Archgon slim BU40N not flashing?
Collyde
#1 Post by Collyde » Tue Feb 22, 2022 9:56 pm
This slim Archgon UHD appears to have an LG BU40 Drive.
I went through the packaged flashing on Windows and after loading MakeMKV on Mac I still see FW 1.0.2
Screen from MakeMKV
Status:
Possible (with patched firmware)
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: Ghost_in_the_Shell
Timestamp: 2017-05-30 15:26:47
Protection: AACS v57
Data capacity: 36.54 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
I then tried the suggested flash approach on macOS, which appeared successful. It used the "The all you need firmware pack.zip"
% ./makemkvcon f -d '/IOBDServices/2BE13B4B' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO9L91G5731
yes
 100% Operation finished
Done successfully
Any suggestions?
Re: Archgon slim BU40N not flashing?
#2 Post by Billycar11 » Tue Feb 22, 2022 10:09 pm
Enc your firmware is on the encrypted list
Collyde
#3 Post by Collyde » Tue Feb 22, 2022 10:58 pm
"Enc your firmware is on the encrypted list"
Not sure what that means. Do you mean the firmware is encrypted and cannot be updated?
#4 Post by Woodstock » Tue Feb 22, 2022 11:39 pm
No, that you have to check the "enc" box on the flasher.
Collyde
#5 Post by Collyde » Wed Feb 23, 2022 12:21 am
When I used SDFTool Flasher on my Mac (BootCamp, VM) I end up with a distorted Window on both Retina and standard displays.
I looked at the Registry but there does not seem to be a way to fix it.
Borders cannot be dragged.
It is too small to see details like "enc." I can set the drive and FW file.
#6 Post by Billycar11 » Wed Feb 23, 2022 12:28 am
you cant flash through a VM anyway well you can but no.
read the guide and add enc to your command thats all i cant walk everyone through this
Collyde
#7 Post by Collyde » Wed Feb 23, 2022 1:21 am
Thank you for the help.
Should have just used the command line ---help option like a good nerd.
All is well. The BU40N v1.0.3 for slimline works, the v1.0.4 from the mk fw package did not, presumably not for slimline.
When I was running the SDFlasher native on Windows 10 x86_64 I ended with an error 0x8f056103 plus the aforementioned display struggle on a Retina screen. Making a standard display the main screen fixed that.
But I have no trouble with the command line. Should just RTFM.
:D
golfbravo
#8 Post by golfbravo » Fri Nov 04, 2022 7:38 pm
I appear to have a similar (not flashing) problem.
MacOS Ventura and a brand new out of the box Archgon MD-8107S-U3YC-UHD drive. The drive has 1.02 firmware.
I downloaded the full pack and followed the instructions [viewtopic.php?t=19634].
I ran the Terminal command and got:
Reading input file /users/grahambb/dvdflash/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO9M2QF0336
yes
Done successfully
However, the drive still seems to be at 1.2
I am a complete and utter novice at this, so any help would be appreciated.
#9 Post by MartyMcNuts » Fri Nov 04, 2022 9:44 pm
yes
Done successfully
In your command use enc as your drive had encrypted firmware.
golfbravo
#10 Post by golfbravo » Fri Nov 04, 2022 9:56 pm
Still see 1.02 after this:
Retina MacOS % ./makemkvcon f -d '/IOBDServices/FC2CB729' -f /users/grahambb/dvdflash/sdf.bin rawflash main enc -i /users/grahambb/dvdflash/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
yes
Done successfully
#11 Post by Billycar11 » Fri Nov 04, 2022 10:11 pm
yes
Done successfully
No main just enc please read guide
golfbravo
#12 Post by golfbravo » Fri Nov 04, 2022 10:33 pm
Thanks for that. Now at 1.03
That has reveled other issues, but I'll search for those separately.
