jkatchy2
Post by jkatchy2 » Tue Mar 01, 2022 12:46 am
RESET_9999 wrote: Tue Feb 22, 2022 4:42 am instead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
If you want to add anything, let me know.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Have Sony X800m2 - tried to paly m2ts - Profile 8 DV with Lossless Atmos (muxed with 27th Feb tsmuxer nightly build which have atmos addition ) - No Audio playback on TRUEHD track but same file track 2 audio AC3 played fine . No issues with DV video with Track 2 selected and also no issues with BDMV folder files with DTDL Profile 7 + Truehd . Am I missing Something ? file played via Wireless Network from NAS .
Post by RESET_9999 » Tue Mar 01, 2022 1:14 am
jkatchy2 wrote: Tue Mar 01, 2022 12:46 am Have Sony X800m2 - tried to paly m2ts - Profile 8 DV with Lossless Atmos (muxed with 27th Feb tsmuxer nightly build which have atmos addition ) - No Audio playback on TRUEHD track but same file track 2 audio AC3 played fine . No issues with DV video with Track 2 selected and also no issues with BDMV folder files with DTDL Profile 7 + Truehd . Am I missing Something ? file played via Wireless Network from NAS .
Sounds like the TrueHD core is missing. Did you remux from a MKV ? if yes, then you have to add the ac3 core back into TrueHD.
https://www.videohelp.com/software/eac3to
ArArdin
Post by ArArdin » Tue Mar 01, 2022 2:48 am
jkatchy2 wrote: Tue Mar 01, 2022 12:46 am...muxed with 27th Feb tsmuxer nightly build which have atmos addition
Note that tsMuxer has always supported and muxed Atmos. This "atmos addition" means no more than tsMuxer will now show TrueHD + Atmos in the track-info list. Where it earlier was described as TrueHD.
jkatchy2
Post by jkatchy2 » Tue Mar 01, 2022 5:13 am
ArArdin wrote: Tue Mar 01, 2022 2:48 am
RESET_9999 wrote: Tue Mar 01, 2022 1:14 am
Got it ! muxed with ac3 core, now it plays fine . Thanks for the inputs .
Albano
Post by Albano » Wed Mar 02, 2022 6:54 am
@RESET_9999
I saw DetectBorders in your files, I tried running the batch file "Detect.BORDERS" but it doesn't work.
What is DetectBorders?
What is it used for?
How to use?
Post by RESET_9999 » Wed Mar 02, 2022 12:12 pm
Albano wrote: Wed Mar 02, 2022 6:54 am @RESET_9999
How to use?
it detects black bars and write the data in a text file (D:\borders.measurements.txt). Not sure if it's perfectly accurate though. It may be better to measure manually, I didnt really test the tool.
DetectBorders.exe --ffmpeg-path="D:\Dolby-Vision-Tools\tools\ffmpeg.exe" --input-file="D:\hdr.mkv" --log-file="D:\borders.measurements.txt"
ArArdin
Post by ArArdin » Fri Mar 04, 2022 10:42 am
For those interested in DGDemux: The writer of the tool created a utility to merge the gap-processed demuxed, separate TrueHD and embedded AC3 tracks back together into TrueHD+AC3.
http://rationalqm.us/board/viewtopic.ph ... 406#p15406
Post by RESET_9999 » Fri Mar 04, 2022 5:13 pm
thanks @ArArdin
Albano
Post by Albano » Sat Mar 05, 2022 1:07 pm
@RESET_9999
I run your tool on Windows 10 LTSC 2019, is this D3D11 native?
Post by RESET_9999 » Sat Mar 05, 2022 2:20 pm
Albano wrote: Sat Mar 05, 2022 1:07 pm @RESET_9999
no, otherwise it would say "native"...
BTW, I'm working on a huge script that will automate all the possible workflows. Almost no editing and "drag & drop" input file support too.
Albano
Post by Albano » Sat Mar 05, 2022 2:42 pm
@RESET_9999
To avoid subtitle time difference, I use tsmuxer to extract the main file of the movie with Dolby Vision. But when I use MKVToolnix to convert from .m2ts to .mkv, the MediaInfo of .mkv file notice there is only 1 video, not 2 videos in the .m2ts file. Why is that?
Arkz147
Post by Arkz147 » Sat Mar 05, 2022 2:46 pm
If I may : what is the best choice, between Zidoo Z9X and Dune HD Real Vision 4K, for playing DV using Kodi and Fen/Seren/Venom (or a Kodi-like app) ?
By playing DV, I mean MKV/MP4, and more profiles supported than by my Shield Pro (Remux-friendly, and without messed up colors).
Thanks for any help.
Post by RESET_9999 » Sat Mar 05, 2022 2:48 pm
no idea... I didnt know this movie bluray has DV ?
jayper
Post by jayper » Sat Mar 05, 2022 3:09 pm
RESET_9999 wrote: Sat Mar 05, 2022 2:48 pm no idea... I didnt know this movie bluray has DV ?
There was a steelbook released in France: https://www.blu-ray.com/movies/Iron-Man ... ay/275647/
As well as a version released in Japan: https://www.blu-ray.com/movies/Iron-Man ... ay/277294/
staknhalo
Post by staknhalo » Sat Mar 05, 2022 3:31 pm
Yes Iron Man and Incredible Hulk have French exclusive DV FEL UHDs
I have the Iron Man release too, just not Hulk (yet)
I had no problems demuxing/working with my Iron Man UHD
Demux from UHD with tsmuxer, combine streams with yeuscopes tool, put into mkv with mkvtoolnix
