I have an LG WH16NS40 that I bought last year which came with the 1.04 firmware. I flashed it with the WH16NS60 1.02 LibreDrive enabled firmware from this site. Since then it has been unstable. I can rip one or two discs and then it throws errors on the next disc and I have to power cycle my system in order to be able to eject the disc and get it working again. I'm seeing messages like this:
MSG:2003,16777216,3,"Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '5858131968'","Error '%1' occurred while reading '%2' at offset '%3'","Internal error - Operation result is incorrect (132)","/BDMV/STREAM/00014.m2ts","5858131968"
I updated the MakeMKV config file and added a line for the drive
sdf_Stop = "HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KL7K36A4851"
and now it is working normally again and I have been able to read several discs in a row with no problems.
I'm not currently ripping any 4K discs, so I don't think I need LibreDrive at present and the software seems to work fine for regular blu rays without it.
How do I flash my drive back to a stock firmware?
Remove LibreDrive firmware and revert to stock?
keithhelms
Re: Remove LibreDrive firmware and revert to stock?
No point just puts you at risk of bricking it
Leave it as is
Leave it as is
Do you have speed control enabled? Is this still happening?keithhelms wrote: Sun Jan 24, 2021 5:36 pm I have an LG WH16NS40 that I bought last year which came with the 1.04 firmware. I flashed it with the WH16NS60 1.02 LibreDrive enabled firmware from this site. Since then it has been unstable. I can rip one or two discs and then it throws errors on the next disc and I have to power cycle my system in order to be able to eject the disc and get it working again.
