7 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/tobiashartstein/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.79.1/(SecureTransport) LibreSSL/3.3.5/1.45.1 (x86_64-apple-darwin21.0) , proxy server not set.
002010:0000 Optical drive "BD-RE ASMedia ASM105x 3.10 KL8L3AI4931d" opened in OS access mode.
SDF  v088: ASMedia_ASM105x_3.10_211901041014_KL8L3AI4931
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
001003:0020 DEBUG: Code 100941314 at 6/ZSG47QXJME~':p:29403291
001003:0020 DEBUG: Code 100941314 at AOpn^t:=02-!{;L]:213130559
DEBUG: Code 2147483648 at "\_KTw9N7~>xh;%/:121264625
DISCID=A1CB602688A9A8AB367815D997E5A4E597A963A5
001003:0020 DEBUG: Code 0 at q(#9f!e1i.3J)_L]_tLQ:121268880
001003:0020 DEBUG: Code 0 at 7>2`dU6P[9TE)[jPd?a:213132859
001003:0020 DEBUG: Code 0 at (iP"cY!Jwryc<h3[2:29397035
001003:0020 DEBUG: Code 0 at Dd(18XTH'Xo8LY7,Z3:121262049
001003:0020 DEBUG: Code 0 at Dd(18XTH'Xo8LY7,Z3:121262256
005043:0000 Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at W~um;-X-yi^32.E<:213131387
001003:0020 DEBUG: Code 0 at "_4BXIZ62@tu@u*:29402256
001003:0020 DEBUG: Code 0 at -|5`i-;F,W5c;8<~:213117058
003016:0000 Title #00000.mpls was skipped
003307:0000 File 00003.mpls was added as title #0
005043:0000 Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
003016:0000 Title #00004.mpls was skipped
003016:0000 Title #00005.mpls was skipped
003307:0000 File 00006.mpls was added as title #1
005043:0000 Failed to decode audio/video data for title #2 - invalid mux or internal error, title skipped.
003016:0000 Title #00000.m2ts was skipped
003307:0000 File 00001.m2ts was added as title #2
003307:0000 File 00003.m2ts was added as title #3
003307:0000 File 00004.m2ts was added as title #4
003307:0000 File 00005.m2ts was added as title #5
003307:0000 File 00006.m2ts was added as title #6
003307:0000 File 00011.m2ts was added as title #7
002023:0000 Encountered 3 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06043E02 count=3 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Re: Saw 4K Blu-Ray Error
Blu-ray.com says the Saw (2004) UHD came out in May, 2021 (in the US at least). Unfortunately, 'Saw' is too short of a search term for this forum. However, looking back in the May 2021 time frame, I found the Saw thread on this forum. It is unhelpfully a single post. You and others were able to decrypt it and I didn't see any other threads about it in the UHD section.
I know you tried replacing the disc. Do you have a different optical drive you could try?
No one else has reported any errors which means either you're the first to run into a problem or other people have not been having any issues. Since the disc came out in May, 2021, I would think others would have reported this problem by now. It seems more likely that your drive might be having difficulty.
SeppelLetsPlay
Sorry I didn't have a chance to reply earlier.
Yes, I have a different version because, as I said, I come from Germany. Namely this one:
https://www.blu-ray.com/movies/Saw-4K-Blu-ray/300955/
I've already tried to make a backup of the Blu-Ray, which worked (although it took 5 hours).
The unencrypted m2ts file can also be played and is error-free, except that there are 2 video tracks and the audio tracks have no language information. When I import the backup into MakeMKV, the same error occurs!
I don't really know what to do, especially because this is the 2nd time and it has the exact same error.
Oddly enough, there are no problems in the Blu-Ray player either.
That's an interesting problem and I imagine frustrating for you. It seems that there's something weird about how that version of Saw is authored. I wonder if tsMuxeR would work on it? I don't have a lot of experience with it, but from what I understand, tsmuxer should be able to remux the .m2ts files from your decrypted backup into a .mkv file.
Perhaps MakeMKV's author, Mike, will happen across this thread.
SeppelLetsPlay
Unfortunately, I got Corona and I wasn't really feeling well, but now it's much better.
Anyway, I've downloaded tsMuxeR and read in the m2ts file, but the way it looks, that's probably not the solution.
awdspyder
Post by awdspyder »
I know it sounds pedantic, but try cleaning the disc with a few drops of dish detergent and warm water, cleaning with your fingers from the inside hub to the outer edge of the disc. Make a few passes around the disc, then wipe dry with a clean microfiber cloth, again from the center outward to the edge.
UHD drives/disks are extremely sensitive to anything on the surface of the disc and nearly always have a film from the manufacturing process on them. If that doesn't work, you likely have a disc with an authoring error and it cannot be properly read. In that case, you're hopefully still in your return window and can exchange it for a new disc.
I've seen a number of slow/long-running UHD rips fixed by a simple cleaning.
