chros
Post by chros » Mon Mar 07, 2022 1:56 pm
I guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
That would be really cool!
And waht was tgat fix.ts file?
Post by RESET_9999 » Mon Mar 07, 2022 3:03 pm
I don't understand ?
susanstone2022
Post by susanstone2022 » Mon Mar 07, 2022 3:59 pm
strange. in my testing, thdmerge took longer than eac3to encoding.
ArArdin
Post by ArArdin » Mon Mar 07, 2022 5:29 pm
RESET_9999 wrote:
Mon Mar 07, 2022 12:13 pm
Yes, I'd think so too. Thinking of this new option, any other track that's on the disc? For example, a commentary track you really like?
DolbyVisionFTW
Post by DolbyVisionFTW » Mon Mar 07, 2022 5:36 pm
And what was that fix.ts file?
You used to have a link listed in your signature to a file that would fix an issue during playback where the device would lock up.
Post by RESET_9999 » Mon Mar 07, 2022 6:48 pm
thats what i thought but wasnt sure.
The file is still available in the DoVi test files link in my signature.
@chros, that file will unlock the oppo/x700 for when you play 2 DT-DL TS video in a row.
Post by RESET_9999 » Mon Mar 07, 2022 8:10 pm
I couldnt make a 32kbps track and thdmerge would not process a 40kbps track but it seems to work at 64kbps. Hopefully, the track still play on my x800m2
here's 4h of silent 5.1 AC3 audio at 64kbps.
https://drive.google.com/file/d/19n0b_0 ... sp=sharing
EDIT: it works on the x800m2 !!!!!
Albano
Post by Albano » Tue Mar 08, 2022 7:22 am
@RESET_9999
Now if I want to mux DV P8 .mkv file to DV P8 .mp4 file, what should I do?
ArArdin
Post by ArArdin » Tue Mar 08, 2022 9:19 am
I tried to add 2ch 32kbps AC3 with eac3to. No dice, got error.
Good to know silent core is working on the Sony.
Thanks for the file :D Most handy
ArArdin
Post by ArArdin » Wed Mar 09, 2022 11:40 am
For us lazy people:
UsEac3To, GUI to eac3to, has added small GUI support for thdmerge with truncating option. THD and AC3 must have same name.
Read here: https://forum.doom9.org/showthread.php? ... ost1965348
Albano
Post by Albano » Thu Mar 10, 2022 8:01 pm
KyleLeMarbe wrote:
Mon Feb 07, 2022 3:24 am
Created some powershell scripts to handle MKV to MP4 with dolby vision. Hoping others can get some value out of them.
https://github.com/KyleLeMarbe/DolbyVisionMuxer
Why Audio offset in your script is it 1100ms?
What's wrong with 0ms?
mehgh750
Post by mehgh750 » Fri Mar 11, 2022 1:31 am
I've got Sony X700 but it cannot play my BDMVs from 4k UHDs. I googled it and found this forum. If I understood correctly, X700 cannot read BDMVs ripped from discs. I should create another BDMV folder using tsMuxeR, am I right? Can someone please explain the workflow how I am supposed to do that. A total newbie here.
Albano
Post by Albano » Fri Mar 11, 2022 8:57 pm
gacopl wrote:
Sun Mar 06, 2022 7:27 pm
Hi i have something to share
I am owner of LG CX and C8 models and also nvidia shield.
I made numerous conversions to make sure what is best, i found that for those LG models most reliable is mp4, m2ts is somewhat ok but for me had seeking issues at least with emby. I have found its best to convert to proper mp4 and keep Atmos and other tracks for safekeeping to be able to remux to mkv in future once at least nvidia shield plays correctly (it does not due to colors issues etc). I have found for best results is to play mp4 directly on Emby app on LG
I have created bash script that automates authoring and conversion of different Dolby Vision mkvs to mp4 that will work on above LG models without issues, so far i have converted around 30 releases no issues to the point i automated workflow
So my tool converts whatever mkv you throw at it to mp4 with DV4,5 or 8 with EAC3 audio and keeps original truehd atmos etc alongside for future, i have tested and remuxing with mkvtoolnix makes it playable with atmos again on nvidia shield no issues.
It automates ffmpeg dovi_tool and mp4box workflow and try to use as little drive space as possible thanks to linux pipes. I have it running on my NAS and is chugging along fine
https://github.com/gacopl/dvmkv2mp4
Take a look comment, or contribute :)
Tell me how to setup and run your script.
I've download it to my PC, but I cannot run it.
fib1985
Post by fib1985 » Sun Mar 13, 2022 5:28 am
fib1985 wrote:
Thu Nov 26, 2020 10:35 am
Hi guys,
actually have some way to play mkv dolby vision dual layer (base layer and enhancement layer) on lg cx ?
Hy Guys, it's quite a while i don't check this awesome forum! Is now that possible ? I checked the first page but i don't find any information about. thanks!
comorla45
Post by comorla45 » Sun Mar 13, 2022 8:13 pm
I believe it is still not possible, at least with my B1, so C1/CX will 99% be the same. LG just seems to downgrade their TVs (first ditch DTS, then P7 DV).
@gacopl would it be possible for you to make this script for windows powershell/cmd? I was looking for just that, as I use plex on LG B1/C1 and other devices, so AC3/EAC3 is a must for direct stream with subtitles (LG).
