when i rip any bluray or 4k uhd first option of 5.1 in audio settings is always having distortion then i select 2nd 5.1 option it works fine. why so?
https://i.imgur.com/ZIdhDUW.jpg
UHD ripped audio distortion
Re: UHD ripped audio distortion
because your player or surround sound does not decode it right
i have pc windows 10 wih cyberlink powerdvd 21 ultra. what should i do and why 2nd option works fine then?Billycar11 wrote: ↑Thu Feb 17, 2022 10:54 ambecause your player or surround sound does not decode it right
Turn off the audio enhancement in cyberlink and set it to fully passthrough to your suround sound system that hopefully supports Atmos/true hd and dtsx/ dts ma.hardcore_gamer29 wrote: ↑Thu Feb 17, 2022 12:59 pmi have pc windows 10 wih cyberlink powerdvd 21 ultra. what should i do and why 2nd option works fine then?Billycar11 wrote: ↑Thu Feb 17, 2022 10:54 ambecause your player or surround sound does not decode it right
disabled all enhancement today in cyberlink still has distortionBillycar11 wrote: ↑Thu Feb 17, 2022 1:09 pmTurn off the audio enhancement in cyberlink and set it to fully passthrough to your suround sound system that hopefully supports Atmos/true hd and dtsx/ dts ma.hardcore_gamer29 wrote: ↑Thu Feb 17, 2022 12:59 pmi have pc windows 10 wih cyberlink powerdvd 21 ultra. what should i do and why 2nd option works fine then?Billycar11 wrote: ↑Thu Feb 17, 2022 10:54 ambecause your player or surround sound does not decode it right
It's something with your setup man I have no issues with sound sound formats it's not a makemkv issue what receiver do you havehardcore_gamer29 wrote: ↑Sun Feb 20, 2022 5:58 pmdisabled all enhancement today in cyberlink still has distortionBillycar11 wrote: ↑Thu Feb 17, 2022 1:09 pmTurn off the audio enhancement in cyberlink and set it to fully passthrough to your suround sound system that hopefully supports Atmos/true hd and dtsx/ dts ma.hardcore_gamer29 wrote: ↑Thu Feb 17, 2022 12:59 pm
can you help me with this as i today directly played through wh16ns60 there was no distortion in sound, it is only after rippingBillycar11 wrote: ↑Mon Feb 21, 2022 12:12 amIt's something with your setup man I have no issues with sound sound formats it's not a makemkv issue what receiver do you havehardcore_gamer29 wrote: ↑Sun Feb 20, 2022 5:58 pmdisabled all enhancement today in cyberlink still has distortionBillycar11 wrote: ↑Thu Feb 17, 2022 1:09 pm
If you use MediaInfo to look at your rips you'll probably see that one of the 5.1 sound tracks is one of the lossless formats Dolby TrueHD or DTS-MA or similar. Those audio tracks require a proper setup to correctly decode. The other sound track is probably the accompanying 'lossy core', which is a much more common Dolby Digital AC-3 or DTS. Those 'lossy core' tracks have been well supported in hardware and software for a long time.
As Billycar11 suggested, there's probably something in your playback setup that can't handle whatever lossless format is in use. MakeMKV makes a correct 1:1 copy of whatever is on the disc, so it is unlikely to be the cause of distortion.
there is a simple confusion that playing directly with disk , why there is no distortion?dcoke22 wrote: ↑Mon Mar 07, 2022 6:31 pmIf you use MediaInfo to look at your rips you'll probably see that one of the 5.1 sound tracks is one of the lossless formats Dolby TrueHD or DTS-MA or similar. Those audio tracks require a proper setup to correctly decode. The other sound track is probably the accompanying 'lossy core', which is a much more common Dolby Digital AC-3 or DTS. Those 'lossy core' tracks have been well supported in hardware and software for a long time.
