I am still having issues with a few discs of old TV shows that were made by my Panasonic consumer DVD recorder. (Yes, I am back at this effort again a year later.) While downgrading MakeMKV to 1.14.7 from the 1.15.4 had helped with some of them, there is one disk that wouldn't work even with 1.12.3. I just tried that same disk on the current 1.16.5 and processing still grinds to a standstill 3/4 of the way through. I copied the disk to my hard drive without issue and then tried to process the files from there and that also does not help.
So it appears nothing has happened to resolve this problem.
New version of MakeMKV extremely slow read rate
mkvusr1
Username1267
Re: New version of MakeMKV extremely slow read rate
I also noticed that the new version reads at 0.6 x. Not all discs but some. But I am not quite sure in which version it started. I haven't used 1.16.7, yet. So it must be 1.16.6 or earlier.
https://www.makemkv.com/download/ Somewhere in MakeMKV's recent history, I think about 1.15.4, MakeMKV got the ability to slow down the read rate at layer transitions and if the drive was struggling to read the disc because of dirt or whatever. Since 1.16.7 has the same mention of improvements for discs with mastering errors as 1.15.4, it could be the speed control is being used more aggressively. I'm just speculating, however.Username1267 wrote: Fri Mar 11, 2022 6:25 pm I also noticed that the new version reads at 0.6 x. Not all discs but some. But I am not quite sure in which version it started. I haven't used 1.16.7, yet. So it must be 1.16.6 or earlier.
chiefbeats
Perhaps this will help? It changes the rip speed of discs. Made a huge difference for me!
viewtopic.php?f=19&t=22689
