MakeMKV doesn't see all files on Inspector Lewis complete series disc 13
ltcolumbo0
#1 Post by ltcolumbo0 » Thu Feb 24, 2022 12:59 am
When attempting to rip Inspector Lewis Disc 13, which contains 4 files for Season 7, MakeMKV only sees a single file. However, when using Magic DVD Ripper, 4 files are found and can be ripped.
I found and tried the MakeMKV manual mode which sees all 4 files (see attached), and was able to rip title #4 (s07e03-e04) successfully. So why isn't this seen with automatic mode?
Debug log started at Thu Feb 24 02:45:46 2022 , written by MakeMKV v1.16.5 win(x64-release)
001005:0000 MakeMKV v1.16.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Mike/MakeMKV_log.txt
No SDF v086: HL-DT-ST_DVDRAM_GH24NSC0_LI00_201512111549_K1MI4DB3451
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF id v086: HL-DT-ST_DVDRAM_GH24NSC0_LI00_201512111549_K1MI4DB3451
No SDF v086: ASUS_BW-12B1ST_1.03_B7D0CL343873
SDF id v086: ASUS_BW-12B1ST_1.03_B7D0CL343873
No auto SDF v086: HL-DT-ST_DVDRAM_GH24NSC0_LI00_201512111549_K1MI4DB3451
DEBUG: Code 0 at B/8ly-CyD^yX5Iu:<:121264142
DEBUG: Code 0 at FCX0qMEkxy~zx6FI:213136769
003028:0000 Title #1 was added (13 cell(s), 1:30:34)
DEBUG: Code 16777991 at 4pWR=_,=xe/mE')d:121266189
Title skip vts=1 pgcn=3 hash=998ACDB1374B3E3E
003025:0000 Title #4 has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
