ArArdin
Post by ArArdin » Tue Feb 22, 2022 7:44 am
Wow, that's great work, RESET_9999. Thanks a bunch.
FubbAyH
Post by FubbAyH » Tue Feb 22, 2022 1:16 pm
Yep, outstanding work @RESET_9999! Thanks so much for putting that together.
Baer2021
Post by Baer2021 » Tue Feb 22, 2022 1:56 pm
RESET_9999 wrote:
Tue Feb 22, 2022 4:42 am
instead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
If you want to add anything, let me know.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Amazing work, thanks for posting this!
baker99
Post by baker99 » Tue Feb 22, 2022 5:40 pm
Brilliant. thanks RESET_9999
DolbyVisionFTW
Post by DolbyVisionFTW » Tue Feb 22, 2022 6:02 pm
Cheers mate, very helpful.
BadlyDrawnBoy
Post by BadlyDrawnBoy » Tue Feb 22, 2022 7:53 pm
You're the man! Thanks!
FubbAyH
Post by FubbAyH » Tue Feb 22, 2022 8:39 pm
FYI: the tsMuxer corruption bug seems to be fixed in the latest nightly (f4fa419 / 2022-02-22-18-30-10).
I've done a couple of full movie remuxes with it and they both passed the test of being fully decoded by ffmpeg with no errors.
ArArdin
Post by ArArdin » Tue Feb 22, 2022 9:51 pm
Yeah, I just noticed the new release. Great things are fixed.
vpm-avs
Post by vpm-avs » Wed Feb 23, 2022 12:25 am
I can confirm for LG G1 at least the built in player falls back to HDR10 on profile 7.
The situation right now seems to be that there is no good solution to play all DV profiles (or at least 5 and 8) with lossless audio, except from original bluray discs. Since all the players that can do lossless audio have other issues.
Or are there others that will do the job?
ArArdin
Post by ArArdin » Wed Feb 23, 2022 10:06 am
I can't vouch for profile 5, but at least since latest firmware my Zidoo Z9x has shown excellent playback of DV profile 7 and 8 mkv with lossless audio. Admittedly it is not too long ago I started with profile 8 and I didn't create much of them.
@RESET_9999
I am curious about the Z9X unstable playback of profile 8 as mentioned in the spreadsheet. Can you name a specific title where the Zidoo shows the RPU issue? I want to have a look at this. See if I can answer some questions.
Post by RESET_9999 » Wed Feb 23, 2022 11:46 am
@RESET_9999
Shang Chi P5 imax web-dl converted to P8 and injected into HDR10 imax web-dl. RPU goes out of sync after 30 minutes... fine on shield , x700 and C8
Sony x800m2 is the way to go. support all profiles with lossless audio and is bug free.
ArArdin
Post by ArArdin » Wed Feb 23, 2022 12:48 pm
Thank you, I'll have a search.
You didn't have this "P8 issue only on Z9X" with a self-ripped disc and conversion? If so, I'd like to hear what movie(s) you can recall.
Post by RESET_9999 » Wed Feb 23, 2022 1:13 pm
I don't remember. I watched about 10 movies and it happened 2 times(Only remember Shang Chi) and then got rid of the device, could not trust it anymore.
sickb
Post by sickb » Fri Feb 25, 2022 8:27 pm
no truehd mkv though, that's one of the few reasons why im considering the oppo203 clones.
Post by RESET_9999 » Fri Feb 25, 2022 9:19 pm
We can generate DV for any HDR10 movie... MKV container is useless to me and this thread is about Dolby Vision , not HDR10/SDR playback...
