kingston12
Re: SDFtool Flasher
Post by kingston12 » Sun Feb 20, 2022 4:26 pm
Thanks for all of the work that has been put in on this.
I've got two BU40N drives that I flashed to 1.00 years ago using the original ASUS flasher.
Is there any advantage in moving them to the 1.03 firmware using the new method, or am I just as well sticking with what I've got if they are working fine?
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Feb 20, 2022 10:39 pm
kingston12 wrote: Sun Feb 20, 2022 4:26 pm Thanks for all of the work that has been put in on this.
No advantage whatsoever, only disadvantages.
abmcconnell
Re: SDFtool Flasher
Post by abmcconnell » Mon Feb 21, 2022 3:58 pm
Looks like there are now 3 options for the BU40N. 1.0, 1.03 and 1.04
Which is preferred and why, please?
Can anyone point me to an explanation of MK versus DE versus HL formats?
I see a few bits at the top of this thread, curious to learn more.
kingston12
Re: SDFtool Flasher
Post by kingston12 » Mon Feb 21, 2022 5:12 pm
MartyMcNuts wrote: Sun Feb 20, 2022 10:39 pm
Thanks, I'll stick with what I've got!
bawjaws
Re: SDFtool Flasher
Post by bawjaws » Tue Feb 22, 2022 4:46 pm
Greetings! Newbie here, having just got a BP55EB40 from Amazon. I followed the instructions at the top of the thread (honest, I did!): flashed to BP50NB40 1.03-MK, then flashed to BP50NB40 1.03-MK, with boot ticked, then tried to crossflash via RECOVERY to BP60NB10 1.00-MK...
BUT...the only firmware in the MK-Firmware-Pack for BP60NB10 is 1.02MK.
I used this one, and it seemed to complete but at the end I got the error message with an error code of 0x8f062900.
MakeMKV seems to have updated the Info section to show that the flash has been completed successfully, but error codes with random hex numbers are never a good way to leave things, so I'm a bit worried :-)
It seems to be reading a 4K disc OK at the moment, but I've yet to actually rip it.
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Feb 22, 2022 9:12 pm
bawjaws wrote: Tue Feb 22, 2022 4:46 pm Greetings! Newbie here, having just got a BP55EB40 from Amazon. I followed the instructions at the top of the thread (honest, I did!): flashed to BP50NB40 1.03-MK, then flashed to BP50NB40 1.03-MK, with boot ticked, then tried to crossflash via RECOVERY to BP60NB10 1.00-MK...
BP60NB10 1.00-MK is in the "old" folder of the MK firmware pack. Anyway, you should be good to go. If you are really worried about it, you could complete the last flash again (BP60NB10 1.02-MK or BP60NB10 1.00-MK) and see if the error appears again.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Mar 02, 2022 4:00 am
Hi everyone,
Just letting you know the SDFtool Flasher has an update. The latest version is v1.3.2. Download link has been updated in the first post.
This latest update improves encrypted firmware detection. (I have not touched the encryption flag toggle ability, just in case it is needed for a particular drive.)
Wolf359
Re: SDFtool Flasher
Post by Wolf359 » Sat Mar 12, 2022 5:28 pm
Does the flasher need to be run in admin mode to work?
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Mar 12, 2022 9:03 pm
Wolf359 wrote: Sat Mar 12, 2022 5:28 pm Does the flasher need to be run in admin mode to work?
Not normally. If you are not admin on your PC, then probably.
Bilbo
Re: SDFtool Flasher
Post by Bilbo » Sun Mar 13, 2022 5:32 am
Hi, thanks for the tool!
I'm trying to read/play/rip UHDs
forgive me if I missed the answer, I combed through 33 pages.
me:
Win10 x64 (administrator)
Model: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MOEL91I1100
https://www.amazon.com/gp/product/B07BC9F98J/
the Archgon.
connected via USB. Slimline.
Firmware chosen: DE_LG_BU40N_1.00
results:
"Command produced error code 0x8f052603"
please help
Wolf359
Re: SDFtool Flasher
Post by Wolf359 » Sun Mar 13, 2022 8:44 pm
@MartyMcNuts thanks for making and maintaining this tool for us! I used it today and encountered no problems at all!! Thanks. :D
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Mar 13, 2022 9:14 pm
Bilbo wrote: Sun Mar 13, 2022 5:32 am Hi, thanks for the tool!
me:
the Archgon.
results:
please help
Make sure there is no disc in the drive and the tray is closed.
Make sure you using the latest version of the SDFtool flasher, which does detect the Archgon 1.02 firmware as encrypted.
You can't flash 1.00 directly. Flash to 1.03-MK first, then flash to 1.00.
Re: SDFtool Flasher
Post by Billycar11 » Sun Mar 13, 2022 10:28 pm
MartyMcNuts wrote: Sun Mar 13, 2022 9:14 pm
me:
the Archgon.
results:
please help
1.00 won't work direct follow the guides recommend flashing sequence
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Mar 13, 2022 10:46 pm
Billycar11 wrote: Sun Mar 13, 2022 10:28 pm
me:
the Archgon.
results:
please help
Yep, geez, how'd I miss that!! I've edited my post.
Bilbo
Re: SDFtool Flasher
Post by Bilbo » Mon Mar 14, 2022 12:23 am
me:
the Archgon.
results:
please help
flawless victory!! Woooo I'm now watching the 1st 4k UHD blu-ray title I've ever purchased! Worked great, thanks again guys for all your help!
P.S. For this drive, should I stick w/ this firmware as-is, or is there another cross-type I should flash w/ (to get faster reads of UHDs?)
Thanks again!!
