HL-DT-ST_DVDRAM_GUE1N_AS00_201512091421
ale5000
Post by ale5000 »
I have this info in MakeMKV:
Current profile: DVD-ROM
Product: DVDRAM GUE1N
Revision: AS00
Serial number: ***
Firmware date: 2015-12-09 14:21
Disc Information
Label: ***
Timestamp: 2012-07-26 17:26:02
Data capacity: 3.16 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 2.52 Mbps [0.25x]
Number of layers: 1 (PTP)
The LibreDrive Information section is missing.
In the log there is:
Debug log started at Wed Feb 23 18:41:19 2022 , written by MakeMKV v1.16.5 win(x64-release)
001005:0000 MakeMKV v1.16.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://***/MakeMKV_log.txt
No  SDF v086: HL-DT-ST_DVDRAM_GUE1N_AS00_201512091421_***
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF id v086: HL-DT-ST_DVDRAM_GUE1N_AS00_201512091421_***
No auto SDF v086: HL-DT-ST_DVDRAM_GUE1N_AS00_201512091421_***
DEBUG: Code 0 at B/8ly-CyD^yX5Iu:<:121264142
DEBUG: Code 0 at FCX0qMEkxy~zx6FI:213136769
I have tried:
sdftool -d D: dump -o c:\out
and I get:
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Re: HL-DT-ST_DVDRAM_GUE1N_AS00_201512091421
Sorry, your drive is obsolete. Only capable of DVD. Not for BD or UHD-BD. For DVD no Libredrive is needed.
ale5000
Post by ale5000 »
So isn't there any plan to remove region and speed limits on DVD drives?
ale5000 wrote:
Fri Mar 04, 2022 9:22 pm
Makemkv does that. And DVDs don't need much time to be ripped. Come on! Enter the future / presence and switch to BD / UHD.
