"invalid timecodes" when ripping 3D MVC ISOs
Everything related to Blu-ray 3D and 3D MKV files
woodpost
Post by woodpost »
as of v1.14.5 i've been getting invalid timecode errors when ripping from 3D MVC ISOs, and the rips fail.
AV synchronization issues were found in file
AV sync issue in stream 0 at 0:47:47.573 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:47.573 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:47.739 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:47.739 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:47.906 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:47.906 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:50.951 : too many video frames with invalid timecodes, future messages will be suppressed
Failed to save title 0 to file
both 3D ISOs i've tried since updating to 1.14.5 have failed like this. never had any problems before.
woodpost
Re: "invalid timecodes" when ripping 3D MVC ISOs
Post by woodpost »
still having this problem ripping all 3D MVC ISO's with the latest builds. am i the only one experiencing this issue? can someone confirm if they're able to rip 3D ISO's? thanks!
davosje
Post by davosje »
Hi! Did you get it to work allready?
I'm having the exact same error as you have
AV sync issue in stream 0 at 0:47:48.073 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:48.073 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:48.240 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:48.240 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:48.407 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:50.576 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:50.742 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:47:50.742 : secondary stream video frame timecode differs by +41.611ms
AV sync issue in stream 0 at 0:47:50.742 : too many video frames with invalid timecodes, future messages will be suppressed
Some movies work fine, some of them wont. I experienced this last error when making an MKV of Up
preserve
Post by preserve »
I know it’s not the answer you’re looking for, but have you tried going back to your original discs?
I’ve had no issues ripping physical 3D discs in the latest versions.
Using: ASUS BW-16D1HT 3.00
vanden
Post by vanden »
The problem comes from blu-ray with several .m2ts/siff files which were ripped by tsMuxer or clown BD (with only one .siff file) ...
The problem comes from blu-ray with several .m2ts/siff files which are made by MakeMKV (1 single .mkv file), then .mkv retransform into blu-ray with tsMuxer (with only one .siff file) ...
The opening of the ISO makes mistakes !!!
Is there a solution ?
vanden
Post by vanden »
I found the solution !
Using DVDFab 12 !
Open bluray, use "Ripper"
Choose "Theater (3D MKV/MVC Passthrough)"
https://i.ibb.co/7XVLRy5/mux-ISO-MKV.jpg
And it works !
