Java Problem on one Bluray Disk
Janus
Post by Janus » Sun Feb 20, 2022 4:19 pm
Hey dear Developers,
I got a problem with one Bluray disk which I cannot fix.
Reading the menu stops always with "Fatal error occured, program will exit now" while reading a file called /BDMV/JAR/04518/menu_p1.1.prop
I'm on Linux and tried a recent Ubuntu and a recent Debian. I switched to a few available Java Versions (Openjdk 9,10,11 and Sun/Oracle Java 7,8). All stop with the same error. The Bluray is new and every Bluray before worked quite well.
Contents of the file mentioned above:
########################### SPECIAL FEATURES ###############################
inmovie_on.image=radio_IME_on_png,radio_IME_on_f_png,radio_IME_on_on_png,radio_IME_on_f_on_png
imePodMenu.name=IMEPodMenu
imePodMenu.zIndex=-1
imePodMenu.position=70,75
imePodMenu.size=126,63
imePodMenu.image=PIP_POD_pod_png
imePodMenu.children=imePodLeftArrow,imePodRightArrow
imePodLeftArrow.name=imePodLeftArrow
imePodLeftArrow.type=Button
imePodLeftArrow.position=0,27
imePodLeftArrow.image=,PIP_POD_lfArrow_png,PIP_POD_lfArrow_a_png
imePodRightArrow.name=imePodRightArrow
imePodRightArrow.type=Button
imePodRightArrow.position=91,27
imePodRightArrow.image=,PIP_POD_rtArrow_png,PIP_POD_rtArrow_a_png
Is there a possibility to skip this file, or to avoid the java error?
Thanks for your kind answer!
Re: Java Problem on one Bluray Disk
Post by dcoke22 » Tue Feb 22, 2022 3:24 pm
viewtopic.php?f=3&t=17268&start=15
Some folks have had luck setting the custom java executable to /bin/true as outlined in the thread above.
Janus
Post by Janus » Fri Feb 25, 2022 11:40 am
Setting the Java Executable to "/bin/true" did the trick.
So all what is left, is asking for an option "Ignore all Java Errors". As I understand it's only a problem that java gives back a none zero Return Value, but the Java Menu isn't needed to access the files. Now I know how to fix it, but others should have these without knowledge of this forum ;)
Thanks for the help!
