Marvel's Eternals (2021)
Re: Marvel's Eternals (2021)
#16 Post by dcoke22 » Tue Mar 01, 2022 6:14 pm
Monte wrote:
Tue Mar 01, 2022 4:49 pm
Where is the update for the message: "Automatic HK downloading is disabled or failed" being pulled from. I am certain it's being blocked but can't find where.
Just need the IP or what it resolves to.
Monte
Fixing Volume Key is Unknown
Monte
#17 Post by Monte » Tue Mar 01, 2022 7:01 pm
Monte
Thank you, I did read the entire thread (again). Do you know the IP address? If this truly resolves to Russia, the geo is blocked but I can request an IP or resolved name.
Monte
#18 Post by dcoke22 » Tue Mar 01, 2022 10:32 pm
There's this thread from a few days ago: viewtopic.php?f=1&t=27481
That sticky link from my last post should eventually be updated with whatever the new 'right' answer becomes. For whatever it is worth, for me at the moment a nslookup on that URL resolves to the original IP as mentioned in that thread.
KiltedShane
#19 Post by KiltedShane » Tue Mar 15, 2022 12:50 am
hartman9 wrote:
Tue Mar 01, 2022 1:03 am
Ok I will give it a go. Any easy way to tell if it's correct without watching the whole movie? For the record here are the four files and maps that I extracted.
MARVEL STUDIOS' ETERNALS - BLU-RAY_t03 (00800 - 946,947,948,949,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t04 (00801 - 946,954,948,949,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t05 (00802 - 946,955,948,953,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t06 (00803 - 946,956,948,949,950).mkv
On my rip, the 802 and 803 have the opening crawl in French and Spanish respectivly.
lfoust
#20 Post by lfoust » Fri May 13, 2022 5:49 am
Here is how the US 4K Blu-ray was layed out for me: https://thediscdb.com/movie/eternals-20 ... es/2022-4k
wazupq97
#21 Post by wazupq97 » Thu Dec 01, 2022 4:50 am
What do I have to uncheck to remove the constant english subtitles that are in the movie not just when their talking in another language or in sign language im using the 00800 any help is greatly appreciated
matrixprime
#22 Post by matrixprime » Wed Dec 20, 2023 10:12 pm
Hi all,
Been some time since I've posted but I'm trying to figure out why my LG drive won't rip certain UHD content. Case in point I cannot get Eternals to rip. Here's my log, if someone could point me in the right direction that would be great!
Hash check failed for file 00057.m2ts at offset 26035218432, file is corrupt.
Hash check failed for file 00057.m2ts at offset 26091055104, file is corrupt.
The source file '/BDMV/STREAM/00057.m2ts' is corrupt or invalid at offset 26411655168, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00057.m2ts' (title #-) , future messages will be printed only to log file
Failed to save title 4 to file C:/Users/aaron/OneDrive/Desktop/MakeMKV Output/MARVEL STUDIOS' ETERNALS - ULTRA HD_t04.mkv
Encountered 23 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
#23 Post by SamuriHL » Wed Dec 20, 2023 10:42 pm
Buy a Pioneer. I know that seems like I'm being sarcastic but I'm not. The LG drives really do suck in comparison. Especially on larger discs. The only advice I have for you on the LG is clean the disc and if that doesn't work replace the drive or disc.
matrixprime
#24 Post by matrixprime » Sat Dec 23, 2023 9:41 pm
Thanks for the tip. Since it's intermittent across 4k UHD you may be on to something. Is there a specific Pioneer that is recommended?
#25 Post by MartyMcNuts » Sat Dec 23, 2023 10:17 pm
Check with a drive seller from this forum located in/near your part of the world.
#26 Post by SamuriHL » Sat Dec 23, 2023 10:29 pm
Exactly what Marty said.
