Archgon slim BU40N not flashing?
Collyde
Post by Collyde »
This slim Archgon UHD appears to have an LG BU40 Drive.
I went through the packaged flashing on Windows and after loading MakeMKV on Mac I still see FW 1.0.2
Screen from MakeMKV
Status:
Possible (with patched firmware)
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: Ghost_in_the_Shell
Timestamp: 2017-05-30 15:26:47
Protection: AACS v57
Data capacity: 36.54 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
I then tried the suggested flash approach on macOS, which appeared successful. It used the "The all you need firmware pack.zip"
% ./makemkvcon f -d '/IOBDServices/2BE13B4B' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO9L91G5731
yes
 100% Operation finished
Done successfully
Any suggestions?
Re: Archgon slim BU40N not flashing?
Enc your firmware is on the encrypted list
Collyde
Post by Collyde »
"Enc your firmware is on the encrypted list"
Not sure what that means. Do you mean the firmware is encrypted and cannot be updated?
No, that you have to check the "enc" box on the flasher.
Collyde
Post by Collyde »
When I used SDFTool Flasher on my Mac (BootCamp, VM) I end up with a distorted Window on both Retina and standard displays.
I looked at the Registry but there does not seem to be a way to fix it.
Borders cannot be dragged.
It is too small to see details like "enc." I can set the drive and FW file.
Collyde wrote: Wed Feb 23, 2022 12:21 am When I used SDFTool Flasher on my Mac (BootCamp, VM) I end up with a distorted Window on both Retina and standard displays.
you cant flash through a VM anyway well you can but no.
read the guide and add enc to your command thats all i cant walk everyone through this
Collyde
Post by Collyde »
Thank you for the help.
Should have just used the command line ---help option like a good nerd.
All is well. The BU40N v1.0.3 for slimline works, the v1.0.4 from the mk fw package did not, presumably not for slimline.
When I was running the SDFlasher native on Windows 10 x86_64 I ended with an error 0x8f056103 plus the aforementioned display struggle on a Retina screen. Making a standard display the main screen fixed that.
But I have no trouble with the command line. Should just RTFM.
:D
golfbravo
Post by golfbravo »
I appear to have a similar (not flashing) problem.
MacOS Ventura and a brand new out of the box Archgon MD-8107S-U3YC-UHD drive. The drive has 1.02 firmware.
I downloaded the full pack and followed the instructions [viewtopic.php?t=19634].
I ran the Terminal command and got:
Reading input file /users/grahambb/dvdflash/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO9M2QF0336
yes
Done successfully
However, the drive still seems to be at 1.2
I am a complete and utter novice at this, so any help would be appreciated.
golfbravo wrote: Fri Nov 04, 2022 7:38 pm I appear to have a similar (not flashing) problem.
yes
Done successfully
In your command use enc as your drive had encrypted firmware.
golfbravo
Post by golfbravo »
Still see 1.02 after this:
Retina MacOS % ./makemkvcon f -d '/IOBDServices/FC2CB729' -f /users/grahambb/dvdflash/sdf.bin rawflash main enc -i /users/grahambb/dvdflash/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
yes
Done successfully
golfbravo wrote: Fri Nov 04, 2022 9:56 pm Still see 1.02 after this:
yes
Done successfully
No main just enc please read guide
golfbravo
Post by golfbravo »
Thanks for that. Now at 1.03
That has reveled other issues, but I'll search for those separately.
