instead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
If you want to add anything, let me know.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Wow, that's great work, RESET_9999. Thanks a bunch.
Yep, outstanding work @RESET_9999! Thanks so much for putting that together.
Amazing work, thanks for posting this!RESET_9999 wrote: ↑Tue Feb 22, 2022 4:42 aminstead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
Brilliant. thanks RESET_9999RESET_9999 wrote: ↑Tue Feb 22, 2022 4:42 aminstead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
Cheers mate, very helpful.RESET_9999 wrote: ↑Tue Feb 22, 2022 4:42 aminstead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
You're the man! Thanks!RESET_9999 wrote: ↑Tue Feb 22, 2022 4:42 aminstead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
FYI: the tsMuxer corruption bug seems to be fixed in the latest nightly (f4fa419 / 2022-02-22-18-30-10).
I've done a couple of full movie remuxes with it and they both passed the test of being fully decoded by ffmpeg with no errors.
Yeah, I just noticed the new release. Great things are fixed.
I can confirm for LG G1 at least the built in player falls back to HDR10 on profile 7.RESET_9999 wrote: ↑Tue Feb 22, 2022 4:42 aminstead of answering always the same question over and over, I made an excel sheet resuming pretty much everything that works or not.
The situation right now seems to be that there is no good solution to play all DV profiles (or at least 5 and 8) with lossless audio, except from original bluray discs. Since all the players that can do lossless audio have other issues.
Or are there others that will do the job?
I can't vouch for profile 5, but at least since latest firmware my Zidoo Z9x has shown excellent playback of DV profile 7 and 8 mkv with lossless audio. Admittedly it is not too long ago I started with profile 8 and I didn't create much of them.
@RESET_9999
I am curious about the Z9X unstable playback of profile 8 as mentioned in the spreadsheet. Can you name a specific title where the Zidoo shows the RPU issue? I want to have a look at this. See if I can answer some questions.
Shang Chi P5 imax web-dl converted to P8 and injected into HDR10 imax web-dl. RPU goes out of sync after 30 minutes... fine on shield , x700 and C8
Sony x800m2 is the way to go. support all profiles with lossless audio and is bug free.vpm-avs wrote: ↑Wed Feb 23, 2022 12:25 amThe situation right now seems to be that there is no good solution to play all DV profiles (or at least 5 and with lossless audio, except from original bluray discs. Since all the players that can do lossless audio have other issues.
Thank you, I'll have a search.RESET_9999 wrote: ↑Wed Feb 23, 2022 11:46 amShang Chi P5 imax web-dl converted to P8 and injected into HDR10 imax web-dl. RPU goes out of sync after 30 minutes... fine on shield , x700 and C8
You didn't have this "P8 issue only on Z9X" with a self-ripped disc and conversion? If so, I'd like to hear what movie(s) you can recall.
I don't remember. I watched about 10 movies and it happened 2 times(Only remember Shang Chi) and then got rid of the device, could not trust it anymore.ArArdin wrote: ↑Wed Feb 23, 2022 12:48 pmThank you, I'll have a search.RESET_9999 wrote: ↑Wed Feb 23, 2022 11:46 amShang Chi P5 imax web-dl converted to P8 and injected into HDR10 imax web-dl. RPU goes out of sync after 30 minutes... fine on shield , x700 and C8
no truehd mkv though, that's one of the few reasons why im considering the oppo203 clones.
