Post by RESET_9999 » Fri Mar 04, 2022 5:13 pm
thanks @ArArdin
Albano
Post by Albano » Sat Mar 05, 2022 1:07 pm
@RESET_9999
I run your tool on Windows 10 LTSC 2019, is this D3D11 native?
Post by RESET_9999 » Sat Mar 05, 2022 2:20 pm
@RESET_9999
no, otherwise it would say "native"...
BTW, I'm working on a huge script that will automate all the possible workflows. Almost no editing and "drag & drop" input file support too.
Albano
Post by Albano » Sat Mar 05, 2022 2:42 pm
@RESET_9999
To avoid subtitle time difference, I use tsmuxer to extract the main file of the movie with Dolby Vision. But when I use MKVToolnix to convert from .m2ts to .mkv, the MediaInfo of .mkv file notice there is only 1 video, not 2 videos in the .m2ts file. Why is that?
Arkz147
Post by Arkz147 » Sat Mar 05, 2022 2:46 pm
If I may : what is the best choice, between Zidoo Z9X and Dune HD Real Vision 4K, for playing DV using Kodi and Fen/Seren/Venom (or a Kodi-like app) ?
By playing DV, I mean MKV/MP4, and more profiles supported than by my Shield Pro (Remux-friendly, and without messed up colors).
Thanks for any help.
Post by RESET_9999 » Sat Mar 05, 2022 2:48 pm
no idea... I didnt know this movie bluray has DV ?
jayper
Post by jayper » Sat Mar 05, 2022 3:09 pm
There was a steelbook released in France: https://www.blu-ray.com/movies/Iron-Man ... ay/275647/
As well as a version released in Japan: https://www.blu-ray.com/movies/Iron-Man ... ay/277294/
staknhalo
Post by staknhalo » Sat Mar 05, 2022 3:31 pm
Yes Iron Man and Incredible Hulk have French exclusive DV FEL UHDs
I have the Iron Man release too, just not Hulk (yet)
I had no problems demuxing/working with my Iron Man UHD
Demux from UHD with tsmuxer, combine streams with yeuscopes tool, put into mkv with mkvtoolnix
Albano
Post by Albano » Sat Mar 05, 2022 3:53 pm
Post by RESET_9999 » Sat Mar 05, 2022 4:24 pm
thanks for that picture, I know that xtreme french website, it told me exactly where to find Iron man and Hulk in FEL DV lol :D
will test in a few minutes
ArArdin
Post by ArArdin » Sat Mar 05, 2022 8:19 pm
It looks like you forgot to select the 2nd video in mkvtoolnix.
May I ask what this subtitle time difference is? Is this why you use mkvtoolnix as intermediate?
Albano
Post by Albano » Sat Mar 05, 2022 9:42 pm
It's overlap in .sup file if I use MKVToolnik or DVDFab to create .mkv remux from BDMV.
If there is a overlap of the original subtitles, the Vietnamese subtitles that I need to sync will also be wrong.
ArArdin
Post by ArArdin » Sat Mar 05, 2022 11:31 pm
Thanks for sharing. I doubt if a remux by those tools could cause such issues. Maybe the overlap would actually exist in the source PGS stream itself. If so, the disc would suffer from a major authoring issue.
However, it's not uncommon for a subtitle OCR process to misinterpret accumulative SUP images. Looking at your screenshot, I can imagine lines 37 and 38 being an example of faulty merging of several (on disc, well-authored) lines. Did you compare the actual PGS images at these timestamps?
ginandbacon
Post by ginandbacon » Sat Mar 05, 2022 11:34 pm
I had the same issue and went with the Dune based on user feedback. Seems like they are better at firmware/software updates then Zidoo. With that said, I have not seen or used the Zidoo. I have confirmed that the Dune HD Real Vision 4k Solo plays both DV 7 profiles. You are going to want to use the built in player no matter which one you go with. Due to either licensing or content providers not allowing it, they are limited to at best, 4K no HDR and Prime video is actually 480p. There is some weird licensing with content providers or they get to choose who gets 4kHDR with streaming services. The Dune is hands down the best media player I have ever used. The fact that it does resolution and framerate changes with no HDMI drop outs is a huge plus. The built in player is all you need really. It does come with a YouTube variant that can actually play HDR. In fact yesterday I was watching something and it came us as HLG. Bohemian Rhapsody, one of the few HDR10+ movies available looked and sounded amazing. It's not for Netflix, Hula, Dis+, ect... The Android in both is crippled by resolution limitations. I only use my Shield now for streaming services. It plays DV profile 4, 6, 7 *MEL and FEL, and 8. Most remux's use 8. HDR10+ (shield doesn't support), HDR10, and HLG. I can't confirm profile 4 due to my setup and it being STD (display does tone mapping, not LLDV). The one thing you will notice right away is no judder, especially compared with the Shield. I had issues with Judder on some content on the Shield. Being able to send out 12b LLDV for SDR content helps with banding and it properly remaps the color tones for pretty much any scenario. While still in Beta, the new GUI is a huge improvement http://dune-hd.com/firmware/newgui/
Albano
Post by Albano » Sun Mar 06, 2022 11:45 am
Yes, I've compared PGS images at these timestamps of genuine Blu-ray disc and .mkv rip from MKVToolnix or DVDFab.
If rip from tsmuxer and convert to .mkv by MKVToolnix, this error will not exist.
