Duplicate Files
DukeD
Duplicate Files
Post by DukeD »
The last couple BR disks I have used MKV on have yielded ,among smaller files, 2 large files which are exactly the same size and neither will play. Is this a new type of "protection" ? Any remedies? Thanks!
Ezatoka
Re: Duplicate Files
Post by Ezatoka »
What do you define as large?
And which files are they? from the streams folder (aka m2ts files) or from somewhere else?
Are these files duplicated on a full backup or after you created MKV files from the BluRay?
DukeD
Re: Duplicate Files
Post by DukeD »
Sorry didn't realize it was so vague...... anyway..... duplicate large files after using MKV on the disk.... large is 32 / 34 GB. Various other files that you usually see when using MKV, things like interviews, etc... ancillary files. But 2 LARGE files which appear to be the main, movie file.
Ezatoka
Re: Duplicate Files
Post by Ezatoka »
More often I see the main movie having two playlists whereas the second playlist only has the original language (e.g. English) and one foreign language, usually Japanese.
Though that you can't play them is strange. What does MediaInfo tell about these files?
DukeD
Re: Duplicate Files
Post by DukeD »
Thanks for your time with this. Wish I had the error message in front of me but it is the usual listing of what it has done and then it says something like "error" 0 files saved. Yet there is a file, but it won't play. So strange.
Ezatoka
Re: Duplicate Files
Post by Ezatoka »
I'm afraid the best thing would be to have the MakeMKV log (with Log debug messages enabled in the Preferences -> General).
So to make fully sure you would need to rip it again and copy the whole log here.
DukeD
Re: Duplicate Files
Post by DukeD »
Will do. Appreciate it.
DukeD
Re: Duplicate Files
Post by DukeD »
Took screenshot but unsure how to attach it on this forum. Any advise?
DukeD
Re: Duplicate Files
Post by DukeD »
Here is the log when I ran through MKV
"MakeMKV v1.16.7 win(x64-release) started
File 00001.mpls was added as title #0
File 00000.mpls was added as title #1
Title #00338.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00334.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00333.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00332.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00331.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00329.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00327.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00326.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00342.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00302.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00319.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00320.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00384.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00340.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00102.m2ts was added as title #2
Title #00132.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00328.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00343.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00325.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00106.m2ts was added as title #3
File 00105.m2ts was added as title #4
File 00104.m2ts was added as title #5
File 00103.m2ts was added as title #6
Title #00318.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00101.m2ts was added as title #7
Saving 1 titles into directory C:/Users/Duke/Desktop/MKV
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '7690647552'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7690647552'
Failed to save title 0 to file C:/Users/Duke/Desktop/MKV/Some Like It Hot_t00.mkv
Encountered 22 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Operation successfully completed"
Ended up with two 39.1 GB files and a few ancillary ones
Ran one of the 39.1 GB files on Handbrake but it could not read it.
Your Thoughts?
Re: Duplicate Files
That means the optical drive was unable to correctly read the disc. Blu-ray players will generally plow ahead when there are read failures and hope you don't notice a tiny messed up bit of the movie. MakeMKV, on the other hand, will not skip over read failures; it is trying to make an exact, correct copy of the disc. The short answer is try gently cleaning the disc and/or try a different optical drive.
If you're experiencing rip errors, please read here first!
Re: Duplicate Files
DukeD wrote: Sat Mar 05, 2022 1:34 pm Took screenshot but unsure how to attach it on this forum. Any advise?
Make your screenshot reasonably small and add it as an attachment to your post. There's an attachments tab on the posting screen.
DukeD
Re: Duplicate Files
Post by DukeD »
DCoke22 thanks so much for your time on this. Appreciate your help.
