MakeMKV v1.6.5 darwin(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-875 DB09" opened in DASPI mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI mode.
Evaluation version, 2 day(s) out of 30 remaining
File 00100.mpls was added as title #0
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #1
File 00007.m2ts was added as title #2
Title #00005.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/2TB External HDD/MKV Files
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '10832510976'
Failed to save title 0 to file /Volumes/2TB External HDD/MKV Files/title00.mkv
0 titles saved, 1 failed
The disc doesn't have any scatches or cracks, so I assume that's not the issue. Tried 3 different time - twice with a previous built and once with the most recent build (1.6.5). Any suggestions?
Error when ripping Inception Bluray
kbutler84
Re: Error when ripping Inception Bluray
http://www.makemkv.com/faq/item/7/catid/6
I saw this, and examined the disc again. I can't seem to find any scratches or imperfections on the disk though.
Romansh
My copy of Inception ripped just fine (LG BH10LS30 in extenal USB enclosure, MakeMKV 1.6.5, MacBook Pro running OS X 10.6.6).
Why is MakeMKV using direct disc access? Do you have DASPI 1.2 installed?
kbutler84
Romansh wrote:Why is MakeMKV using direct disc access? Do you have DASPI 1.2 installed?
Yeah, it is installed. And when I downloaded the new version of MakeMKV, I reinstalled it just in case it was removed when I deleted the old version.
Please try to make a full disc backup with MakeMKV first. But the error does look like a bad disc.
pelegram34
Alright, I'm having this same problem as well. I get about 17 Gb into the rip and then it happens:
MakeMKV v1.6.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Lankin/MakeMKV_log.txt
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at qB"4q5hwAAzifof@:121269156
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00009.m2ts has length of 62 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00008.m2ts has length of 148 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00007.m2ts has length of 146 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00005.m2ts has length of 101 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00004.m2ts has length of 78 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Saving 1 titles into directory N:/Video/Inception
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393953
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683105280, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683418624, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683424768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683430912, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683695104, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683713536, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18684837888, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18687264768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18687301632, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18688462848, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689636352, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689648640, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689654784, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18690471936, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691080192, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691086336, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691700736, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692573184, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692579328, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692585472, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692591616, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692610048, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18693163008, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18695553024, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18696480768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697052160, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697058304, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697064448, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697070592, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697089024, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697887744, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697900032, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697906176, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697918464, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697924608, attempting to work around
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393907
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:121262509
DEBUG: Code 0 at CQdHTn+?Xq-BeRMa"F,F:29394321
DEBUG: Code 9129852 at CQdHTn+?Xq-BeRMa"F,F:29393309
DEBUG: Code 0 at TbxNL?L'!OrC\Vi%oQ9x4:29397449
Failed to save title 0 to file N:/Video/Inception/title00.mkv
There are no readily apparent scratches, smudges, or other blemishes on the disk. What gives?
Same ask, please make a full disc backup per http://www.makemkv.com/faq/item/4/catid/4 and see if any hashcheck errors show up.
pelegram34
Sorry, Mike. Thanks for repeating yourself. Here's what I got:
Backing up disc into folder "E:\Music and Movies\Inception"
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18695448576, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18705672192, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18829535232, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18873575424, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18888321024, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00001.m2ts.
Hash check for /BDMV/STREAM/00001.m2ts : 0.00% corrupt, 99.99% correct, 99.99% checked.
Backup done but 1 files failed hash check
Is this irreparable?
crowfax
Yes, the disc is damaged.pelegram34 wrote:Is this irreparable?
