deadchip12
When I connect the usb hard drive that contains movies into the x700, can I cut/copy/paste movies' files from folders to folders directly on the x700? Because based on what discussed here, the bluray folder of a movie needs to be placed in the root folder of the hard drive in order to be played without issues on the x700, so if I want to switch to another movie I have to do some cut/paste between folders, and I don't want to have to unplug the hard drive from the x700 and plug it into my pc everytime for that.
unfortunately, you need a pc every time.deadchip12 wrote: ↑Tue Mar 15, 2022 12:36 pmI don't want to have to unplug the hard drive from the x700 and plug it into my pc everytime for that.
yeah, I'm not sure about that one...Gatorman wrote: ↑Tue Mar 15, 2022 6:39 am@RESET_9999 Thank you for the comprehensive script. I have a question regarding MaxCLL and MaxFALL values assigned to the RPU, when working from a madVR HDR measurement file. Should the MaxCLL and MaxFALL values be pulled from the measurement file or manually assigned? I have some HDR10 files that do not list MaxCLL or MaxFALL values, when viewing with MediaInfo. I'm in the habit of leaving these values set to "0" and allowing them to be set from the measurement file.
I asking because the "MODE.madVR.TO.DoVi.workflow.8" option seems to be overriding them, in the case when they are set to "0". I modified the script a bit by removing the L6 "editor" lines and injected the original "%output_path%rpu.bin" created. This allowed the MaxCLL and MaxFALL values to be from the measurement file.
Is this the expected behavior or should they be set to "0"?
it's probably better to use the metadata from madvr measurements. I still have work to do in the madvr to dovi workflows.
well if you use a bluray player like the x800m2 / x700 / oppo, you still have to add an ac3 core otherwise the TrueHD wont work but soon tsmuxer should be able to generate a silent core and merge it like THDMERGE.exe does.
Why not just create a 64kbps or 128kbps ac3 track from the original audio? Or use the core ac3?RESET_9999 wrote: ↑Mon Mar 07, 2022 8:10 pmI couldnt make a 32kbps track and thdmerge would not process a 40kbps track but it seems to work at 64kbps. Hopefully, the track still play on my x800m2ArArdin wrote: ↑Mon Mar 07, 2022 5:29 pmYes, I'd think so too. Thinking of this new option, any other track that's on the disc? For example, a commentary track you really like?RESET_9999 wrote: ↑Mon Mar 07, 2022 12:13 pmI guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
here's 4h of silent 5.1 AC3 audio at 64kbps.
https://drive.google.com/file/d/19n0b_0 ... sp=sharing
EDIT: it works on the x800m2 !!!!!
that would require encoding. With the 4h silent track, I can use it for any movie without having to re-encode.MartyMcNuts wrote: ↑Tue Mar 15, 2022 11:26 pmWhy not just create a 64kbps or 128kbps ac3 track from the original audio? Or use the core ac3?
The provided link for 4h of silent ac3 audion doesn't work:RESET_9999 wrote: ↑Wed Mar 16, 2022 12:31 amthat would require encoding. With the 4h silent track, I can use it for any movie without having to re-encode.MartyMcNuts wrote: ↑Tue Mar 15, 2022 11:26 pmWhy not just create a 64kbps or 128kbps ac3 track from the original audio? Or use the core ac3?
Can you please share it again?
Nope I am Linux guy and I think there are tools for windows already. Anyways you should be able to use it with WSL2
That error comes from newest mp4box you need to have version 1.0.1 installed then it will be fineSnickers333 wrote: ↑Mon Mar 14, 2022 1:03 pm
Guys i have run into a problem running this script.
https://github.com/gacopl/dvmkv2mp4
I tried to troubleshoot it myself but with no luck. Anyone run into this issue as well ?
Trying to convert Profile 7 BL_RPU_EL single track mkv to mp4
This is for linux not windows it's meant to be put on your mediaserver/NAS whatever, follow the steps from README to install all needed stuff
You can also run it in virtual machine with linux
@RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
More reasons to collect physical media. Ugoos AM6B+.
when you manually edit L5. You enter just 260...Gatorman wrote: ↑Sun Mar 20, 2022 5:56 am@RESET_9999 Wow! You're really improving your DoVi_Scripts. What is the correct input to edit the L5 data? "260/260" or "260 260"? (Forward slash or space or something else) I'm getting an error when attempting to set a custom L5 value and not when "cropping". "MODE.madVR.TO.DoVi.workflow.2"
in manual modes, it only edit top/bottom which means if your video has right and left borders, you have to use the AUTO-L5 workflows.
The new version that I'll upload today will include:
- Support input files with space and special characters
- New workflows that fix invalid L6 metadata in some p5 web-dl (> 10 000)
- New workflows that can remove HDR10plus when injecting DV ( for the firestick TV)
- Now the output filename will be the input filename instead of just " P8.hevc"
rosavanwinkle
My god this thread is still going even after maybe 2 years of being inactive on it...
so if i wanna convert my raw blueray files with dolby vision to a single layer what is the best use atm?
It is for use on a shield tv pro with plex and a LG tv
i used to use yuescope tool,but is their something else out their now or something better?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
