Here is my drive info.
OS device name: E:
Product: BD-RE BU40N
Revision: FR07
Serial number: MZFL8OI3421
Firmware date: 2119-05-10 13:48
Bus encryption flags: 1F
Highest AACS version: 76
Here is my error message in CMD.
.\makemkvcon.exe f --all-yes -d E: rawflash -i "C:\Users\15030\Desktop\BU40N-FR\fire.bin"
Unable to load sdf.bin
Internal error 0xffffffff
Here is my error message when I try to open SDFtool Flasher
An error occurred trying to start process 'c:\users\15030\downloads\MakeMKV\sdftool64.exe' with working directory 'c:\program files (x86)\MakveMKV'.
When I ignore this error continue to open the software, the dropbox to choice BD drive is empty
BU40N FR flash firmware error by SDRflasher and CMD
caokddjs
Re: BU40N FR flash firmware error by SDRflasher and CMD
Read the troubleshooting section of the guide you may just need to open a bluray or you may need to do the force flash command
caokddjs
Still same error on CMD. 0xfffffff
What's precisely the .net framework version SDFtool Flasher needs?
Maybe I directly installed it again, and it would be fine.
That's what error I get from the SDF tool Flasher. I tried three different win10 64 computers they all show the same error. I tried them on another brand new win7 64 computer, which shows another mistake "Machine lost the 1-1-0.dll.". Actually, the DLL wasn't lost.
The dropdown box in SDF flasher software also is empty. It didn't show any BD/DVD drive
System.ComponentModel.Win32Exception (2): An error occurred trying to start process 'C:\Users\15030\Downloads\MakeMKV\sdftool64.exe' with working directory 'C:\Users\15030\Desktop\SDF(v1.2.4)'. 系统找不到指定的文件。
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at SDFtool_Flasher_Updated.Form1.Get_Drive_List()
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
caokddjs
PS C:\program files (x86)\makemkv> ./makemkvcon64.exe f --all-yes -t mtk1959 -d F: rawflash C:\Users\15030\Desktop\BU40N-FR\BU40N-FR07-JM02202-211801221536.bin
PS C:\program files (x86)\makemkv> ./makemkvcon64.exe f --all-yes -t mtk1959 -d F: Unable to load sdf.bin
PS C:\program files (x86)\makemkv> ./makemkvcon64.exe f -t mtk1959
Error: Drive not specified
PS C:\program files (x86)\makemkv> ./makemkvcon64.exe f -t mtk1959 -d F:
abmcconnell
Caokddjs, Did you ever resolve this? I appear to be having similar issues- same error ID. Have tried with flasher GUI on Win VM and on Mac terminal. No dice. Only difference is I am trying MK HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
