Just some clarification on my drives
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 12:05 am
I have two drives:
Product: BDDVDRW UH12NS40
Revision: 1.01
And
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
From these old stock firmware revisions, are there any special steps needed for flashing? Or can I just go straight to the latest MK firmware in the ZIP?
Re: Just some clarification on my drives
Post by Billycar11 » Tue Mar 01, 2022 1:10 am
need more info then that post the makemkv info the asus might already not need to be flashed it if is on the correct 3.02
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 1:56 am
What additional information is needed, and what would be the best way to get it? It's never been flashed, and the firmware date is
"Firmware date: 2117-11-15 17:16"
So I guess its a time-traveling drive.
Since you said it may not need to be flashed, I tried my Sherlock Holmes 4K and MakeMKV reports "no disc".
Post by dcoke22 » Tue Mar 01, 2022 6:11 am
Load MakeMKV and post the Drive Information & LibreDrive Information sections from the Info box on the right. For example, below is the relevant data from my ASUS BW-16D1HT.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Post by MartyMcNuts » Tue Mar 01, 2022 6:30 am
Post the complete right side pane.
jcdick1
Post by jcdick1 » Tue Mar 01, 2022 4:11 pm
UH12NS40:
Revision: 1.01
Serial number: SIK9HG76F263
Firmware date: 2117-11-23 15:50
Bus encryption flags: 16
Harware support: Yes
Firmware support: No
Firmware version: 1.01
ASUS BW-16D1HT:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: K9NI1QI1748
Post by Billycar11 » Tue Mar 01, 2022 11:41 pm
UH12NS40:
Revision: 1.01
ASUS BW-16D1HT:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Both need to be flashed and can do uhd for the Asus just follow the guide for the LG just flash it to the latest mk for it.
