Just some clarification on my drives
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 12:05 am
I have two drives:
Product: BDDVDRW UH12NS40
Revision: 1.01
And
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
From these old stock firmware revisions, are there any special steps needed for flashing? Or can I just go straight to the latest MK firmware in the ZIP?
Re: Just some clarification on my drives
Post by Billycar11 » Tue Mar 01, 2022 1:10 am
need more info then that post the makemkv info the asus might already not need to be flashed it if is on the correct 3.02
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 1:56 am
What additional information is needed, and what would be the best way to get it? It's never been flashed, and the firmware date is
"Firmware date: 2117-11-15 17:16"
So I guess its a time-traveling drive.
Since you said it may not need to be flashed, I tried my Sherlock Holmes 4K and MakeMKV reports "no disc".
Post by dcoke22 » Tue Mar 01, 2022 6:11 am
jcdick1 wrote: Tue Mar 01, 2022 1:56 am What additional information is needed, and what would be the best way to get it? It's never been flashed, and the firmware date is
Load MakeMKV and post the Drive Information & LibreDrive Information sections from the Info box on the right. For example, below is the relevant data from my ASUS BW-16D1HT.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Post by MartyMcNuts » Tue Mar 01, 2022 6:30 am
Post the complete right side pane.
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 4:11 pm
UH12NS40:
Revision: 1.01
Serial number: SIK9HG76F263
Firmware date: 2117-11-23 15:50
Bus encryption flags: 16
Harware support: Yes
Firmware support: No
Firmware version: 1.01
ASUS BW-16D1HT:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: K9NI1QI1748
Post by Billycar11 » Tue Mar 01, 2022 11:41 pm
jcdick1 wrote: Tue Mar 01, 2022 4:11 pm UH12NS40:
Revision: 1.01
ASUS BW-16D1HT:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Both need to be flashed and can do uhd for the Asus just follow the guide for the LG just flash it to the latest mk for it.
