thanks. too difficult for me.
I've had an issue like that where I get the 'no signal' message on my TV when turning on the player. It was usually fixed by turning the TV off and on again. My player is connected directly to the (LG) TV so it's definitely not something that only happens with switches.
My setup is to use the Sony just for DV rips, and to use another box for HDR10 stuff and streaming (I use an Apple TV 4K, but I expect that any of the other good mainstream streaming boxes would work nicely since it seems to be a lot easier to get HDR10 playback right compared with DV).
Thanks for posting your impressions, and I'm glad things are mostly working for you too. For my part, now that I'm feeding the X800M2 files that aren't broken, it's handled every movie I've tried fine. But I have only been testing titles out for ~20 mins or so and shamefully haven't found time to watch a whole movie yet.
Ah damn.. I bound the vrooms hot plug command to HomeKit and Siri, so I can recover without TV restart atm.FubbAyH wrote: ↑Mon Mar 07, 2022 1:19 amI've had an issue like that where I get the 'no signal' message on my TV when turning on the player. It was usually fixed by turning the TV off and on again. My player is connected directly to the (LG) TV so it's definitely not something that only happens with switches.
Me too, but no HD audio passthrough (Atmos). I also have a Shield pro but im trying to sell it to consolidate and also because of the various color issues even in non DV (if I got it right).FubbAyH wrote: ↑Mon Mar 07, 2022 1:19 amMy setup is to use the Sony just for DV rips, and to use another box for HDR10 stuff and streaming (I use an Apple TV 4K, but I expect that any of the other good mainstream streaming boxes would work nicely since it seems to be a lot easier to get HDR10 playback right compared with DV).
Hence the Oppo 203 clones seemed so appealing to me, as it seemed to tick all boxes, minus the "mkv; to AC3 and back to truehd again" and "run the fix.ts after watching DV ts files" hassles.
It's been great so far indeed. I'm testing it and up til now it has stood up to the promise. Yeah, it's a two way process but I don't mind as I usually do a lot of steps manually. Combined with DGDemux it's the perfect toolset for gap processed demuxing and remuxing with the native Dolby AC3 track. This guy makes great software.RESET_9999 wrote: ↑Sun Mar 06, 2022 5:53 pmI tested this new tool and it worked very well and this is exactly the solution I was looking for the other day: a way to merge thd with ac3 without encoding the core in eac3to.
Took about 3min for a 2h movie when eac3to usually takes more than 10minutes.(more if clipping detected).
Obviously, you have to demux the mkv first(and ac3 track must be present) but it still faster thanks to my NVME drive (+ most of the time i have to demux the hevc too anyway)
The fact that it can fix the gap from makemkv files is great as well.
I hope it plays well on the x800m2...
Could you please let us know how it plays on your X800M2? I haven't decided yet on purchase.
Thanks for the script!
yes, it works, and no problem with the 10min I tested.
from the author of the tool:
I guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)Glad you find it useful and thank you for your testing. I will release it formally with source code tomorrow. There will be an option to choose what to do if the two audio streams are not the same duration: truncate the longer one or do not truncate it.
That would be really cool!I guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
And waht was tgat fix.ts file?
susanstone2022
strange. in my testing, thdmerge took longer than eac3to encoding.
Yes, I'd think so too. Thinking of this new option, any other track that's on the disc? For example, a commentary track you really like?RESET_9999 wrote: ↑Mon Mar 07, 2022 12:13 pmI guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
DolbyVisionFTW
You used to have a link listed in your signature to a file that would fix an issue during playback where the device would lock up.
thats what i thought but wasnt sure.DolbyVisionFTW wrote: ↑Mon Mar 07, 2022 5:36 pm
The file is still available in the DoVi test files link in my signature.
@chros, that file will unlock the oppo/x700 for when you play 2 DT-DL TS video in a row.
I couldnt make a 32kbps track and thdmerge would not process a 40kbps track but it seems to work at 64kbps. Hopefully, the track still play on my x800m2ArArdin wrote: ↑Mon Mar 07, 2022 5:29 pmYes, I'd think so too. Thinking of this new option, any other track that's on the disc? For example, a commentary track you really like?RESET_9999 wrote: ↑Mon Mar 07, 2022 12:13 pmI guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)
here's 4h of silent 5.1 AC3 audio at 64kbps.
https://drive.google.com/file/d/19n0b_0 ... sp=sharing
EDIT: it works on the x800m2 !!!!!
@RESET_9999
Now if I want to mux DV P8 .mkv file to DV P8 .mp4 file, what should I do?
I tried to add 2ch 32kbps AC3 with eac3to. No dice, got error.RESET_9999 wrote: ↑Mon Mar 07, 2022 8:10 pmI couldnt make a 32kbps track and thdmerge would not process a 40kbps track but it seems to work at 64kbps. Hopefully, the track still play on my x800m2
Good to know silent core is working on the Sony.
Thanks for the file
For us lazy people:
UsEac3To, GUI to eac3to, has added small GUI support for thdmerge with truncating option. THD and AC3 must have same name.
Read here: https://forum.doom9.org/showthread.php? ... ost1965348
