Tinker Tailor Soldier Spy
Procat
Post by Procat »
Has anyone been able to copy this title. Disc is from Target. After what seems like ‘chewing’ the disc sometime loads but for the most part fails. If it does load it fails on what would appear to be the 2nd layer. Using both lg16ns40 flashed to both 1.00 and 1.02. Also tried BU40NS flashed to 1.00
Possibly manufacturing error?
Re: Tinker Tailor Soldier Spy
have you tried cleaning the disc?
Procat
Post by Procat »
Billycar11 wrote: Tue Mar 08, 2022 11:15 am have you tried cleaning the disc?
One of the first things I try. I usually use eye glass wipes, will try some other ways I found on google.
Thank you for the reply though.
speeddemon
Post by speeddemon »
I ran into this same problem with two separate copies of this movie. It seems like there's either a new form of copy protection or an incompatibility with MakeMKV.
lfoust
Post by lfoust »
I also had a ton of trouble ripping the 4K version of the movie with my copy purchased from Kino Lorber. I had given up until I accidentally bought a second copy (long story) and my new copy worked! This is how the contents of the discs turned out for me: https://thediscdb.com/movie/tinker-tail ... -lorber-4k
