LibreDrive for Pioneer drives
#166 Post by MartyMcNuts » Sun Mar 13, 2022 4:47 am
doublepwn wrote: Sun Mar 13, 2022 4:36 am Hi guys,
I recently purchased a BDR-212UBK and it looks like may not be supported (currently using SDF v88). Do I need to dump the firmware or update the firmware on the drive?
Makemkv reports the drive as:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: SLDL00XXXXXX
Firmware date: 2019-01-10
Highest AACS version: 76
Drive platform: Pioneer RS8F01
Firmware version: ID58
Compatible firmware versions are in the first post. If yours isn't there, contact Mike so he can dump it from your drive and add it to the list.
#167 Post by Coopervid » Sun Mar 13, 2022 11:09 am
Please contact Mike to complete his lists of supported firmwares. However, you can also update to 1.01 using the Pioneer firmware update utility for your drive:
https://pioneer.jp/device_e/product-e/i ... #firmware1
hansolo
#168 Post by hansolo » Mon Mar 14, 2022 12:49 pm
I can confirm Verbatim #43888 is LibreDrive capable external Pioneer drive. I had it on 1.14 firmware (2020-06-15) from the box matching the following entry.
PIONEER-BD-RW___BDR-UD04-1.14-489CDFD6-8A10-20200615
Although it does not matter MakeMKV this drive seems to be official 4K UHD BD drive with AACS2 keys for e.g. proper SGX/PowerDVD Ultra usage (don't bother :D). There are at least two model number variations and #43888 is the official UHD BD drive.
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
Lok749
#169 Post by Lok749 » Sat Mar 19, 2022 12:00 pm
Debug log started at Sat Mar 19 11:57:32 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file:
No  SDF v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WL
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF id v088: ASUS_SBW-06D2X-U_1.10_QBDL019130WL
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: QBDL019130WL
Firmware-Datum: 2017-04-18
Drive platform: Pioneer RS8510
Firmware version: ID22
aat92
#170 Post by aat92 » Sun Mar 20, 2022 6:29 pm
mkv says its BD-RW BDR-XD05 but the full product listed on the bottom of the disc drive is BD-RW BDR-XD05TB
i inserted jumanji official 4k disc i bought off the shelf and it didnt read it :(
#171 Post by Coopervid » Sun Mar 20, 2022 9:22 pm
Lok749 wrote: Sat Mar 19, 2022 12:00 pm
OS-Gerätename: E:
Produzent: ASUS
Revision: 1.10
Contact Mike. Yours should work. Maybe a special firmware variant.
#172 Post by Coopervid » Sun Mar 20, 2022 9:23 pm
aat92 wrote: Sun Mar 20, 2022 6:29 pm Image
List the Makemkv status report. Maybe your firmware version isn't supported.
#173 Post by MartyMcNuts » Sun Mar 20, 2022 9:25 pm
That's because your drive isn't a UHD model and doesn't natively read UHD discs.
#174 Post by Coopervid » Sun Mar 20, 2022 9:31 pm
MartyMcNuts wrote: Sun Mar 20, 2022 9:25 pm
You are right Marty. The drive's names have to include the letter "U" to work with UHDs.
aat92
#175 Post by aat92 » Mon Mar 21, 2022 7:21 am
Coopervid wrote: Sun Mar 20, 2022 9:23 pm
Debug log started at Sun Mar 20 19:02:25 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Albert/MakeMKV_log.txt
SDF v088: PIONEER_BD-RW___BDR-XD05_3.10_OLDL00XXXXXX
Application exited at Sun Mar 20 19:04:26 2022
OS device name: E:
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OLDL00XXXXXX
Firmware date: 2017-06-22
Highest AACS version: 62
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
i thought thats what LibreDrive is meant to do. read the whole disc data raw bypassing anything that gets in the way to protect the data
#176 Post by MartyMcNuts » Mon Mar 21, 2022 9:37 am
aat92 wrote: Mon Mar 21, 2022 7:21 am
OS device name: E:
Revision: 3.10
No, libredrive won’t pass everything. It stops a drive from being revoked with new AACS revisions and re-enables UHD disc reading within a drive’s firmware if it could already recognise a UHD disc. The AACS encryption/decryption process still works the same as always. Libredrive doesn’t change that.
As mentioned before, your drive isn't a UHD model and doesn't natively read UHD discs.
alixwithnobeanie
#177 Post by alixwithnobeanie » Wed Mar 23, 2022 4:08 pm
Hello, I'm new to this so sorry if I don't understand everything.
I have a Verbatim drive that is a rebranded Pioneer drive. It should be supported for libredrive but it's not yet enabled. From what I understand, this means that Mike needs to add the firmware manually? Should I message him directly or is a post here enough?
Thanks a lot for the help, here is my drive info :
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ACDL383626WL
Firmware date: 2020-06-15
Highest AACS version: 66
Firmware version: GENE
Disc Information
Label: GOT_S2_DISC3
Timestamp: 2019-03-06 13:15:17
Protection: AACS v66
Data capacity: 45.85 Gb
Disc type: BD-ROM
Number of layers: 2
#178 Post by dcoke22 » Wed Mar 23, 2022 6:06 pm
alixwithnobeanie wrote: Wed Mar 23, 2022 4:08 pm Hello, I'm new to this so sorry if I don't understand everything.
In other posts, he's asked people to PM or email him, which is probably what you should do in this case. For example: viewtopic.php?p=118847#p118847
horze
#179 Post by horze » Wed Mar 23, 2022 10:57 pm
hey guys
with the BDR-S12UHT now supported, could one argue this is the best drive to now get over the LG BH16NS55 and ASUS BW-16D1HT Pro (obviously flashed to make friendly)
Is there any benefits of having a friendly drive over a BDR-S12UHT official
#180 Post by Billycar11 » Wed Mar 23, 2022 11:15 pm
horze wrote: Wed Mar 23, 2022 10:57 pm hey guys
The other drives are faster and work with more programs
Pioneer rips UHD at 4x LG/Asus can rip up to 12x or 8x stock
