Need Help Diagnosing Issues with WH14NS40 Drive
goferguy
Post by goferguy »
Hi there, new to the forum, but I am need of help diagnosing issues with my WH14NS40 Blu Ray Drive. I recently purchased this second hand and flashed it with the WH16NS60 firmware 1.02 and later WH16NS60 1.03 MK after this issue occurred.
Last night I tried to rip my first 4K UHD Blu Ray - Spaceballs, and about 1/2 to 3/4 way through the rip, the process would stop and I would get this error:
HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET
From what it sounded like this may come up as a result of overspeed and under voltage, however, when the drive stopped it was ripping at about 8X and the drive is in a PC not a USB enclosure.
It seems to rip Blu Rays fine, occasionally running into hash errors, but these are on Library rentals, so likely they have surface defects.
Attached below you will find the debug information from the last time I tried to rip the blu ray. I am just trying to figure out if it is a software issue on Make MKV's end, a firmware bug, or a faulty drive.
Thanks for the help!
Debug Info:
Debug log started at Tue Mar 15 05:21:50 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\riesx/MakeMKV_log.txt
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF  v088: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLOL2ID1346
001011:0000 Using LibreDrive mode (v06.3 id=4083C4CCDB14)
DEBUG: Code 2147483648 at vY-GuZ@?5^tcx_N8:121264625
DISCID=F7C72673EA7D1E0DF63642E74284B8017FF6B556
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00000.m2ts was added as title #1
003025:0000 Title #00001.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file://I:/Make MKV/spaceballs
005001:0308 File I:/Make MKV/spaceballs/Spaceballs_t00.mkv already exist. Do you want to overwrite it?
001003:0020 DEBUG: Code 3221225628 at wPw@X*c]4mg& [n>)i&~--ZG:121262371
001003:0020 DEBUG: Code 3221225628 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 100864261 at jy`8q}68o"jrtS*\:29403291
001003:0020 DEBUG: Code 100864261 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 3221225491 at wPw@X*c]4mg& [n>)i&~--ZG:121262371
001003:0020 DEBUG: Code 3221225491 at %L!0Ld/*I;&9zs;':213130559
002003:0000 Error 'Internal error - Operation was cancelled (135)' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '32214220800'
001003:0020 DEBUG: Code 0 at 0bwgt@77.GHGQIR{;>4=:29395471
001003:0020 DEBUG: Code 0 at R4u~o@nt  rPOb)U[7/2:29394068
001003:0020 DEBUG: Code 0 at 0bwgt@77.GHGQIR{;>4=:213131157
001003:0020 DEBUG: Code 0 at 0bwgt@77.GHGQIR{;>4=:121262647
001003:0020 DEBUG: Code 15729600 at 0bwgt@77.GHGQIR{;>4=:121261773
001003:0020 DEBUG: Code 0 at 4>JbJ\HBc5C{L=GS3mux:29394022
001003:0020 DEBUG: Code 0 at boH@.@V!]`~XV|dwLcSw{:213137068
001003:0020 DEBUG: Code 0 at 4>JbJ\HBc5C{L=GS3mux:29404878
001003:0020 DEBUG: Code 0 at 4>JbJ\HBc5C{L=GS3mux:29405384
001003:0020 DEBUG: Code 0 at 4>JbJ\HBc5C{L=GS3mux:29403383
001003:0020 DEBUG: Code 0 at xh'a}$I$O=svtt{\uL-[:121272790
001003:0020 DEBUG: Code 0 at %:_F@e_g4U7~p`bv:213132537
001003:0020 DEBUG: Code 0 at M@|Jr'aK})xg'|kGM:121264464
001003:0020 DEBUG: Code 0 at M@|Jr'aK})xg'|kGM:121263912
001003:0020 DEBUG: Code 0 at M@|Jr'aK})xg'|kGM:213130145
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
---- Failed I:/Make MKV/spaceballs/Spaceballs_t00.mkv
ch_0        3150267120000 0
ch_1        3151348200000 0
ch_2        3152429280000 0
ch_3        3153510360000 0
ch_4        3154591440000 0
ch_5        3155672520000 0
ch_6        3156753600000 0
ch_7        3157834680000 0
mt=000002A9AD5CC760 n=8
s=0 n=1 o=32214220800
    0 649621 000001  3157834680000       45045000 99C7128A 00000036500184310095C026F441ABBFC98F5C1AF48B528460382B892AE1BAA62DC277E04F68BEEA697C7302F1298BCF73E92922BBB2BB157B80000000034601100000001840010C01FFFF2220000003009000000300000300999594090000003C420101222000000300900000030000030099A001E020021C4D96565924CAF0
s=1 n=1 o=32204273664
    1   4884 000001  3157839360000       11520000 E0CAE333 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40380000000000000400000002000000040002000590DA6BD20C258A1112E6525393DCC5BDEE739CD5AD4A49CE528842141CD528C7298C5294A4294A620C63104410C1CD5A92729CE7314A318CA421462108410C9AB5
s=2 n=1 o=32204273664
    2   2012 000001  3157839360000       11520000 A7590493 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40380000000000000400000002000000040002000590DA6BD20C258A1112E6525393DCC5BDEE739CD5AD4A49CE528842141CD528C7298C5294A4294A620C63104410C1CD5A92729CE7314A318CA421462108410C9AB5
s=3 n=1 o=32204273664
    3   2608 000001  3157839360000       11520000 E142BCEE 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA00800000000000002D3318C62F4A4EB4A56B59CA318C20F7BDCE735AB30F18C62F4A4EB4A56B59CA518C20F7B9CE6B5AC48C000000000000000000000000000000022C08B25EB662B1D346CE5D3762A1320427CE9D3C78E9D3A74D970A062408B25EB66AB1D34
s=4 n=1 o=32204273664
    4   2012 000001  3157839360000       11520000 A5BDF74C 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA00800000000000002D3318C62F4A4EB4A56B59CA318C20F7BDCE735AB30F18C62F4A4EB4A56B59CA518C20F7B9CE6B5AC48C000000000000000000000000000000022C08B25EB662B1D346CE5D3762A1320427CE9D3C78E9D3A74D970A062408B25EB66AB1D34
s=5 n=1 o=32205490176
    5    768 000001  3157850880000       34560000 22B2A182 0B77B24014304B704392490000709F362DD06060606A0C0C0C0DF9A133B22FA12ACBAE207AEB1252A6F9536A90F92DBA62F63E4CF6EB9A4FAB5BAEAA0D689088A67CF6942D746DC37CF6BBEEE1A7F9D52C29D5A99177392BA8549F53F2BE9840812000B4D9976FA5873A80F8FE032D8670FF3E7CAF40BB1D327FEF5FE379C060
s=6 n=1 o=32214220800
    6     30 000011  3158915760000       22522500 909EFB39 16000B078004381005110000000017000A01000365038F00B1002E800000
s=7 n=0 o=32214220800
mt=000002A9AD5DA210 n=8
s=0 n=3 o=32214220800
    0 469030 000000  3158014860000       45045000 A2A261C3 000000365001843100114D48101ADCFD6A9FAE8C98EC826685096F1B10BD9BBE056C6C8AD4414443C99CE61D4B40B25DEDFF53F4BE17AECC238000000003460130000000074E010102000B80000521B20201D02149E10C622088718194F2D4B750253C949951B1476516142ED0734094E7742CD1153FC51F3473D19F462515F4
    0 365557 000008  3157924770000       45045000 1360C244 00000036500184310049EA50E94A977A13829F335925123F888A14AEA69335EAB9273FFE47144C4680C7927A5FB64A6AF9CB8CDF7451EE28C18000000003460150000000074E0101020085800003AB530201E04495786280886A58FCE3E18EF0769BB9FD9DF0EF7C7A9BC88E9B74079FFD28E86F6AFA6FD21E43711794FCE9E6
    0 280135 000008  3157879725000       45045000 1FDE0F0B 00000036500184310021C3FDE7602FAE6BE3D420992AA05901E6D9055383D94BEEC80F0605EFEFC20409A557894ACBE61B090B4D99744F2FCA8000000003460150000000074E0101020101800002A47C0001E024FD7E8B1904434CB9625B08D672A31598A97D406B0D4BCA2F50769074C7A10CE669B74D99F94C9E6693AAA065
s=1 n=30 o=32204273664
    1   4872 002001  3157850880000       11520000 018D2D46 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400008000000000000000000000000000600000001D1827095CE5393DCD639CE739AC5AD29498E320C420C1CD5A90731CC7298A5314A530883188210C5CD5A8E6298C7298A5210A519063108220C9CB5A5294A5294A0
    1   4872 002001  3157862400000       11520000 57387EB9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4040080000000000040000000400000006000200051AF458D15A50D4E31B0D4E53939CD635EE739CD629494A4E518C41141CD624E6318E8318A5298C5314A3108210C5CD5A4E6298C7310A528CA631483108410C5CB5
    1   4868 002001  3157873920000       11520000 9CF4E916 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4180000000000000040000000600000004000000009B09870810D5920DB4E128BDED635CD6B5AC629494A4E619462149CD6290631CA5214C6294A531462108410C1CD624E7298E6318A5214A521043108220C9AC5AD4
    1   4856 002001  3157885440000       11520000 22FCE342 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4120000004000000040000000400000006000000009DF3F953F1A136F092294A11939AD5B1AD735AC629494A4C518C62145CD62D2941CE529885294A52146310821141CD624E5194E6298A41908518C83108210C5CE6
    1   4888 002001  3157896960000       11520000 56201410 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410000000080000000800000000000000600000001969C6723829D8ECE3193DCD631AE735AC6A9494A0E720C42145CD5A907214C5298A62986529062108410C5CD5A4E531CC5314832946528C62188410C9CC62D2A4A
    1   4836 002001  3157908480000       11520000 DEF6C56D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4540000000000000008000000400000002000000073CFC0422088111186CA31939CD5B1AE739AD629494A4C628C42145CE62907318C7318A42948529463108420C9AD5A506294C7314A6310A428C63108410C5AC5A92
    1   4836 002001  3157920000000       11520000 AD615F40 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414020000000000000000000040000000400000007504326B591A0CCCA11939CD631AE6B98D6294949CE510C820C1CD628E7318C631485294A628C63188420C9CD624E5314C529884294A528C63108410C5CB5AD294A
    1   4840 002001  3157931520000       11520000 C28B69F3 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45400000000000000400000004000000020000000417F4F42EF0A0D362D461193DAD5B5AE7398D5A92749CE618C42149CD5A906318A6394A52908631462188410C5CD624E7294A631885298A528C63104420C5CC5ACE
    1   4844 002001  3157943040000       11520000 196B6E3F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400040000000000000000000040000000600020005B45AB9096FEC11C61393DCD5B5AE7358D6252841CE521042145CC628E7318C6318842948629483108410C5CD628E6318A6294A5290A429063188410C5AB5A9294A
    1   4828 002001  3157954560000       11520000 D9806791 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4524880000000000000000000200000002000000046C6F4D4EA20DF1F50631594C61193DAD5B1AE7398D5A9274A0C528C42145CD5A527318A6298C5194A429463104420C5CD628E7294C72986521484294A3108210C9
    1   4820 002001  3157966080000       11520000 5C141EA4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410008000400000000000000060000000400000006E1989FE45B26F1DA84A1193DAD5B1CE7396C525294A10520C42141CC628E631CC6318C5294A53148318C220C5CC624E6298C6318A6214852948410C410C5AC5AD2
    1   4824 002001  3157977600000       11520000 CEFBE9B4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41000000008000000100000000000000060002000089F2D88C8255872E649F1939AC5B5AE6B58B5A5294A4E519062145CC5A907298C531CA5294A531063188420C5AC628E6318C6318A5314A529443188410C9AC5AD2
    1   4828 002001  3157989120000       11520000 1006F019 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414040000000000000000000040000000200000006ECCC61020C0184C5F18B9AD635AE7356B5A92849D2628C620C5EC62926318C731CC329084310A318841145AD5A8E6318C631CA429486214A3184410C5AC5A94952
    1   4816 002001  3158000640000       11520000 1C234B32 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410040000000000001000000040000000400000006D55AFB6311603145F18BDCD631AE7316B5A9494A10628C42145CC624E7298A6318A4298862906418C420C5CC5A4E631CC7398C5294A5290A4108410C5AC5A92A4A
    1   4808 002001  3158012160000       11520000 8DE7CB0B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41004000000000000000000000000000040002000682DF6F09B0E461183DCC6358E7316B529494A4C529062145CC6292729CE631886298C5294A3108410C1CD5A506310E7294A5294A629483108610C9AB5A9294A529
    1   4788 002001  3158023680000       11520000 B6906512 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000400000005B5CA11839CC635AE6B16B5292949CC529042141CD62906298C7298C62986529483188410C1CD624C7314E7314A5294A5294A4188210C5CC5AD294A5294A5294A12
    1   4792 002001  3158035200000       11520000 099B0B11 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000600020005A46AE1F34A30839CE6B5AE6316B4A529424E528C62145CC62927318C7310A5298A530C44188420C5CC5A8E6318A7314C4294A5294A3108410C9CC5A9494A52949D
    1   4812 002001  3158046720000       11520000 BC4FDA95 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46000000000000000000000002000000040002000192D935C783D9E4CA118BDEE6B5AD6AD6A529294A0E521042145AC5A8E6298C631886294A62946310C210C1CC5A928318C7314A5294A629063188220C9AC5AD294A
    1   4848 002001  3158058240000       11520000 3F659E2D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000000002000400020001865A5446F19AEFCA528C62E739CD6B18B529294A4C520C42145CC5A507298C731465294A320C63188420C5AC5A4E7314C6310A328CA52908310C420C9CC5A9294A
    1   4840 002001  3158069760000       11520000 7B4D8240 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000000000006000000070A5B20C3A6DCE328C60E6B5AD6AD6B52949424C520C62141CD5A50831CE6314A6290C6294A2104220C1CC5A528314C5314A3298C521462108420C9CD5A9294A529
    1   4852 002001  3158081280000       11520000 506F033F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000040000000600000007EAF17136A694E528C60E6B5AD62D8B525494A4A528862145CC5A926318C6318A6210A63148218C410C1CC5A529398C6314A5294A429064108410C9CB529294A529
    1   4832 002001  3158092800000       11520000 FCCF8E47 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF448000000400000004000000040000000400000001878C1919355C28DB04A328C9EE6B5AD6B18B52549424E528C42141CC5A946318C531485314C629484108420C1AC5A927314C6318A33148429064108410C5CC5AD2
    1   4828 002001  3158104320000       11520000 D118E11A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000040002000400020000C4DAC44870969DCE528C5EE739AD62D6B5294941CC528C61145CC5A507318C6318A6290A529462108420C5CD5A926318A5314A5294A521483108420C5CB529294A
    1   4836 002001  3158115840000       11520000 A2576FAA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000600000000000000000000000400020007E518A104C0CD2328C5EE6B5AD6316B52929420C528C620C1AC5A926314C6214A5298A631463108410C5CC5AD27298C7318A5298A531063188210C9AB528E94A529
    1   4812 002001  3158127360000       11520000 19CB3C7B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000000000000000200040000000274443426CA328C60E739AC6318B5A9484A4E518C42145CC5AD25318C6290A4294A52108418C410C1CC5A92730CA5294A3214A529484108210C9CC5A9294A5294A5
    1   4828 002001  3158138880000       11520000 E4912334 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF404000000000000004000000000000000000020002A08CCE97CE328C1CE6B5AC5B16B529494A4E520C63145CD5A926318C631865294A63106310C410C1AC5A92631CC63108528CA421463104410C5CC5A9494A5094A5
    1   4832 002001  3158150400000       11520000 6B533190 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000004000000041000000109700A924A52845EE739AC6316B52949424E418C42145AC5A928318C5314A5294A631483188410C5CC5AD27318A629464214A531083108410C5AB5A9294A52949D
    1   4828 002001  3158161920000       11520000 C4A983CC 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41000000020000000000000004000000020002000027DCBDAA9806CFCE51841CD6B5AC62D6B52949420C518C42145AC5A925314A619483214A52944310841149CD62D4949CC6198A528CA528C83108210C5CB529294A
    1   4840 002001  3158173440000       11520000 D1D3FFFF 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000600000000000000022A8D98DFA65CA31841EE6B58C6316B5A929424E520C43145AC5A92731CC5394A5214A329483108420C1CC5A927318A6314A52108531484188210C5AC5A9294A529
    1   4820 002001  3158184960000       11520000 6DD7F2F3 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000060000000400000004A90DE7205B04A32841EE6B5AC5B16B529294A4E528C620C1CC5A8E6314A5294A6294A431083188220C5CD5AD27318A629486294A519063108410C5AC5AD294A509
s=2 n=30 o=32204273664
    2   2012 002001  3157850880000       11520000 BB7BBF7B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400008000000000000000000000000000600000001D1827095CE5393DCD639CE739AC5AD29498E320C420C1CD5A90731CC7298A5314A530883188210C5CD5A8E6298C7298A5210A519063108220C9CB5A5294A5294A0
    2   2012 002001  3157862400000       11520000 5DB9522D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4040080000000000040000000400000006000200051AF458D15A50D4E31B0D4E53939CD635EE739CD629494A4E518C41141CD624E6318E8318A5298C5314A3108210C5CD5A4E6298C7310A528CA631483108410C5CB5
    2   2012 002001  3157873920000       11520000 14FCDAFF 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4180000000000000040000000600000004000000009B09870810D5920DB4E128BDED635CD6B5AC629494A4E619462149CD6290631CA5214C6294A531462108410C1CD624E7298E6318A5214A521043108220C9AC5AD4
    2   2012 002001  3157885440000       11520000 26AA8BD0 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4120000004000000040000000400000006000000009DF3F953F1A136F092294A11939AD5B1AD735AC629494A4C518C62145CD62D2941CE529885294A52146310821141CD624E5194E6298A41908518C83108210C5CE6
    2   2012 002001  3157896960000       11520000 08D1652D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410000000080000000800000000000000600000001969C6723829D8ECE3193DCD631AE735AC6A9494A0E720C42145CD5A907214C5298A62986529062108410C5CD5A4E531CC5314832946528C62188410C9CC62D2A4A
    2   2012 002001  3157908480000       11520000 87E4997C 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4540000000000000008000000400000002000000073CFC0422088111186CA31939CD5B1AE739AD629494A4C628C42145CE62907318C7318A42948529463108420C9AD5A506294C7314A6310A428C63108410C5AC5A92
    2   2012 002001  3157920000000       11520000 362C7106 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414020000000000000000000040000000400000007504326B591A0CCCA11939CD631AE6B98D6294949CE510C820C1CD628E7318C631485294A628C63188420C9CD624E5314C529884294A528C63108410C5CB5AD294A
    2   2012 002001  3157931520000       11520000 4D423539 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45400000000000000400000004000000020000000417F4F42EF0A0D362D461193DAD5B5AE7398D5A92749CE618C42149CD5A906318A6394A52908631462188410C5CD624E7294A631885298A528C63104420C5CC5ACE
    2   2012 002001  3157943040000       11520000 09822030 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400040000000000000000000040000000600020005B45AB9096FEC11C61393DCD5B5AE7358D6252841CE521042145CC628E7318C6318842948629483108410C5CD628E6318A6294A5290A429063188410C5AB5A9294A
    2   2012 002001  3157954560000       11520000 CB3D1AFA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4524880000000000000000000200000002000000046C6F4D4EA20DF1F50631594C61193DAD5B1AE7398D5A9274A0C528C42145CD5A527318A6298C5194A429463104420C5CD628E7294C72986521484294A3108210C9
    2   2012 002001  3157966080000       11520000 FAB2AFFD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410008000400000000000000060000000400000006E1989FE45B26F1DA84A1193DAD5B1CE7396C525294A10520C42141CC628E631CC6318C5294A53148318C220C5CC624E6298C6318A6214852948410C410C5AC5AD2
    2   2012 002001  3157977600000       11520000 2A03E73E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41000000008000000100000000000000060002000089F2D88C8255872E649F1939AC5B5AE6B58B5A5294A4E519062145CC5A907298C531CA5294A531063188420C5AC628E6318C6318A5314A529443188410C9AC5AD2
    2   2012 002001  3157989120000       11520000 96516091 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414040000000000000000000040000000200000006ECCC61020C0184C5F18B9AD635AE7356B5A92849D2628C620C5EC62926318C731CC329084310A318841145AD5A8E6318C631CA429486214A3184410C5AC5A94952
    2   2012 002001  3158000640000       11520000 29CF649A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410040000000000001000000040000000400000006D55AFB6311603145F18BDCD631AE7316B5A9494A10628C42145CC624E7298A6318A4298862906418C420C5CC5A4E631CC7398C5294A5290A4108410C5AC5A92A4A
    2   2012 002001  3158012160000       11520000 5463F028 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41004000000000000000000000000000040002000682DF6F09B0E461183DCC6358E7316B529494A4C529062145CC6292729CE631886298C5294A3108410C1CD5A506310E7294A5294A629483108610C9AB5A9294A529
    2   2012 002001  3158023680000       11520000 50425550 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000400000005B5CA11839CC635AE6B16B5292949CC529042141CD62906298C7298C62986529483188410C1CD624C7314E7314A5294A5294A4188210C5CC5AD294A5294A5294A12
    2   2012 002001  3158035200000       11520000 DBD25B58 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000600020005A46AE1F34A30839CE6B5AE6316B4A529424E528C62145CC62927318C7310A5298A530C44188420C5CC5A8E6318A7314C4294A5294A3108410C9CC5A9494A52949D
    2   2012 002001  3158046720000       11520000 C932188E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46000000000000000000000002000000040002000192D935C783D9E4CA118BDEE6B5AD6AD6A529294A0E521042145AC5A8E6298C631886294A62946310C210C1CC5A928318C7314A5294A629063188220C9AC5AD294A
    2   2012 002001  3158058240000       11520000 8A29EB82 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000000002000400020001865A5446F19AEFCA528C62E739CD6B18B529294A4C520C42145CC5A507298C731465294A320C63188420C5AC5A4E7314C6310A328CA52908310C420C9CC5A9294A
    2   2012 002001  3158069760000       11520000 08D80D92 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000000000006000000070A5B20C3A6DCE328C60E6B5AD6AD6B52949424C520C62141CD5A50831CE6314A6290C6294A2104220C1CC5A528314C5314A3298C521462108420C9CD5A9294A529
    2   2012 002001  3158081280000       11520000 D8A16963 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000040000000600000007EAF17136A694E528C60E6B5AD62D8B525494A4A528862145CC5A926318C6318A6210A63148218C410C1CC5A529398C6314A5294A429064108410C9CB529294A529
    2   2012 002001  3158092800000       11520000 9BEAFD82 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF448000000400000004000000040000000400000001878C1919355C28DB04A328C9EE6B5AD6B18B52549424E528C42141CC5A946318C531485314C629484108420C1AC5A927314C6318A33148429064108410C5CC5AD2
    2   2012 002001  3158104320000       11520000 8ADBB2D1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000040002000400020000C4DAC44870969DCE528C5EE739AD62D6B5294941CC528C61145CC5A507318C6318A6290A529462108420C5CD5A926318A5314A5294A521483108420C5CB529294A
    2   2012 002001  3158115840000       11520000 C4FB01E4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000600000000000000000000000400020007E518A104C0CD2328C5EE6B5AD6316B52929420C528C620C1AC5A926314C6214A5298A631463108410C5CC5AD27298C7318A5298A531063188210C9AB528E94A529
    2   2012 002001  3158127360000       11520000 F2680029 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000000000000000200040000000274443426CA328C60E739AC6318B5A9484A4E518C42145CC5AD25318C6290A4294A52108418C410C1CC5A92730CA5294A3214A529484108210C9CC5A9294A5294A5
    2   2012 002001  3158138880000       11520000 445F4D57 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF404000000000000004000000000000000000020002A08CCE97CE328C1CE6B5AC5B16B529494A4E520C63145CD5A926318C631865294A63106310C410C1AC5A92631CC63108528CA421463104410C5CC5A9494A5094A5
    2   2012 002001  3158150400000       11520000 F3D603D1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000004000000041000000109700A924A52845EE739AC6316B52949424E418C42145AC5A928318C5314A5294A631483188410C5CC5AD27318A629464214A531083108410C5AB5A9294A52949D
    2   2012 002001  3158161920000       11520000 CE1C8D56 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41000000020000000000000004000000020002000027DCBDAA9806CFCE51841CD6B5AC62D6B52949420C518C42145AC5A925314A619483214A52944310841149CD62D4949CC6198A528CA528C83108210C5CB529294A
    2   2012 002001  3158173440000       11520000 55429CCD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000600000000000000022A8D98DFA65CA31841EE6B58C6316B5A929424E520C43145AC5A92731CC5394A5214A329483108420C1CC5A927318A6314A52108531484188210C5AC5A9294A529
    2   2012 002001  3158184960000       11520000 2F4F0B42 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000000000000060000000400000004A90DE7205B04A32841EE6B5AC5B16B529294A4E528C620C1CC5A8E6314A5294A6294A431083188220C5CD5AD27318A629486294A519063108410C5AC5AD294A509
s=3 n=30 o=32204273664
    3   2612 002001  3157850880000       11520000 F3AD52F1 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA02004000028040001ECFA170DED44E9718C62B5A4E96AD6B4A4A318C20F7B9CE6B58C38F18C62B59CE96AD6B4A4A11842107BDCE735AB4080000000000000000000000000000000234191159B868B193C70E1C3664A5124407CF9C3870F1D3870B980A0234191
    3   2608 002001  3157862400000       11520000 B46078A3 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62D6A4A95A5694A4E31842107BDCE735AB38B18C62D6A4A95A5694A4E318420F7B9CE739CC4880000000000000000000000000000000233A8D21B3D66A593866E1A3060B91223A74D9F3A70D9C3E6CC950A023BA8D21ABD66A593866E
    3   2608 002001  3157873920000       11520000 8CEED7B2 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62B4A4A75AD694A52318C6107BDEE735AB40B18C62B4A4E75AD694A5231846107B9CE739AC4080000000000000000000000000000000233A8B159B462A57B86CDDA335EBD0223E7CF9E3C78F9D3E70E130C022BB8B1183460A97B76AD
    3   2608 002001  3157885440000       11520000 66E3D495 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0400400000004000174717717B18C62D6A4E74A56949CE318420F83DCE739AC40B18C62D6A4E74A56949CE318C20F7B9CE739AC488000000000000000000000000000000022BE84F5B3A60B573466D19315EB11A33C74E1B3E74E1A3874D960C0223D8705B3A6
    3   2612 002001  3157896960000       11520000 2E824C4F 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0000000A000000397F00FE55FFB17C62B5A4A74AD6B4A4E31846107BDCE735AC48B17C62B5A4E94AD6B4A4E318460F7BDCE6B98B488000000000000000000000000000000021B785159B760A57B370D5AB260B90A23E88F9E3E70C9D3C74F1914022377F159
    3   2608 002001  3157908480000       11520000 F881BB4D 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA028000000A00000001AC139CF01D317C62D59CA94AD6B4A4E31842107BDEE735AB38F17C62B5A4E94AD6B4A4E318420F7B9CE6B9AC48C000000000000000000000000000000021378715AB95CA58336EDDBB164B5123387101E3670E9D3C70D930A020B77D15A
    3   2596 002001  3157920000000       11520000 6CD831BD 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0000000A8000003AF780770DFA2D8317C62B5A4E74AD6B3A4E31846107BDEE739AC48B17C62B59CE74AD6B3A4E118420F7B9CE739AC488000000000000000000000000000000021358115A3666AD7B370DDCAF62ACFA13C7D01E3874F1E3874E1710021B57F
    3   2628 002001  3157931520000       11520000 24A4BD88 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000A000000047483AD1B7A02A717C62B5A4A94AD693A4E31842107BDEE735AC38B17C62D4A4A94AD6B3A4E31841F07BDCE739AC508000000000000000000000000000000022348111A34629D8336CD98AB64ACF9F3870F9F3874F1C3A70E170A01F3481
    3   2608 002001  3157943040000       11520000 BE724D55 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA080040000A2050003A6B12F77C13915B758F3F17C62D5A4E95ADAB3A4A11842107B9EE6B9AC41317C62B5A4A75ADAB3A4A30841EF7B9CE6B9AC490000000000000000000000000000000022357B19C3862A993570F1BAB60A0FA03A7CF9F346CF9B3674D16100
    3   2608 002001  3157954560000       11520000 9D809117 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0B0040000A000000370C2CEB06C7FA56D1F17C62B4A4A95AD6B39CA31842107BDEE7398C38F17C62B4A4A94AD6B39CE31846107BDEE739AC48C00000000000000000000000000000001C367D158B160A57B470D9BAB56950213878DA03C70E9C3E78C17040203
    3   2612 002001  3157966080000       11520000 957D8C6F 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000A020000373A65AA4B767862A4B18C62B4A4A94B52929CA118C2107BDCF739AB48B17C62B4A4A94B56939CA128C6107BDEE739AC50800010000000000000000000000000001FB6770D8325EA133166E99B050AD21B427CD9D3C74F1B3E74F1B262803
    3   2596 002001  3157977600000       11520000 99F7F92A 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA08820000208200000CB6178A51F1E108A5317C62B59CE94B5A739CA31842107BDEE739AB48F17C62B49CE94B5A739CA31846107BDCE739AC48C0000000000000000000000000000000203279099335AB18B170E16A8529D021386CE1F3A78E1A3E70D111001DB
    3   2596 002001  3157989120000       11520000 0A3D64AD 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA020240000A024000383C878C0B9327088D71B717C62B59CE94B569394A318421083DCE739AB48F17C62B59CE74B569394A318C6107BDCE739CC48810000000000000000000000000000002033750E1306AB14AF64E5B2E52A12A14670E9C3A78E9B3A74F1C261
    3   2604 002001  3158000640000       11520000 D05EC7FF 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000802000036A5FEAD3F4F6DA317C62B59CE94B56929CA318420F83DEE739AC48B17C62B49CE94B56939CA318C2307BDCF739AC48800000000000000000000000000000001FB472F56B35AB572F74D97275091021386CF193C74E1C3C70D94120203274
    3   2592 002001  3158012160000       11520000 F341CAE5 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA080000000900000017C5712A4F17C62D59CE94AD69394A318C2307BDEE739AC48717C62B5A4E94B56929C6318C2107BDEE739CC4880000000000000000000000000000000203472F19B85AAD93170CD7284E890A03A70F9E366CD9C3874E171001EB474F59B45
    3   2588 002001  3158023680000       11520000 887CCE44 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA000000000800000018F318C62B6AD294AD27394A32846307BDCF739CC48718BDEB6AD294ACE73946328461083DCE739CC48400000000000000000000000000000001F3572E99396AB98B168C55A84C890A23870F1D3668D1F3A78E1410020B66AE58B96AB98B1
    3   2600 002001  3158035200000       11520000 1CFBA3CA 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA1000000030000000318D3C13EB18C62F6AD695A4E73946518C2107BDEF739AB48717C62F6AD295A527294631842107BDEE6B9AC4840000000000000000000000000000000233678F5DBA6ACD83462B54A84A8519F3C74E203A70E1E3A74D940C020B578F5DBA6
    3   2600 002001  3158046720000       11520000 6C7AC5F9 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62F8AD6B5A5273946318420F7BDCD739AB40718C62F8AD6B5A5273946318420F7BDCE739AC4840000000000000000000000000000000223E7F09FC570DDCB864CD52E4C9121F3A7901C3870E193674D930C021BF8109FC570DDCB864C
    3   2600 002001  3158058240000       11520000 0BB5BDD6 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0008000000000000296B18C6317AD294A527394632842107BDEF735AC38718C6317AD294AD25394632842107B9CE739AC4840000000000000000000000000000000213A86FE14172C98B464CD52D4A890A43A74F9D3A74E9F3A70D16040223A86FE14072C9934
    3   2612 002001  3158069760000       11520000 68F35B91 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0400000024000000073D220A8F18C6317AD2B4A527394631846107B9EE7358C30718C6317AD2B4A527394631842107BDCE739AC4840000000000000000000000000000000223E8AFA14270BDAB368C552B508D0A33C7CE9E3A6CF9C3A68C160401FBE8AF61427
    3   2596 002001  3158081280000       11520000 9EFCDCB0 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6317AD294A4E7394A318C20F7BDEE735AC48718C6317AD6B4A4E5394A328C20F7B9EE739AC4040000000000000000000000000000000233E85062C06CD1A3066B552A5094FA23C74E1C3670F1C3C6CC9912022BE85062C06ED1A3168B
    3   2612 002001  3158092800000       11520000 54F32293 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA16000000040000000CA083427C68318C6316AD6B4A527394631842107BDCE739AB48718C6316AD6B4A5272946328420F7BDCE735AB4840000000000000000000000000000000223C84F60BF6ED9AB266BD5294E891A23670F9D3C6CE1A3E78E15100224082FA2
    3   2596 002001  3158104320000       11520000 F11F2AD4 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316B56B3A4E7294A318C21083DEF739AB48718C6316AD6B3A4E7294A318C20F7BDEE739AB4040000000000000000000000000000000223E81020BE72D1AAE5EB55A84C951A14274F9E3C6CF1E3C74C130C0223E81020BE70D1AAE5EB
    3   2596 002001  3158115840000       11520000 D3736A9F 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6317AD6B4A4E7394A318C60F7BDCE739AB28718C6317AD6B4A4E7394A31842107BDCE739AC484000000000000000000000000000000021BD86FA1C06ED5C3262B55AA4C951213E7CE9B3C6CE1D3A78D9302021BC86FA1C06ED5BB262B
    3   2588 002001  3158127360000       11520000 14375E9E 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD6949CE739CA31846107BDEF739AC38718C6316AD6949CE739C632842107BDCE739CB4840000000000000000000000000000000213D7CF61BD70D19AF58B152A508D120367CF9E3A70E9D3C70D1604020BD7EF623E70D19AF5AB
    3   2600 002001  3158138880000       11520000 C966F315 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0200000000000000158F18C62F6AD6B49CE7394A31842107BDEF735AC40718C6316AD6B4A4E7394A318C20F7B9EF739CC4040000000000000000000000000000000213D82F9F3B6AD1B305CB152B4A8D0A23A78F9D3A68E9F3A6CD160C0213D82F613B68D1B2F
    3   2600 002001  3158150400000       11520000 64AF4D57 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0800000008000000013C10F18C6316AD2B49CE7394A518421083DCF739AC48718C6316A52B49CE7294A328420F83DCE6B9AC4840000004000000000000000000000000213A7EF60BE6ACDAB158A959F52993244674D1E3E78E9C3C74E1B2C2004176FDEC17CD1
    3   2588 002001  3158161920000       11520000 BF1081FC 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD694A4E7294A318C6307BDEF739AC40718C6316AD694A4E7294A31846107BDCE739AC3840000000000000000000000000000000213B82F1FBD6AD17AF5EB55284C911213E78F9E386CE9E3A74D950A021BB80F5FBC6AD18AF5EA
    3   2600 002001  3158173440000       11520000 33828378 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA08000000080000003F8A5A318C5F16AD2B4A4E5394A31846107BDEF739AC48718C5F16AD2B49CE5394A318C60F7BDEE739AC484000000000000000000000000000000020B776EE03E6EC9B325CA93A94CA11A03C78F1C3670E213C74D180C0203978F203E6ECD
    3   2592 002001  3158184960000       11520000 30703799 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000317C6316AD294A4A7294A318C6307C1EE739AC40718C5F16AD695A4E5294A318C2107BDCE739CC504000000000000000000000000000000021347CF1FBC6ECD8B35EA15264C8CFA03A8101D3880E9C3A74E140A020B77CEDFBD6CCD8B35EA
s=4 n=30 o=32204273664
    4   2012 002001  3157850880000       11520000 4A7E4A01 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA02004000028040001ECFA170DED44E9718C62B5A4E96AD6B4A4A318C20F7B9CE6B58C38F18C62B59CE96AD6B4A4A11842107BDCE735AB4080000000000000000000000000000000234191159B868B193C70E1C3664A5124407CF9C3870F1D3870B980A0234191
    4   2012 002001  3157862400000       11520000 31F2D5FF 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62D6A4A95A5694A4E31842107BDCE735AB38B18C62D6A4A95A5694A4E318420F7B9CE739CC4880000000000000000000000000000000233A8D21B3D66A593866E1A3060B91223A74D9F3A70D9C3E6CC950A023BA8D21ABD66A593866E
    4   2012 002001  3157873920000       11520000 9B102CE2 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62B4A4A75AD694A52318C6107BDEE735AB40B18C62B4A4E75AD694A5231846107B9CE739AC4080000000000000000000000000000000233A8B159B462A57B86CDDA335EBD0223E7CF9E3C78F9D3E70E130C022BB8B1183460A97B76AD
    4   2012 002001  3157885440000       11520000 80A27515 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0400400000004000174717717B18C62D6A4E74A56949CE318420F83DCE739AC40B18C62D6A4E74A56949CE318C20F7B9CE739AC488000000000000000000000000000000022BE84F5B3A60B573466D19315EB11A33C74E1B3E74E1A3874D960C0223D8705B3A6
    4   2012 002001  3157896960000       11520000 41281940 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0000000A000000397F00FE55FFB17C62B5A4A74AD6B4A4E31846107BDCE735AC48B17C62B5A4E94AD6B4A4E318460F7BDCE6B98B488000000000000000000000000000000021B785159B760A57B370D5AB260B90A23E88F9E3E70C9D3C74F1914022377F159
    4   2012 002001  3157908480000       11520000 4469B619 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA028000000A00000001AC139CF01D317C62D59CA94AD6B4A4E31842107BDEE735AB38F17C62B5A4E94AD6B4A4E318420F7B9CE6B9AC48C000000000000000000000000000000021378715AB95CA58336EDDBB164B5123387101E3670E9D3C70D930A020B77D15A
    4   2012 002001  3157920000000       11520000 767DE4A0 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0000000A8000003AF780770DFA2D8317C62B5A4E74AD6B3A4E31846107BDEE739AC48B17C62B59CE74AD6B3A4E118420F7B9CE739AC488000000000000000000000000000000021358115A3666AD7B370DDCAF62ACFA13C7D01E3874F1E3874E1710021B57F
    4   2012 002001  3157931520000       11520000 874DF4CE 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000A000000047483AD1B7A02A717C62B5A4A94AD693A4E31842107BDEE735AC38B17C62D4A4A94AD6B3A4E31841F07BDCE739AC508000000000000000000000000000000022348111A34629D8336CD98AB64ACF9F3870F9F3874F1C3A70E170A01F3481
    4   2012 002001  3157943040000       11520000 565ACAFB 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA080040000A2050003A6B12F77C13915B758F3F17C62D5A4E95ADAB3A4A11842107B9EE6B9AC41317C62B5A4A75ADAB3A4A30841EF7B9CE6B9AC490000000000000000000000000000000022357B19C3862A993570F1BAB60A0FA03A7CF9F346CF9B3674D16100
    4   2012 002001  3157954560000       11520000 EC13B2A1 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0B0040000A000000370C2CEB06C7FA56D1F17C62B4A4A95AD6B39CA31842107BDEE7398C38F17C62B4A4A94AD6B39CE31846107BDEE739AC48C00000000000000000000000000000001C367D158B160A57B470D9BAB56950213878DA03C70E9C3E78C17040203
    4   2012 002001  3157966080000       11520000 461B3029 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000A020000373A65AA4B767862A4B18C62B4A4A94B52929CA118C2107BDCF739AB48B17C62B4A4A94B56939CA128C6107BDEE739AC50800010000000000000000000000000001FB6770D8325EA133166E99B050AD21B427CD9D3C74F1B3E74F1B262803
    4   2012 002001  3157977600000       11520000 7ED95F43 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA08820000208200000CB6178A51F1E108A5317C62B59CE94B5A739CA31842107BDEE739AB48F17C62B49CE94B5A739CA31846107BDCE739AC48C0000000000000000000000000000000203279099335AB18B170E16A8529D021386CE1F3A78E1A3E70D111001DB
    4   2012 002001  3157989120000       11520000 6A4AB523 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA020240000A024000383C878C0B9327088D71B717C62B59CE94B569394A318421083DCE739AB48F17C62B59CE74B569394A318C6107BDCE739CC48810000000000000000000000000000002033750E1306AB14AF64E5B2E52A12A14670E9C3A78E9B3A74F1C261
    4   2012 002001  3158000640000       11520000 D10B9A23 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0A0200000802000036A5FEAD3F4F6DA317C62B59CE94B56929CA318420F83DEE739AC48B17C62B49CE94B56939CA318C2307BDCF739AC48800000000000000000000000000000001FB472F56B35AB572F74D97275091021386CF193C74E1C3C70D94120203274
    4   2012 002001  3158012160000       11520000 DD351880 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA080000000900000017C5712A4F17C62D59CE94AD69394A318C2307BDEE739AC48717C62B5A4E94B56929C6318C2107BDEE739CC4880000000000000000000000000000000203472F19B85AAD93170CD7284E890A03A70F9E366CD9C3874E171001EB474F59B45
    4   2012 002001  3158023680000       11520000 8DDD485A 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA000000000800000018F318C62B6AD294AD27394A32846307BDCF739CC48718BDEB6AD294ACE73946328461083DCE739CC48400000000000000000000000000000001F3572E99396AB98B168C55A84C890A23870F1D3668D1F3A78E1410020B66AE58B96AB98B1
    4   2012 002001  3158035200000       11520000 5A123BF1 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA1000000030000000318D3C13EB18C62F6AD695A4E73946518C2107BDEF739AB48717C62F6AD295A527294631842107BDEE6B9AC4840000000000000000000000000000000233678F5DBA6ACD83462B54A84A8519F3C74E203A70E1E3A74D940C020B578F5DBA6
    4   2012 002001  3158046720000       11520000 C0F649B1 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C62F8AD6B5A5273946318420F7BDCD739AB40718C62F8AD6B5A5273946318420F7BDCE739AC4840000000000000000000000000000000223E7F09FC570DDCB864CD52E4C9121F3A7901C3870E193674D930C021BF8109FC570DDCB864C
    4   2012 002001  3158058240000       11520000 1B3F16AF 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0008000000000000296B18C6317AD294A527394632842107BDEF735AC38718C6317AD294AD25394632842107B9CE739AC4840000000000000000000000000000000213A86FE14172C98B464CD52D4A890A43A74F9D3A74E9F3A70D16040223A86FE14072C9934
    4   2012 002001  3158069760000       11520000 A8BCFFD9 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0400000024000000073D220A8F18C6317AD2B4A527394631846107B9EE7358C30718C6317AD2B4A527394631842107BDCE739AC4840000000000000000000000000000000223E8AFA14270BDAB368C552B508D0A33C7CE9E3A6CF9C3A68C160401FBE8AF61427
    4   2012 002001  3158081280000       11520000 4DE31086 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6317AD294A4E7394A318C20F7BDEE735AC48718C6317AD6B4A4E5394A328C20F7B9EE739AC4040000000000000000000000000000000233E85062C06CD1A3066B552A5094FA23C74E1C3670F1C3C6CC9912022BE85062C06ED1A3168B
    4   2012 002001  3158092800000       11520000 997FD692 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA16000000040000000CA083427C68318C6316AD6B4A527394631842107BDCE739AB48718C6316AD6B4A5272946328420F7BDCE735AB4840000000000000000000000000000000223C84F60BF6ED9AB266BD5294E891A23670F9D3C6CE1A3E78E15100224082FA2
    4   2012 002001  3158104320000       11520000 90A84F51 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316B56B3A4E7294A318C21083DEF739AB48718C6316AD6B3A4E7294A318C20F7BDEE739AB4040000000000000000000000000000000223E81020BE72D1AAE5EB55A84C951A14274F9E3C6CF1E3C74C130C0223E81020BE70D1AAE5EB
    4   2012 002001  3158115840000       11520000 FC1E9E38 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6317AD6B4A4E7394A318C60F7BDCE739AB28718C6317AD6B4A4E7394A31842107BDCE739AC484000000000000000000000000000000021BD86FA1C06ED5C3262B55AA4C951213E7CE9B3C6CE1D3A78D9302021BC86FA1C06ED5BB262B
    4   2012 002001  3158127360000       11520000 C38D5155 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD6949CE739CA31846107BDEF739AC38718C6316AD6949CE739C632842107BDCE739CB4840000000000000000000000000000000213D7CF61BD70D19AF58B152A508D120367CF9E3A70E9D3C70D1604020BD7EF623E70D19AF5AB
    4   2012 002001  3158138880000       11520000 71076C56 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0200000000000000158F18C62F6AD6B49CE7394A31842107BDEF735AC40718C6316AD6B4A4E7394A318C20F7B9EF739CC4040000000000000000000000000000000213D82F9F3B6AD1B305CB152B4A8D0A23A78F9D3A68E9F3A6CD160C0213D82F613B68D1B2F
    4   2012 002001  3158150400000       11520000 B78D51C5 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0800000008000000013C10F18C6316AD2B49CE7394A518421083DCF739AC48718C6316A52B49CE7294A328420F83DCE6B9AC4840000004000000000000000000000000213A7EF60BE6ACDAB158A959F52993244674D1E3E78E9C3C74E1B2C2004176FDEC17CD1
    4   2012 002001  3158161920000       11520000 2FD1BC27 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD694A4E7294A318C6307BDEF739AC40718C6316AD694A4E7294A31846107BDCE739AC3840000000000000000000000000000000213B82F1FBD6AD17AF5EB55284C911213E78F9E386CE9E3A74D950A021BB80F5FBC6AD18AF5EA
    4   2012 002001  3158173440000       11520000 1E8F661F 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA08000000080000003F8A5A318C5F16AD2B4A4E5394A31846107BDEF739AC48718C5F16AD2B49CE5394A318C60F7BDEE739AC484000000000000000000000000000000020B776EE03E6EC9B325CA93A94CA11A03C78F1C3670E213C74D180C0203978F203E6ECD
    4   2012 002001  3158184960000       11520000 8C120A41 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000317C6316AD294A4A7294A318C6307C1EE739AC40718C5F16AD695A4E5294A318C2107BDCE739CC504000000000000000000000000000000021347CF1FBC6ECD8B35EA15264C8CFA03A8101D3880E9C3A74E140A020B77CEDFBD6CCD8B35EA
s=5 n=21 o=32205490176
    5    768 002001  3157885440000       34560000 FECB3D87 0B772A1114304B704392490000709F362DD06060606A0C0C0C0DF964641A73AB3E54F97A4AF0A95284FAB91AB2988446AF5F57735EC422CA6BBEB045F2A74FD4AA84EB2D844969C1AD5ABAAEACA62113E6F8EF9F4284FD5255D96DBF72F9F525B5EB3E84F9F3EA509F3E7D0FCAFA712244801402147EA05F028E00E6E1A7D8E0
    5    768 002001  3157920000000       34560000 23F9DAAF 0B778CE514304B705392490000709F362DD06060606A0C0C0C0DF5E43C2AEF9ED6AEF953E7CF9D3E7D096D42AE6DD67D4A3575C95F528699CD2A736AE3C8F14625755E13E88F9CD6AD6E1BE7D49F3E7AFE93AA3BEB3DAEFDD924AABE17F3AD754F57544BE57D308102403E9FE3ABC0C58EE7D90D5BF1FF93E848219D08AC88A3
    5    768 002001  3157954560000       34560000 94E84377 0B7747B014304B705392490000709F362DD06060606A0C0C0C0DF56133E54AA8BEB0E5F3F72F6B5BACEC9117C96B575696142A549F3EAEE9F50B0966E426BC5EBD7F0AAD8870AD3A84FDED37BBEB5254FA9AA2C42C2D8835F8E74F39B909AF1F9C1F2B42F9F29AF06BBE5559F3F5349F3E7D06BBF4AF9F2AA4F9F90F2BE9C489
    5    768 002001  3157989120000       34560000 51C37680 0B77858D14304B705392490000709F362DD06060606A0C0C0C0DF56463EA306BD37E45F5284FD2D28509F917C96BBE7CFD2DA851D2BE850A151B70AA45623C2951A8987274AFAB534B4A9AE7B612AAA4F9D3F4C99525889C4B99D5BA91588F0F9C1FA57EE95117E95F3E84FD2C1AEB6BC27CFD12642F9D3F4B0ADA1F2BE9C489
    5    768 002001  3158023680000       34560000 CEBC296D 0B7781A214304B70539249000070AF362DD06060606A0C0C0C0DF5614D2A519FBE73B1B217CF6BC284F954E54E6C3E4AFD2DA855D3B4855DF38E8FA984371D5EBE7F46B52D56E1527D1443E7EE2DBE7CFA13E854A953535D2BF5537A610DC75F9612BE74F6BBDAF49F427CFD2C29E9613E4E9693E554A13E7E4693EF2BE9C489
    5    768 002001  3158058240000       34560000 B1F8E97C 0B77A04C14304B70439249000070BF362DD06060606A0C0C0C0DFEA12707E866707E99C5C045061D37735F479B0E941D8E9141B5C98A7F3AB5AEF9F2AA36DEC0529C85B4BE57D1891224015A7A78FA730980B40FFDE68ED647140E8A17A06305CAC52A005EC0D1FE1C610D0D59AFF7861D070D11A94202D2F589A8736BF6C8D1
    5    768 002001  3158092800000       34560000 DFA3DBF1 0B77684A14304B703392490000708F362DD06060606A0C0C0C0DF55C6484B61CC34B5D467A34A9D1B0A1F53A4AA1527B5ABAAD5146427CFA939A6FD93574D71CA1570AA40417125C9CA6BC340AADC078FDF3D9EF5F3DB1088D7B5A971B5D5D7F9EE1581AF9F39B8E2B52D749F2B22A9EEAAD5A1537B0B542CEFD2A9B2DE88408
    5    768 002001  3158127360000       34560000 B8BA99F9 0B775CF014304B702392490000705F362DD06060606A0C0C0C0DFD5988FEA354D2DAA932A6DF0EC384BB2B3EE3552D780A904948FA9525559FAA769A6BE6031EBF7F59A2A9B7C3B1F3E3E7CA69BE7D061BDAD4A152AD5A1BEA4F953DB085F39855D2D752E5BD0C9932400025EE4CE340E1821A66DE72B5D2C031303609D82CC7
    5    768 002001  3158161920000       34560000 758C46CB 0B7792C414304B701392490000704F362DD06060606A0C0C0C0DFFE0420B75A1D77D4DEB189F827BE7DAF2C758C7CF94DD25AEE92B96F4562C5900C7D033E3A4FE7941E1C82D0DE0E7F091FBE7F514DC8413C83F0B71206FCC4388BBDC57131ED0DBBA843854FE98FF6E8F885E026E7E703D5FB4A920432C0BDF8892762E16EC
    5    768 002001  3158196480000       34560000 031A031D 0B771DDF14304B701392490000703F362DD06060606A0C0C0C0DFAA0E2AAD19EEB84BA93A7B5D5A67B5D53F681E9CB04CF73BDAC9A94287ADD52755E681EBE7456FA1397D4D751AF369C24D0ACB7A0D1A34806E8FDA583E89EC345813036CD2FD059C1282DB437487610195D23E948F0760885EFF4C1312D12A2D37CA4A2CA24
    5    768 002001  3158231040000       34560000 EB35D7DC 0B773EF314304B701392490000703F362DD06060606A0C0C0C0DF5553A07F4D0A0B70AB46A4FA16AA8A5F3E86A6B4384FD33E8081FC17696B52B57253BE730E13DA75D3264AF9E5C495A19CB6F9ED6884695387592478692BD749AE94EF9CC3F9ED4D6A50DF917B0ABBEA4F9CC2AE9A92A735AB56ACFDF3A4CE9CC3B2DE80408
    5    768 002001  3158265600000       34560000 3935C8B1 0B77FD2414304B701392490000703F362DD06060606A0C0C0C0DF6554BF7C96139854E95342F9F4285AA152A69693E7F0A1A5A6AA9A1854D2BED69E8AC6A3D5CBE52B68D37CF9F44434C8BEE88D274FFE76ACFDD25A55ABB98509FAA74A933DD699529AD4ABAA52FDCD75496CB79DB366C8036F82069FAD789BF819BD969B5BA
    5    768 002001  3158300160000       34560000 29CAC968 0B77518214304B701392490000703F362DD06060606A0C0C0C0DF6948C254FA92987561BE9CFA93E7EBA72A4CE388C5EAAB43737DFBE4E95525B4FE953FA2EC8A4AD49EC354F95577D49F27A953FF9EA927515DD3A7E8555286454C3B2DE76CD9B200046CF4E5B26F0306AA10069E27C8E31C9063D5615BFC355D3D62B9520D9
    5    768 002001  3158334720000       34560000 BB3021DF 0B77FB1F14304B701392490000702F362DD06060606A0C0C0C0DFE9862A5E469A6551D542F8506BAA8692C257F46BCE8091F3E75C2F85F3DC2AE969BDD6A9525AD0E8D755E5BCF89122403E17AE8351AF1DE308471EF09A55CC3410A10E31ED5BD91212BD26D39FD5A3DAEDA0D5AE3087E2D526FB8993D5B4EDCA112D7DE936D
    5    768 002001  3158369280000       34560000 A5EFF183 0B77836E14304B701392490000702F362DD06060606A0C0C0C0DF55C3D76AFDF4255712AA52E6AF54D5EB3EAB4A142A6F6C254CADCBE7EE92D6850A01BF454DEBDBAB5FDA871DD91AD0D52B21069D74AFD55654FB5BD7D49D3EB835806FD153F9CB45B86F6BAA730DD41AEF9F2E74A953D84FA9BDA50ABAA4B4A9BE72DE85CB9
    5    768 002001  3158403840000       34560000 C0EF7F03 0B77DA2414304B7FF392490000701F362DD06060606A0C0C0C0DF55C8C254F9F39A5129A5A4956AA80A643F4E346567D0B3A5534AA2A85494D6B49A43CE432503D7F5A4437CBAB58530DD3DA4AA95B7AAA0257D0DEBF4BBDCBEAF5990F390C9F9F2B3F4B4DF29855AA217499CD41AA9529855AB527CFAB42A55D33E72FE92448
    5    768 002001  3158438400000       34560000 13E3DD0A 0B77DAF814304B7FF392490000701F362DD06060606A0C0C0C0DFB9D34E7B0E8D920FAC3A194AB3EB0E8721825570DB7B712C44EC888BF3D2F53012A986E61BA534DEC37AE5BD289122400100F4CB6A443E26D9D3B0AE994617FB8F8122A873A0ADCD2C973616BB8108F043D130370B2F8594FE8C89AFD53559BCBF618442EEF
    5    768 002001  3158472960000       34560000 4B27D3E9 0B77B85D14304B7FF392490000701F362DD06060606A0C0C0C0DF96463F2ABCB2A7CA9F397CFF795AE867A2B6C99FC472F9D2A8AE5DA9D6E94BECBC14BF54A96EC4B50643CB4A15774F92C2EDB267F13E437EE612F2499C5A8EF6451D4F9F2E7E45F3F2AE7414B74A342A68BCB7A5D3A74803682321521F194AD54B2D95146D7
    5    768 002001  3158507520000       34560000 1BB5F545 0B772B9014304B7FF392490000701F362DD06060606A0C0C0C0DFD5D2D2A5477BF850A741C7F8553F470AB2F90F61B94CA94DB80F9CC37D06016534F625CCF2ADC44FD2D071FE155F3B53A34DED74B0DF3B1AF9D2654E932A7CA5FBA7695F2A735DD298565BD108102403D067CBA9FD0180FAF042C218A1147E7FEFF88096BF6
    5    768 002001  3158542080000       34560000 3ACD5C9D 0B7719AE14304B7FF392490000701F362DD06060606A0C0C0C0DF559340531B5594AA6E0B750D2BAA6E5D3A54F9F58190E6D77B648D6553C6BDAD4DC495EAFD26B88F69C3830E0BF4B4AA2B5B06C354AFABAEAEDA955AEE92BEA74A71257ABFF9EEBAA7359FA6534DD3E4CA69AA54961BA7B4D33DA6F63BE4C98925B2DE864C9
    5    768 002001  3158576640000       34560000 61493F49 0B775D4914304B7FF392490000701F362DD06060606A0C0C0C0DFF61230195E1B4D95E8B97ECA9539913D32A9C4F3B8AFE76AF49D2A534DF90A6F973A7B5A1BD86F9F3E44F9D51A6F9F3E7CFECB7A4102048073828349F0FEE1F64F478871B408037437BA1E0DFD7156007FEB085401722B7D2A3FC856E970883B492C5667231
s=6 n=0 o=32214220800
mt=000002A9AD5A59A0 n=8
    0 286849 000008  3157969815000       45045000 CFC368E1 0000003650018431002AD6D5611CB7036EF1E849185E473294C3F5C19925B976E42B404B410854DD1548D02204B643F59790EE1730644DDB6F8000000003460150000000074E0101020183800002B1E40001E066B5FD463008869B7EDB5676BAAD922C6D63AB2FD8EA9A74D3A6051E29AD4DDA4B54DEA594999F0CE967B544EA
    1   4824 002001  3158196480000       11520000 8CEFC004 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000020000000200000000000000011A23DA38F204A31845EE6B5AD5AD6B52929424C420C42145AC5A926398C5294A5298C531463108220C5AC5A92631CC5294A5298A529483108410C9AB5A9294A509
    2   2012 002001  3158196480000       11520000 F8AEDC4B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000020000000200000000000000011A23DA38F204A31845EE6B5AD5AD6B52929424C420C42145AC5A926398C5294A5298C531463108220C5AC5A92631CC5294A5298A529483108410C9AB5A9294A509
    3   2592 002001  3158196480000       11520000 FD9D3880 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD2B4A4E72946318C2107BDEF739AC48718C6316AD294A4E72946318C2107BDEE739AC504000000000000000000000000000000020BB7CF1FBC6EC59AF5EA94254C8101E3E70E9E3674D9C3670D141401FBB7CF1F3C6CC592D5CA
    4   2012 002001  3158196480000       11520000 9F02D879 7FFE8001FC3C7DB0B700093B8003EF7FE07EDB7FFFFFFFFFFFA0000000000000000318C6316AD2B4A4E72946318C2107BDEF739AC48718C6316AD294A4E72946318C2107BDEE739AC504000000000000000000000000000000020BB7CF1FBC6EC59AF5EA94254C8101E3E70E9E3674D9C3670D141401FBB7CF1F3C6CC592D5CA
    5    768 002001  3158611200000       34560000 E48243CF 0B77545714304B7FF392490000701F362DD06060606A0C0C0C0DFAE08A74282E3EDEF5EC3A6F9F436AFA952727B36183B610A27CFE66D72861C04AE6731F3E3E7CF756C4165BD289122403EF6EEB8EBDF99876193B28BF5D25E91BF8F18481BA1739D65E40B74CF00C210C690C1E8B6E3420205A8773F29106AEAF4F287EDDC5
005003:0000 Failed to save title 0 to file I:/Make MKV/spaceballs/Spaceballs_t00.mkv
002023:0000 Encountered 3 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=3 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 2 unclassified errors
error=0xC0000013 count=1 name=OS error - {No Disk} There is no disk in the drive. Please insert a disk into drive hs
error=0xC000009C count=1 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
Application exited at Tue Mar 15 06:03:07 2022
Re: Need Help Diagnosing Issues with WH14NS40 Drive
Clean the disc
Replace the disc
Billycar11 wrote: Tue Mar 15, 2022 10:31 pm Clean the disc
Replace the disc
Clean the laser lens. If nothing works scrap the drive.
You could try using MakeMKV drive speed control to slow the rip speed down and see what happens.
