Albano
Post by Albano »
ArArdin wrote:
Sat Mar 05, 2022 11:31 pm
Albano wrote:
Sat Mar 05, 2022 9:42 pm
It's overlap in .sup file if I use MKVToolnik or DVDFab to create .mkv remux from BDMV.
Thanks for sharing. I doubt if a remux by those tools could cause such issues. Maybe the overlap would actually exist in the source PGS stream itself. If so, the disc would suffer from a major authoring issue.
However, it's not uncommon for a subtitle OCR process to misinterpret accumulative SUP images. Looking at your screenshot, I can imagine lines 37 and 38 being an example of faulty merging of several (on disc, well-authored) lines. Did you compare the actual PGS images at these timestamps?
Yes, I've compared PGS images at these timestamps of genuine Blu-ray disc and .mkv rip from MKVToolnix or DVDFab.
If rip from tsmuxer and convert to .mkv by MKVToolnix, this error will not exist.
jsc1979
Post by jsc1979 »
I’m looking at getting the Sony X800m2. Before I do I’d like to see if Dolby Vision Fel is worth it. Does anyone have a list of films where the Fel is a reasonable size?
Albano
Post by Albano »
@RESET_9999
Which madVR version is in your tool?
userr
Post by userr »
Can anyone tell me pls, is there a point in playing profile 7 dolby vision with enhancement layer if i have a Sony Player-LED TV? Can it display the additional details that comes with enhancement layer?
Albano wrote:
Sun Mar 06, 2022 2:24 pm
@RESET_9999
the latest beta without time limitation: 113B or 114 if I recall correctly.
userr wrote:
Sun Mar 06, 2022 3:01 pm
yes it can and why wouldnt it? ( as long as the player is sending the information to the TV)
The player-led bug is not related to the EL and it affects Dolby Vision without EL( profile 8 ) as well.
userr
Post by userr »
RESET_9999 wrote:
Sun Mar 06, 2022 3:19 pm
Thank you, i wasnt sure if it would thats why i asked.
What is the player-led bug? Havent been keeping up with DV in a while
From what i can gather from reading just the last pages, it seems Zidoo Z9X / Dune HD Real Vision 4K is the way to go for profile 7 mkv playback?
Or Sony x800m2 for mp4 i guess?
userr wrote:
Sun Mar 06, 2022 3:36 pm
https://youtu.be/e_a77zJTrO4
read this: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
FubbAyH
Post by FubbAyH »
jsc1979 wrote:
Sun Mar 06, 2022 12:31 pm
https://forum.blu-ray.com/showthread.php?t=276448
ArArdin wrote:
Fri Mar 04, 2022 10:42 am
For those interested in DGDemux: The writer of the tool created a utility to merge the gap-processed demuxed, separate TrueHD and embedded AC3 tracks back together into TrueHD+AC3.
http://rationalqm.us/board/viewtopic.ph ... 406#p15406
I tested this new tool and it worked very well and this is exactly the solution I was looking for the other day: a way to merge thd with ac3 without encoding the core in eac3to.
Took about 3min for a 2h movie when eac3to usually takes more than 10minutes.(more if clipping detected).
Obviously, you have to demux the mkv first(and ac3 track must be present) but it still faster thanks to my NVME drive (+ most of the time i have to demux the hevc too anyway)
The fact that it can fix the gap from makemkv files is great as well.
I hope it plays well on the x800m2...
@echo off
TITLE MKV THD to THD+AC3
:: this script demux MKV(THD_and_AC3) and merge THD with AC3
:: path to tools
set "output_path=D:\
set "thdmerge_path=D:\Dolby-Vision-Tools\tools\thdmerge.exe
set "mkvextract_path=D:\Dolby-Vision-Tools\tools\mkvextract.exe
color 2
:: drag and drop input file
set /p video_path=Drag and drop an MKV(THD_and_AC3) file and press enter...
cd C:\%UserInputPath%
:: demux
%mkvextract_path% %video_path% tracks 1:%output_path%1.thd tracks 2:%output_path%1.ac3
if NOT ["%errorlevel%"]==["0"]  pause
:: merge thd ac3
%thdmerge_path% %output_path%1.thd %output_path%1.ac3 %output_path%thd+ac3.thd
del %output_path%1.thd
del %output_path%1.ac3
Albano
Post by Albano »
I've just installed my PC with windows 11 but still can't see D3D11 Native from your tool.
Albano wrote:
Sun Mar 06, 2022 6:27 pm
i dont know, works fine here.. are you sure lavfilters is set to native?
Albano
Post by Albano »
RESET_9999 wrote:
Sun Mar 06, 2022 6:41 pm
Please send to me link download your tool.
gacopl
Post by gacopl »
Hi i have something to share
I am owner of LG CX and C8 models and also nvidia shield.
I made numerous conversions to make sure what is best, i found that for those LG models most reliable is mp4, m2ts is somewhat ok but for me had seeking issues at least with emby. I have found its best to convert to proper mp4 and keep Atmos and other tracks for safekeeping to be able to remux to mkv in future once at least nvidia shield plays correctly (it does not due to colors issues etc). I have found for best results is to play mp4 directly on Emby app on LG
I have created bash script that automates authoring and conversion of different Dolby Vision mkvs to mp4 that will work on above LG models without issues, so far i have converted around 30 releases no issues to the point i automated workflow
So my tool converts whatever mkv you throw at it to mp4 with DV4,5 or 8 with EAC3 audio and keeps original truehd atmos etc alongside for future, i have tested and remuxing with mkvtoolnix makes it playable with atmos again on nvidia shield no issues.
It automates ffmpeg dovi_tool and mp4box workflow and try to use as little drive space as possible thanks to linux pipes. I have it running on my NAS and is chugging along fine
https://github.com/gacopl/dvmkv2mp4
Take a look comment, or contribute :)
sickb
Post by sickb »
My latest report on the X800M2:
- Choppy playback issues seem to be resolved after stabilising my network (replaced switches and reserved an access point, disabled modern standby). Also I need to make sure there's nothing else gobbling up IO on the hard drives from which im playing movies, obviously.
- I still have it lock up sometimes after pause, stop, resume kind of situations, which means I need to do a hard reboot of the player
- Even for non disc content, it appears you need to manually change between dolby vision on and off for non-dolby vision content. my HDR content otherwise has raised black levels. I tried forcing color spaces, change my tv edid to LLDV or RGB (just to see if it somehow would treat HDR content better by miracle), but no.
- Connected to my VRRoom switch/splitter, I sometimes need to switch ports back and forth because of otherwise black screen. but this is probably the VRRoom firmware.
- As I find the remote (limited cec) and the navigation in general sub-par, I repurposed a DLNA music cast plugin for Plex, to cast videos to the X800M2 directly from the plex app on phone and tablet, basically fixing my biggest usability concern.
- Seeking via cast can drop dolby vision back to hdr, have to stop and start to get it back
Im a little sad about the manual DV switch, but I guess if it really bothers me I could buy a second unit and configure it with it off, then I just need to pick the right cast target based on HDR/DV :-)
My M9203 arrived but has weird artefacts and color issues so probably has to go back.
I also noticed the DV in TS problem where you have to view another test file (thanks RESET9999) to fix it.
So in the end, it's tradeoffs everywhere :D
ragico
Post by ragico »
sickb wrote:
Sun Mar 06, 2022 11:12 pm
- Choppy playback issues seem to be resolved after stabilising my network (replaced switches and reserved an access point). Also I need to make sure there's nothing else gobbling up IO on the hard drives from which im playing movies, obviously.
- I still have it lock up sometimes, which means I need to do a hard reboot of the player
- Even for non disk content, it appears you need to manually change between dolby vision on and off for non-dolby vision content. my HDR content otherwise has raised blacks.
- As I find the remote and the navigation in general sub-par, I repurposed a DLNA music cast plugin for Plex, to cast videos to the X800M2 directly from the plex app on phone and tablet, basically fixing my biggest usability concern.
Can you explain how you did this cast from phone?
