Compatible firmware versions are in the first post. If yours isn't there, contact Mike so he can dump it from your drive and add it to the list.doublepwn wrote: ↑Sun Mar 13, 2022 4:36 amHi guys,
I recently purchased a BDR-212UBK and it looks like may not be supported (currently using SDF v88). Do I need to dump the firmware or update the firmware on the drive?
Makemkv reports the drive as:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: SLDL00XXXXXX
Firmware date: 2019-01-10
Highest AACS version: 76
Drive platform: Pioneer RS8F01
Firmware version: ID58
LibreDrive for Pioneer drives
Please contact Mike to complete his lists of supported firmwares. However, you can also update to 1.01 using the Pioneer firmware update utility for your drive:
https://pioneer.jp/device_e/product-e/i ... #firmware1
I can confirm Verbatim #43888 is LibreDrive capable external Pioneer drive. I had it on 1.14 firmware (2020-06-15) from the box matching the following entry.
Although it does not matter MakeMKV this drive seems to be official 4K UHD BD drive with AACS2 keys for e.g. proper SGX/PowerDVD Ultra usage (don't bother
). There are at least two model number variations and #43888 is the official UHD BD drive.
PIONEER-BD-RW___BDR-UD04-1.14-489CDFD6-8A10-20200615LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
Debug log started at Sat Mar 19 11:57:32 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file:
No SDF v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WL
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF id v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WL
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: QBDL019130WL
Firmware-Datum: 2017-04-18
Drive platform: Pioneer RS8510
Firmware version: ID22
mkv says its BD-RW BDR-XD05 but the full product listed on the bottom of the disc drive is BD-RW BDR-XD05TB
i inserted jumanji official 4k disc i bought off the shelf and it didnt read it
Contact Mike. Yours should work. Maybe a special firmware variant.Lok749 wrote: ↑Sat Mar 19, 2022 12:00 pmCode: Select all
Debug log started at Sat Mar 19 11:57:32 2022 , written by MakeMKV v1.16.7 win(x64-release) 001005:0000 MakeMKV v1.16.7 win(x64-release) gestartet 001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file: Using 262272KB for read cache. Network access is ENABLED, CURL version 7.72.0/Schannel/1.41.0 (x86_64-pc-win32) , proxy server not set. WinCdArb=v1.2.0_tiny win(x64-release) No SDF v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WL DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310 SDF id v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WLCode: Select all
Laufwerksinformation OS-Gerätename: E: Produzent: ASUS Produkt: SBW-06D2X-U Revision: 1.10 Serienummer: QBDL019130WL Firmware-Datum: 2017-04-18 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 76 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8510 Firmware version: ID22
List the Makemkv status report. Maybe your firmware version isn't supported.
That's because your drive isn't a UHD model and doesn't natively read UHD discs.
You are right Marty. The drive's names have to include the letter "U" to work with UHDs.MartyMcNuts wrote: ↑Sun Mar 20, 2022 9:25 pmThat's because your drive isn't a UHD model and doesn't natively read UHD discs.
Debug log started at Sun Mar 20 19:02:25 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Albert/MakeMKV_log.txt
SDF v088: PIONEER_BD-RW___BDR-XD05_3.10_OLDL00XXXXXX
Application exited at Sun Mar 20 19:04:26 2022
OS device name: E:
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OLDL00XXXXXX
Firmware date: 2017-06-22
Highest AACS version: 62
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
i thought thats what LibreDrive is meant to do. read the whole disc data raw bypassing anything that gets in the way to protect the data
No, libredrive won’t pass everything. It stops a drive from being revoked with new AACS revisions and re-enables UHD disc reading within a drive’s firmware if it could already recognise a UHD disc. The AACS encryption/decryption process still works the same as always. Libredrive doesn’t change that.aat92 wrote: ↑Mon Mar 21, 2022 7:21 amDebug log started at Sun Mar 20 19:02:25 2022 , written by MakeMKV v1.16.7 win(x64-release)
OS device name: E:
Revision: 3.10
As mentioned before, your drive isn't a UHD model and doesn't natively read UHD discs.
alixwithnobeanie
Hello, I'm new to this so sorry if I don't understand everything.
I have a Verbatim drive that is a rebranded Pioneer drive. It should be supported for libredrive but it's not yet enabled. From what I understand, this means that Mike needs to add the firmware manually? Should I message him directly or is a post here enough?
Thanks a lot for the help, here is my drive info :
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ACDL383626WL
Firmware date: 2020-06-15
Highest AACS version: 66
Firmware version: GENE
Disc Information
Label: GOT_S2_DISC3
Timestamp: 2019-03-06 13:15:17
Protection: AACS v66
Data capacity: 45.85 Gb
Disc type: BD-ROM
Number of layers: 2
Revision: 1.14
Disc Information
Label: GOT_S2_DISC3
Disc type: BD-ROM
Number of layers: 2
In other posts, he's asked people to PM or email him, which is probably what you should do in this case. For example: viewtopic.php?p=118847#p118847alixwithnobeanie wrote: ↑Wed Mar 23, 2022 4:08 pmHello, I'm new to this so sorry if I don't understand everything.
hey guys
with the BDR-S12UHT now supported, could one argue this is the best drive to now get over the LG BH16NS55 and ASUS BW-16D1HT Pro (obviously flashed to make friendly)
Is there any benefits of having a friendly drive over a BDR-S12UHT official
The other drives are faster and work with more programs
Pioneer rips UHD at 4x LG/Asus can rip up to 12x or 8x stock
