Purchased Insurgent Redbox Blu-Ray
gereral1
Re: Purchased Insurgent Redbox Blu-Ray
Post by gereral1 » Wed Jun 15, 2016 2:13 am
preserve wrote:
gereral1 wrote:The movie insurgant was used in my videos but blanked out due to copywrite. This is the canada disk.
Okay, can you post what the playlist number is then? That's what forums are for, and that's what people generally do in this forum - help other people.
general1 wrote:We are weary on letting anyone use this tool as it will find the correct mpls with 2 clicks. This tool will work under all versions of windows. No mac versions.
I don't understand the point of saying that it's for Windows, and advertising how great it is, if no one can use it.
PS, I think you mean "wary" instead of "weary" ;)
But I don't understand, what are you wary about?
The movie industry reads these forums. If I reveal the next screen pass protection they will counter with patches and code. They have moved onto the cashed protection and calling fake playlists because of my videos. I then showed how to defeat this and they are now doing chapter obsufucation on newer disks. So if I share this it will be another round of crap to find the movie playlist. As for mpls it's 209 masked and with alldup 258. This is layed out in the other 2 videos if you dig deeper into my channel under hometheater101 section. This is an old movie by now. Sorry for the delayed reply.
preserve
Post by preserve » Thu Jun 16, 2016 3:37 am
fuzzfuzz wrote:00258.mpls:
506,502,504,510,511,501,505,507,509,503,508
Thanks again for the help. It WAS 258 for the same Canadian UPC, but somehow mine had a different segment map than yours - I triple checked it to make sure I copied it down correctly from a screenshot:
00258.mpls
506,504,510,502,511,501,505,507,509,503,508
16 chapters, 1:59:00
0:00:00 - 1
0:06:11 - 2
0:13:35 - 3
0:19:35 - 4
0:26:39 - 5
0:34:23 - 6
0:41:13 - 7
0:46:34 - 8
0:53:10 - 9
0:59:30 - 10
1:05:59 - 11
1:13:34 - 12
1:22:57 - 13
1:32:04 - 14
1:39:09 - 15
1:46:38 - 16
Using: ASUS BW-16D1HT 3.00
MagnumXL
Post by MagnumXL » Fri Jan 21, 2022 5:22 am
None of these segments match my 3D disc. All four possibilities begin with Segment 609. I've had this disc for a long time, but never watched it and didn't realize I dumped the wrong one (probably the one marked "FPL_MainFeature_3D"). I can't believe not one post on these entire forums (or Google) show a segment 609 as the start. I'm using the latest MakeMKV. I guess I'd need to dump and watch them all.
Post by dcoke22 » Fri Jan 21, 2022 4:34 pm
MagnumXL wrote: Fri Jan 21, 2022 5:22 am None of these segments match my 3D disc. All four possibilities begin with Segment 609. I've had this disc for a long time, but never watched it and didn't realize I dumped the wrong one (probably the one marked "FPL_MainFeature_3D"). I can't believe not one post on these entire forums (or Google) show a segment 609 as the start. I'm using the latest MakeMKV. I guess I'd need to dump and watch them all.
If you make a decrypted disc backup, you should be able to use VLC to watch the individual segments to find the correct segment map.
MagnumXL
Post by MagnumXL » Sun Feb 20, 2022 11:01 pm
Yeah, I dumped them all and looked for the problem scenes. I'm pretty sure I found the correct one.
