Marvel's Eternals (2021)
stuckinkodiagain
Post by stuckinkodiagain » Mon Feb 14, 2022 8:17 pm
Got my disc early, and dump was submitted a couple days ago. It's working now! (U.S. 4K Steelbook)
FYI that the correct English playlist seems to be 00800.mpls, t04 (Segment map: 55, 56, 57, 58, 59)
The other playlists are all non-English for the opening information crawl. With the exception of 00801.mpls, t05 (Segment map: 55, 82, 57, 58, 59). I can't tell the difference at first glance between 801 and 800. But given that their other discs usually have 800 as the correct playlist, I'd say 800 is probably the right one.
Re: Marvel's Eternals (2021)
Post by SamuriHL » Mon Feb 14, 2022 8:37 pm
Awesome. I'm just waiting for mine now as it's out for delivery.
jayper
Post by jayper » Mon Feb 14, 2022 10:25 pm
My Best Buy steel landed on Saturday and worked out of the box.
Regarding the differences between playlists 800 and 801, it comes down to only the following to streams: 00056.m2ts and 00082.m2ts. The 00082 file has a few extra seconds of black screen before the English text begins to scroll.
If you back up the full disc you can navigate to the stream folder to compare the two files side by side: MARVEL_STUDIOS_ETERNALS\BDMV\STREAM.
Swaps
Post by Swaps » Mon Feb 14, 2022 10:56 pm
Regular release (non steelbook) not working - dump submitted.
Post by SamuriHL » Mon Feb 14, 2022 11:22 pm
BB SB working out of the box so thanks to whoever submitted it. :)
silvergold
Post by silvergold » Thu Feb 24, 2022 7:12 pm
any update on eternals yet? is it working yet for non SB?
Post by Woodstock » Thu Feb 24, 2022 7:19 pm
The post right above yours said it's working. Have you tried it?
wazupq97
Post by wazupq97 » Sun Feb 27, 2022 7:18 am
I need some help this is my 1st post so I have the wal-mart standard blu-ray and when I try any of the 4 there it always gives me the scene description audio as well as movie audio how do I get rid of that Thank you
Snake2bake
Post by Snake2bake » Sun Feb 27, 2022 4:18 pm
hi everyone. need some help with how too with same files size. :(
Snake2bake
Post by Snake2bake » Sun Feb 27, 2022 4:42 pm
i did the first one and now i am running it through HB, i will let you know what will be the outcome.
hartman9
Post by hartman9 » Mon Feb 28, 2022 5:11 pm
Does anyone know which of the four segment maps to use for the Blu-Ray version of Eternals? Thanks.
archer
Post by archer » Mon Feb 28, 2022 8:35 pm
With Disney titles, it's almost always
00800.mpls
and in this case:
Segment map: 55,56,57,58,59
for the US, Best Buy release
Verified it through Process Monitor and VLC Player
hartman9
Post by hartman9 » Tue Mar 01, 2022 1:03 am
Ok I will give it a go. Any easy way to tell if it's correct without watching the whole movie? For the record here are the four files and maps that I extracted.
MARVEL STUDIOS' ETERNALS - BLU-RAY_t03 (00800 - 946,947,948,949,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t04 (00801 - 946,954,948,949,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t05 (00802 - 946,955,948,953,950).mkv
MARVEL STUDIOS' ETERNALS - BLU-RAY_t06 (00803 - 946,956,948,949,950).mkv
archer
Post by archer » Tue Mar 01, 2022 6:23 am
I'm 99.9% sure you're good with
- 00800 is 00800.mpls
If you want to be 100% sure, you can follow the method outlined here:
viewtopic.php?f=6&t=16251
It's extremely useful to find the correct track. The only change I would make is:
- "Path" ends with ".mpls" and use VLC for Playback - If you need help, let me know
Monte
Post by Monte » Tue Mar 01, 2022 4:49 pm
Where is the update for the message: "Automatic HK downloading is disabled or failed" being pulled from. I am certain it's being blocked but can't find where.
Just need the IP or what it resolves to.
Monte
