LG Slim DVD /BluRay writer (BD-RE BP50NB40)
Dal1980
#1 Post by Dal1980 » Sat Mar 05, 2022 6:19 pm
Hi guys
I asked in another post on general for recommendations in buying a new drive because this one isn't behaving itself. I found that the error was talked about quite recently as being a bug (I might be jumping to conclusions so hence this post).
OS device name: E:
Product: BD-RE BP50NB40
Revision: 1.01
Serial number: SIKZ9HCP21526
Firmware date: 2117-11-23 16:15
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.01
My drive will disconnect (windows 10 usb disconnect sound) and make will just lock out as if there was no drive. I get a load of errors before the disc gives up too and I've even used known working discs to confirm that the problem shouldn't be with the disc itself. I'm not sure exactly what is wrong or how to help my situation.
Debug log started at Sat Mar 05 17:41:05 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\ZB/MakeMKV_log.txt
001003:0020 DEBUG: Code 1 at TNhXYRSK*#o#1_6WTix<hTRz:121261704
001003:0020 DEBUG: Code 3221225486 at TNhXYRSK*#o#1_6WTix<hTRz:121261727
001003:0020 DEBUG: Code 3221225486 at *e|66T8YQ=^#{a@T3lPj:213130582
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF  v087: HL-DT-ST_BD-RE_BP50NB40_1.01_211711231615_SIKZ9HCP21526
DEBUG: Code 2317353419 at (!n|5-#1Tvs?#]\g.:213132974
DEBUG: Code 0 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 1 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 2 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 3 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 4 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 5 at (!n|5-#1Tvs?#]\g.:121264786
DEBUG: Code 2317353419 at (!n|5-#1Tvs?#]\g.:121264648
DEBUG: Code 0 at jy`8q}68o"jrtS*\:29401934
001003:0020 DEBUG: Code 101067008 at jy`8q}68o"jrtS*\:29403291
001003:0020 DEBUG: Code 101067008 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 100795393 at jy`8q}68o"jrtS*\:29403291
001003:0020 DEBUG: Code 100795393 at %L!0Ld/*I;&9zs;':213130559
001003:0020 DEBUG: Code 100795393 at 3s}V)Ev#h<NJZ{[r)E:29395195
001003:0020 DEBUG: Code 100795393 at 3s}V)Ev#h<NJZ{[r)E:29393792
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '655360'
001012:0000 udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '32768'
001003:0020 DEBUG: Code 0 at Hlyjh_f7m#e8"=b&0jk:213129777
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '65536'
001012:0000 udf: UDF mount: reading in reserve VDS extent
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '36048928768'
001012:0000 udf: UDF mount: error reading volume space
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '131072'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '133120'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '135168'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '137216'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '139264'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '141312'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '143360'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '145408'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '147456'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '149504'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '151552'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '153600'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '155648'
Replaced disc with known working disc (bluray)
Debug log started at Sat Mar 05 18:10:45 2022 , written by MakeMKV v1.16.7 win(x64-release)
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '1245184'
001012:0000 udf: 	node fe/efe failed!
001003:0020 DEBUG: Code 0 at o_Xa1f//iCn}@`Kn-:121262992
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '2555904'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '2605056'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '720896'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '2228224'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '1835008'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.01 SIKZ9HCP21526' at offset '1847296'
OS device name: E:
Revision: 1.01
Disc Information
Label: Ghostbusters II
Timestamp: 2014-08-01 12:30:50
Protection: AACS
Data capacity: 34.63 Gb
Disc type: BD-ROM
Number of layers: 2
001003:0020 DEBUG: Code 3221225664 at jy`8q}68o"jrtS*\:121267362
If I close makemkv and disconnect and reconnect the drive (USB) and open makemkv back up
Debug logging enabled, log will be saved as C:\Users\ZB/MakeMKV_log.txt
DEBUG: Code 0 at TNhXYRSK*#o#1_6WTix<hTRz:121261704
The program can't find any usable optical drives.
and again
Debug log started at Sat Mar 05 18:15:08 2022 , written by MakeMKV v1.16.7 win(x64-release)
... more but 60000 character limit on forum post
Not sure if any of this is helpful
Dal1980
Re: LG Slim DVD /BluRay writer (BD-RE BP50NB40)
#2 Post by Dal1980 » Sat Mar 05, 2022 6:25 pm
weirdly changing the usb ports corrected this issue and I was able to read Ghostbusters II. I then put my original problematic disc in and was able to read that now.
Baring in mind that this problem just seems to move around because I already changed my USB ports to fix this problem but I'd gone from original ports to new ports and had no difference but upon returning to the original ports it worked again. This time, I've changed over and the new ports have worked this time without needing to switch back if that is explained well.
Title #00171.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00102.mpls was added as title #0
Title #00186.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00210.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00213.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00217.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #1
File 00003.mpls was added as title #2
Title #00004.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00019.mpls was added as title #3
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00099.m2ts was added as title #4
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #5
Title #00003.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #6
Title #00013.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #7
File 00015.m2ts was added as title #8
#3 Post by dcoke22 » Sat Mar 05, 2022 6:28 pm
That sorta seems like the drive is running out of power. Does the drive connect via a USB Y cable? It needs both those cables connected to high powered USB ports to have enough power. MakeMKV can spin a drive fast enough that the power requirements can exceed what a single port or two low powered ports can provide. When it does so, the drive will momentarily shut down and disappear from your computer.
Dal1980
#4 Post by Dal1980 » Sat Mar 05, 2022 6:40 pm
Yeah it has a Y cable which is why I mentioned USB Ports
I always have to use the original cable and always have both plugged in.
The problem seems to not be any specific port or ports as I mentioned that I got it working a couple of hours ago by moving from using USB 1 + 2 to then plugging them into USB 3 + 4 to see the same error and moving them back to USB 1 + 2 again for the drive to suddenly read the disc. This time around I moved USB 1 + 2 to USB 3 + 4 for the disc to be successfully read
I felt like my original post was asking a dumb question for providing a recommendation on a replacement drive but after trying to dig deeper I found other people that had the same errors and something about it being a known bug
What I mean is I haven't got a clue what the problem is, what a good drive to buy as a replacement would be and if this is related to some software bug, manufacturer driver issue, windows issue or if the colour of my wall is affecting the performance of the spin rate :lol:
Dal1980
#5 Post by Dal1980 » Sat Mar 05, 2022 7:00 pm
May just be the drive dying.
I've had a response on my other post asking about replacement drives which would be the better route to go down as this drive has done more miles than my car :P
viewtopic.php?f=1&t=27596
Thanks for the response.
risaaco49
#6 Post by risaaco49 » Sun Mar 06, 2022 8:08 pm
I encountered the same error with my drive. Following this to see if swapping ports is what I need to do. I've done countless DVDs and Blu-rays with no issue whatsoever, and now I'm getting the same errors described in this thread. However, my BD-RE BP50NB40 has LibreDrive enabled (as of yesterday). I thought it would help, but not so much. Anyway I shall continue to debug. Drive info below.
OS device name: E:
Revision: 1.03
Serial number: SIM03J17E3213
Firmware version: 1.03
OldSkool
#7 Post by OldSkool » Sun May 29, 2022 10:05 am
Hi guys,
I also get the exact same error message:
Can someone explain this error message and offer a solution?
I use USB 2.0 A/SATA, IDE Adapter with separate power supply 220 V / 230 V and a Samsung TSSTcorp DVDWBD SH-B123L internal drive.
Manufacturer: TSSTcorp
Product: DVDWBD SH-B123L
Revision: SB04
Serial number: R8496GGB400536
Drive platform: MT1939
Firmware version: 03.31
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
