Arrow’s latest Limited Edition UK UHD release of the film Phenomena:
https://www.arrowfilms.com/blu-ray/phen ... 83734.html?
rctxt=default
Both discs result in:
DEBUG: Code 0 at q)3*^k0QW2*w%}_6:29396092
DEBUG: Code 0 at q)3*^k0QW2*w%}_6:29395172
TGZ dump has been emailed.
Thanks in advance.
Volume Key Unknown for Arrow's UHD Phenomena
Re: Volume Key Unknown for Arrow's UHD Phenomena
Contrary to my initial assumptions, the second disc appears to be envrypted differently. While it is now possible to rip the first disc, the second disccannot still be decryped.
Disc Information
Label: PHENOMENA UHD2
Timestamp: 2021-12-22 22:30:06
Protection: AACS2.0/C v76
Data capacity: 92.31 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:29396092
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:29395172
I've therefore attached the associated AAC dump TGZ file in the hope of this being looked at:
Disc Information
Number of layers: 3
- MKB20_v76_PHENOMENA_Disc_2_-_4K_UHD_B04C.tgz
- (3.36 MiB) Downloaded 297 times
You really need to email the dump to svq@makemkv.com. Just posting it to the forum means it is unlikely to get processed, since the program's author doesn't check the forums for such things.
Fixing Volume Key is Unknown
dcoke22 wrote: ↑Fri Mar 04, 2022 4:32 pmYou really need to email the dump to svq@makemkv.com. Just posting it to the forum means it is unlikely to get processed, since the program's author doesn't check the forums for such things.
Yeah, thanks for that, but I already done so.
For clarity. it should also be said that both discs can now be accessed and ripped.
