https://youtu.be/e_a77zJTrO4
read this: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
I tested this new tool and it worked very well and this is exactly the solution I was looking for the other day: a way to merge thd with ac3 without encoding the core in eac3to.ArArdin wrote: ↑Fri Mar 04, 2022 10:42 amFor those interested in DGDemux: The writer of the tool created a utility to merge the gap-processed demuxed, separate TrueHD and embedded AC3 tracks back together into TrueHD+AC3.
http://rationalqm.us/board/viewtopic.ph ... 406#p15406
@echo off
TITLE MKV THD to THD+AC3
:: this script demux MKV(THD_and_AC3) and merge THD with AC3
:: path to tools
set "output_path=D:\
set "thdmerge_path=D:\Dolby-Vision-Tools\tools\thdmerge.exe
set "mkvextract_path=D:\Dolby-Vision-Tools\tools\mkvextract.exe
color 2
:: drag and drop input file
set /p video_path=Drag and drop an MKV(THD_and_AC3) file and press enter...
cd C:\%UserInputPath%
:: demux
%mkvextract_path% %video_path% tracks 1:%output_path%1.thd tracks 2:%output_path%1.ac3
if NOT ["%errorlevel%"]==["0"] pause
:: merge thd ac3
%thdmerge_path% %output_path%1.thd %output_path%1.ac3 %output_path%thd+ac3.thd
del %output_path%1.thd
del %output_path%1.ac3
I've just installed my PC with windows 11 but still can't see D3D11 Native from your tool.RESET_9999 wrote: ↑Sun Mar 06, 2022 3:19 pm
the latest beta without time limitation: 113B or 114 if I recall correctly.
i dont know, works fine here.. are you sure lavfilters is set to native?
Please send to me link download your tool.RESET_9999 wrote: ↑Sun Mar 06, 2022 6:41 pm
Can you explain how you did this cast from phone?sickb wrote: ↑Sun Mar 06, 2022 11:12 pmMy latest report on the X800M2:
- Choppy playback issues seem to be resolved after stabilising my network (replaced switches and reserved an access point). Also I need to make sure there's nothing else gobbling up IO on the hard drives from which im playing movies, obviously.
- I still have it lock up sometimes, which means I need to do a hard reboot of the player
- Even for non disk content, it appears you need to manually change between dolby vision on and off for non-dolby vision content. my HDR content otherwise has raised blacks.
- Connected to my VRRoom switch/splitter, I sometimes need to switch ports back and forth because of otherwise black screen. but this is probably the VRRoom firmware.
- As I find the remote and the navigation in general sub-par, I repurposed a DLNA music cast plugin for Plex, to cast videos to the X800M2 directly from the plex app on phone and tablet, basically fixing my biggest usability concern.
I found a python project that supports casting plex music to DLNA servers, and repurposed it for my video needs.ragico wrote: ↑Sun Mar 06, 2022 11:22 pmCan you explain how you did this cast from phone?sickb wrote: ↑Sun Mar 06, 2022 11:12 pmMy latest report on the X800M2:
I've had an issue like that where I get the 'no signal' message on my TV when turning on the player. It was usually fixed by turning the TV off and on again. My player is connected directly to the (LG) TV so it's definitely not something that only happens with switches.
My setup is to use the Sony just for DV rips, and to use another box for HDR10 stuff and streaming (I use an Apple TV 4K, but I expect that any of the other good mainstream streaming boxes would work nicely since it seems to be a lot easier to get HDR10 playback right compared with DV).
Ah damn.. I bound the vrooms hot plug command to HomeKit and Siri, so I can recover without TV restart atm.FubbAyH wrote: ↑Mon Mar 07, 2022 1:19 amI've had an issue like that where I get the 'no signal' message on my TV when turning on the player. It was usually fixed by turning the TV off and on again. My player is connected directly to the (LG) TV so it's definitely not something that only happens with switches.
Me too, but no HD audio passthrough (Atmos). I also have a Shield pro but im trying to sell it to consolidate and also because of the various color issues even in non DV (if I got it right).FubbAyH wrote: ↑Mon Mar 07, 2022 1:19 amMy setup is to use the Sony just for DV rips, and to use another box for HDR10 stuff and streaming (I use an Apple TV 4K, but I expect that any of the other good mainstream streaming boxes would work nicely since it seems to be a lot easier to get HDR10 playback right compared with DV).
It's been great so far indeed. I'm testing it and up til now it has stood up to the promise. Yeah, it's a two way process but I don't mind as I usually do a lot of steps manually. Combined with DGDemux it's the perfect toolset for gap processed demuxing and remuxing with the native Dolby AC3 track. This guy makes great software.RESET_9999 wrote: ↑Sun Mar 06, 2022 5:53 pmI tested this new tool and it worked very well and this is exactly the solution I was looking for the other day: a way to merge thd with ac3 without encoding the core in eac3to.
Took about 3min for a 2h movie when eac3to usually takes more than 10minutes.(more if clipping detected).
Obviously, you have to demux the mkv first(and ac3 track must be present) but it still faster thanks to my NVME drive (+ most of the time i have to demux the hevc too anyway)
The fact that it can fix the gap from makemkv files is great as well.
I hope it plays well on the x800m2...
yes, it works, and no problem with the 10min I tested.
I guess we could encode a 4h silent ac3 core and use it for any movie (in case the mkv doesnt have an AC3 compatibility track)Glad you find it useful and thank you for your testing. I will release it formally with source code tomorrow. There will be an option to choose what to do if the two audio streams are not the same duration: truncate the longer one or do not truncate it.
