I just tried ripping the Parks and Recreation bluray discs, and got an error message about the disc using a newer version of AACS protection and the decryption key being unknown. This came out maybe six months ago, so finding out that MakeMKV doesn't have the keys for the disc was a surprise. There are also a LOT of discs—it's a seven-season show. Am I going to have to send MakeMKV a new "AACS dump file" for each disc?
Thanks for your help!
Parks and Rec - Missing keys?
Re: Parks and Rec - Missing keys?
What version of MakeMKV? Do you have a LibreDrive-capable drive?
Mmuiwdcwnc
I'm on MakeMKV 1.16.5 on an M1 Mac. My BD drive's LibreDrive status is "Possible (with patched firmware)."
I found a forum post last night on how to flash LibreDrive firmware on a Mac, so I assume doing that is my next step, but it's definitely more Terminal work than I've done in a long, long time. (I used Terminal to flash a new ROM on an Android phone several years ago, but I found really hand-hold-y directions.)
this only is needed if the discs are UHD are they?Mmuiwdcwnc wrote: ↑Sat Feb 26, 2022 2:35 amI'm on MakeMKV 1.16.5 on an M1 Mac. My BD drive's LibreDrive status is "Possible (with patched firmware)."
Auto flash kit $40 Email me for one Billycar5924@gmail.com
Mmuiwdcwnc
They are not UHD. Thanks for the tip. I thought the error I was getting ripping might be because of the note MakeMKV was giving me about AACS versions, and that LibreDrive would let me bypass the AACS issues. Any other tips?
Nope if it's a new aacs you will just have to wait untill makemkv supports it but also you drive may not be able to rip any discsMmuiwdcwnc wrote: ↑Sat Feb 26, 2022 4:14 pmThey are not UHD. Thanks for the tip. I thought the error I was getting ripping might be because of the note MakeMKV was giving me about AACS versions, and that LibreDrive would let me bypass the AACS issues. Any other tips?
Mmuiwdcwnc
I've ripped a couple hundred BDs on this drive so far. Are you saying that now that I've tried to read a disc with a newer AACS, my drive might not rip anything anymore?
If your drive still hasn't been flashed, you are limited by the drive's revocation table, which is updated when you insert a disk. That's what AACS does as the drive level - once a AACS key is revoked, it's revoked for ALL Bluray content. MakeMKV needs to get a new key when that happens.
LibreDrive puts the drive into a mode that doesn't care about things like revocation tables.
Mmuiwdcwnc
Update: I flashed the LibreDrive firmware for my drive (LG BD-RE WP50NB40) and the discs are reading/ripping great so far. I'm guessing, though, that just because my drive was LibreDrive compatible doesn't mean it's also UHD compatible, right?
yes and no you would need to go to bp60nb10Mmuiwdcwnc wrote: ↑Tue Mar 01, 2022 2:11 amUpdate: I flashed the LibreDrive firmware for my drive (LG BD-RE WP50NB40) and the discs are reading/ripping great so far. I'm guessing, though, that just because my drive was LibreDrive compatible doesn't mean it's also UHD compatible, right?
see guide linked below
