Read errors followed by "Backup Done"
rkjnsn
Post by rkjnsn » Sun Mar 06, 2022 7:15 am
Quick question:
If I see the following…
Backing up disc into folder "…"
Encountered 9 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done
Does that indicate any problem with the backup, or does "Backup done" mean the backup is good regardless of any preceding messages? (In other words, does "Backup done" imply that all mentioned read errors were successfully retried?)
Re: Read errors followed by "Backup Done"
Post by Billycar11 » Sun Mar 06, 2022 7:29 am
no its not good if it says that
it may or may not be playable.
rkjnsn
Post by rkjnsn » Tue Mar 08, 2022 4:36 am
Hmm… after further checking, it appears the rip is good.
After doing another rip on a different drive with no reported errors, I ended up with a result that was bit-for-bit identical to the first one, so it appears the 9 reported read errors were all successfully retried in this case (though surely it could have been more explicit about it). (I also verified there was no corruption in the m2ts streams.) Indeed, when there's an uncorrected error, MakeMKV seems to indicate the exact file with the error, e.g.,
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01082.m2ts' at offset '1794244608'
Failed to save title /BDMV/STREAM/01082.m2ts to file …/BDMV/STREAM/01082.m2ts
or
Hash check failed for file 01080.m2ts at offset 903014400, file is corrupt.
Hash check failed for file 01080.m2ts at offset 903211008, file is corrupt.
Hash check failed for file 01080.m2ts at offset 907339776, file is corrupt.
Hash check failed for file 01080.m2ts at offset 907536384, file is corrupt.
Hash check failed for file 01080.m2ts at offset 907929600, file is corrupt.
Too many hash check errors in file 01080.m2ts.
Hash check for /BDMV/STREAM/01080.m2ts : 0.45% corrupt, 99.54% correct, 99.99% checked.
followed by
Backup done but 2 files failed hash check
instead of just "Backup done".
