Just thought I'd give a heads up and was wondering if the developers have a copy of the latest OS X to test with! Thanks for all your great work!!Fatal error occurred, program will now exit.
Mac OS X 10.7 Lion Support
I know it's still really early and the developer preview has just been released, but at this moment, I cannot get the latest build of MakeMKV for Mac to run. The UI comes up for a few seconds when opened, then it reports the following:
Re: Mac OS X 10.7 Lion Support
+1
Same issue here.
Same issue here.
- Contact:
Confirmed problem with MakeMKV, next version should work fine.
You all are awesome! Thanks for the prompt reply and resolution!
Any word on when the next version will be out? I'm anxious to give it a try in Lion.
Are you looking for users to test the new version on Lion? I'd be happy to give it a try...mike admin wrote:Confirmed problem with MakeMKV, next version should work fine.
It would make my transition to 10.7 complete, because I rely on Makemkv plugin in Plex to playback Bluray painlessly.
- Contact:
Should be available very soon. Thanks for patience
A little more than a week later, presenting version 1.6.6.
It's perfect for Lion. Transition is complete that coincides with Preview 2, which might be as good as final.
Life is back to normal. Plex is now playing bluray beautifully.
Could you point me to that plugin? I've been trying to find it but all the links I find are dead ends.tdtran1025 wrote:It would make my transition to 10.7 complete, because I rely on Makemkv plugin in Plex to playback Bluray painlessly.
