Volume Key Unknown for Arrow's UHD Phenomena
dante01
Post by dante01 »
Arrow’s latest Limited Edition UK UHD release of the film Phenomena:
https://www.arrowfilms.com/blu-ray/phen ... 83734.html?
rctxt=default
Both discs result in:
DEBUG: Code 0 at q)3*^k0QW2*w%}_6:29396092
DEBUG: Code 0 at q)3*^k0QW2*w%}_6:29395172
TGZ dump has been emailed.
Thanks in advance.
dante01
Re: Volume Key Unknown for Arrow's UHD Phenomena
Post by dante01 »
Contrary to my initial assumptions, the second disc appears to be envrypted differently. While it is now possible to rip the first disc, the second disccannot still be decryped.
Disc Information
Label: PHENOMENA UHD2
Timestamp: 2021-12-22 22:30:06
Protection: AACS2.0/C v76
Data capacity: 92.31 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:29396092
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:29395172
I've therefore attached the associated AAC dump TGZ file in the hope of this being looked at:
MKB20_v76_PHENOMENA_Disc_2_-_4K_UHD_B04C.tgz
(3.36 MiB) Downloaded 338 times
dante01 wrote: Fri Mar 04, 2022 10:59 am I've therefore attached the associated AAC dump TGZ file in the hope of this being looked at:
You really need to email the dump to svq@makemkv.com. Just posting it to the forum means it is unlikely to get processed, since the program's author doesn't check the forums for such things.
Fixing Volume Key is Unknown
dante01
Post by dante01 »
dcoke22 wrote: Fri Mar 04, 2022 4:32 pm
Yeah, thanks for that, but I already done so.
dante01
Post by dante01 »
For clarity. it should also be said that both discs can now be accessed and ripped.
