Remove LibreDrive firmware and revert to stock?
keithhelms
Post by keithhelms »
I have an LG WH16NS40 that I bought last year which came with the 1.04 firmware. I flashed it with the WH16NS60 1.02 LibreDrive enabled firmware from this site. Since then it has been unstable. I can rip one or two discs and then it throws errors on the next disc and I have to power cycle my system in order to be able to eject the disc and get it working again. I'm seeing messages like this:
MSG:2003,16777216,3,"Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '5858131968'","Error '%1' occurred while reading '%2' at offset '%3'","Internal error - Operation result is incorrect (132)","/BDMV/STREAM/00014.m2ts","5858131968"
I updated the MakeMKV config file and added a line for the drive
sdf_Stop = "HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KL7K36A4851"
and now it is working normally again and I have been able to read several discs in a row with no problems.
I'm not currently ripping any 4K discs, so I don't think I need LibreDrive at present and the software seems to work fine for regular blu rays without it.
How do I flash my drive back to a stock firmware?
Re: Remove LibreDrive firmware and revert to stock?
No point just puts you at risk of bricking it
Leave it as is
Post by mike admin »
keithhelms wrote: Sun Jan 24, 2021 5:36 pm I have an LG WH16NS40 that I bought last year which came with the 1.04 firmware. I flashed it with the WH16NS60 1.02 LibreDrive enabled firmware from this site. Since then it has been unstable. I can rip one or two discs and then it throws errors on the next disc and I have to power cycle my system in order to be able to eject the disc and get it working again.
Do you have speed control enabled? Is this still happening?
