Can't read discs SOLVED
Trasper
#1 Post by Trasper » Fri Feb 25, 2022 3:47 pm
Hi!
Wanted to back-up a couple of discs today, one blu-ray and one UHD.
Neither showed in MakeMKV and only the UHD showed up in Finder on my Mac.
The last time I backed up was four days ago.
Since it worked fine then, I tried the same UHD again.
Today it didn't show in MakeMKV or Finder.
I'm on the latest version of MacOS Monterey, and on latest version of MakeMKV.
Pretty sure none is updated since last time I used MakeMKV.
My drive/fw is an external LG-BH16NS55 CF WH16NS60 1.02MK
Any ideas what can be wrong?
UPDATE:
Problem seems to have solved itself.
Turned of the drive. Thought I should give it another try one hour later.
Alle discs worked fine.
Weird... But great.
