Error when ripping Inception Bluray
MakeMKV v1.6.5 darwin(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-875 DB09" opened in DASPI mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI mode.
Evaluation version, 2 day(s) out of 30 remaining
File 00100.mpls was added as title #0
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #1
File 00007.m2ts was added as title #2
Title #00005.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/2TB External HDD/MKV Files
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '10832510976'
Failed to save title 0 to file /Volumes/2TB External HDD/MKV Files/title00.mkv
0 titles saved, 1 failed
The disc doesn't have any scatches or cracks, so I assume that's not the issue. Tried 3 different time - twice with a previous built and once with the most recent build (1.6.5). Any suggestions?
Re: Error when ripping Inception Bluray
http://www.makemkv.com/faq/item/7/catid/6
I saw this, and examined the disc again. I can't seem to find any scratches or imperfections on the disk though.
My copy of Inception ripped just fine (LG BH10LS30 in extenal USB enclosure, MakeMKV 1.6.5, MacBook Pro running OS X 10.6.6).
Why is MakeMKV using direct disc access? Do you have DASPI 1.2 installed?
Romansh wrote:Why is MakeMKV using direct disc access? Do you have DASPI 1.2 installed?
Yeah, it is installed. And when I downloaded the new version of MakeMKV, I reinstalled it just in case it was removed when I deleted the old version.
- Contact:
Please try to make a full disc backup with MakeMKV first. But the error does look like a bad disc.
Alright, I'm having this same problem as well. I get about 17 Gb into the rip and then it happens:
MakeMKV v1.6.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Lankin/MakeMKV_log.txt
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at qB"4q5hwAAzifof@:121269156
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00009.m2ts has length of 62 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00008.m2ts has length of 148 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00007.m2ts has length of 146 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00005.m2ts has length of 101 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00004.m2ts has length of 78 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Saving 1 titles into directory N:/Video/Inception
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393953
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683105280, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683418624, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683424768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683430912, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683695104, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18683713536, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18684837888, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18687264768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18687301632, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18688462848, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689636352, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689648640, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18689654784, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18690471936, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691080192, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691086336, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18691700736, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692573184, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692579328, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692585472, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692591616, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18692610048, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18693163008, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18695553024, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18696480768, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697052160, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697058304, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697064448, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697070592, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697089024, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697887744, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697900032, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697906176, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697918464, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 18697924608, attempting to work around
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:29393907
DEBUG: Code 0 at Vs:iO}FTd)}l*rLQGg]]:121262509
DEBUG: Code 0 at CQdHTn+?Xq-BeRMa"F,F:29394321
DEBUG: Code 9129852 at CQdHTn+?Xq-BeRMa"F,F:29393309
DEBUG: Code 0 at TbxNL?L'!OrC\Vi%oQ9x4:29397449
Failed to save title 0 to file N:/Video/Inception/title00.mkv
There are no readily apparent scratches, smudges, or other blemishes on the disk. What gives?
- Contact:
Same ask, please make a full disc backup per http://www.makemkv.com/faq/item/4/catid/4 and see if any hashcheck errors show up.
Sorry, Mike. Thanks for repeating yourself. Here's what I got:
Backing up disc into folder "E:\Music and Movies\Inception"
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18695448576, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18705672192, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18829535232, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18873575424, file is corrupt.
Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 18888321024, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00001.m2ts.
Hash check for /BDMV/STREAM/00001.m2ts : 0.00% corrupt, 99.99% correct, 99.99% checked.
Backup done but 1 files failed hash check
Is this irreparable?
Yes, the disc is damaged.pelegram34 wrote:Is this irreparable?
