LibreDrive for Pioneer drives
hansolo
Post by hansolo »
Great job re: Pioneer LibreDrive support!
Are Asus branded drives (Pioneer clones listed in the first post) as good burners as "real" Pioneer drives. I'm planning to get one of these drives mainly due to amazing BD50 burning capabilities.
For example these, which I could easily purchase from local retailers.
Asus SBW-06D5H-U (external)
Asus SBC-06D2X-U (external)
How about much cheaper internal drive Asus BW-16D1HT/B. There is no letter "U" in model number, but it is BD-XL drive.
And how about Pioneer BDR-212EBK. Again, no letter "U" but it is BD-XL drive.
Edit: just noticed elsewhere in other topic that Asus BW-16D1HT has MT1959 chipset, not Pioneer RS8xxx. That makes it LGE clone or am I mistaken?
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
Post by mike admin »
SDF v85
Fixed some drives entering slow speed mode
Pioneer module in sdftool now has commands to view and change default speed mode. One less reason to download Pioneer drive utility :)
Post by SamuriHL »
Oh that's awesome. Very handy!
TeddyRaspin
Post by TeddyRaspin »
Just a curiosity if I can ask. Are UHD svq dumps made with S12UHT as good as the ones made with LG drives?
Post by SamuriHL »
They should be. There doesn't seem to be any difference in functionality that I've seen except the all region code not being implemented yet.
TeddyRaspin wrote:
Fri Feb 18, 2022 9:49 pm
Yes.
TeddyRaspin
Thanks as always Mike. :wink:
datensenke
Post by datensenke »
I'm very confused now and I just couldn't find out. How do I enable Libredrive on my Pioneer BDR-212M1.00?
I try to do it on Linux, so I did
sdftool -d /dev/sr0 --info
, which returned me:
SDF.bin version: 0x0085
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:Pioneer RS8F00
8003:Firmware version
:ID56
Then I tried:
sdftool -d /dev/sr0 help
, which returned me
Pioneer firmware module v1.20
Commands:
  dump [auto|full] dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump auto      - dumps full image if possible, info data otherwise
    speed get      - prints current speed mode setting
    speed set MODE - writes new default speed mode to EEPROM
Therefore, no way to enable Libredrive.
I looked through the forum for hours and I just couldn't find it out. Everyone just takes the information I'm looking for, for granted, even in the ahem "Guides".
And please don't tell me something like: "just get the right firmware". That's not an answer.
The full answer would be:
use the command:
sdftool -f sdf.bin -d /dev/sr0 -i firmware.bin flash
, where firmware.bin is the file from http://<well known address for everybody except datensenke>, or whatever.
(Yes, I'm very spoiled by Arch Linux Forums and Stackoverflow, indeed).
Your firmware is not supported. Ask Mike how to upload 1.00 or upgrade to 1.01.
datensenke wrote:
Sun Feb 20, 2022 6:16 pm
8013:Status
8001:Drive platform
:Pioneer RS8F00
:ID56
Then I tried:
, which returned me
Commands:
use the command:
The supported Pioneer firmware list is in the first post. No need to flash, it just works. If your drive is in the list but not the firmware version, either contact Mike to get your firmware extracted and added to the list or upgrade your firmware to an already compatible version via Pioneer flash tool.
datensenke
Oh, holy sh...
I read in the thread, that there was an M212.00, but it's not in the list anymore.
Sorry, for being so angry. Now I have to be angry with me.
datensenke wrote:
Mon Feb 21, 2022 2:35 pm
Oh, holy sh...
There is a 212M 1.01 in the list, so either contact Mike so he can extract and add your 1.00 firmware to the list or update your drive to 1.01 via Pioneer's flasher.
i5xswipe
Post by i5xswipe »
ryley wrote:
Mon Feb 14, 2022 12:44 am
As of SDF v083, my Pioneer BDR-XD05 (3.00) is now LibreDrive compatible. Unfortunately I'm not having much luck with it. If a standard Blu-ray disc is inserted when starting MakeMKV, a fatal error occurs (screenshot attached). Loading a disc after starting MakeMKV also fails but no fatal error message is shown. I've attached the debug log files for both scenarios. (The 'STATUS_DEVICE_NOT_CONNECTED' message was only logged after I unplugged the USB cable)
Edit: I've tested MakeMKV v1.16.5 with SDF v07e again. The same drive/disc combination worked correctly with this configuration, but I can't seem to attach the log file.
This! I am on V1.21, but have the same issue with a standard Blu-ray.
i5xswipe wrote:
Tue Feb 22, 2022 7:32 pm
You are getting a fatal error with SDF v86???? Did you try disabling LibreDrive for your drive? Please email/PM me, I'll ask for a log file for troubleshooting. Thanks!
mike admin wrote:
Wed Feb 23, 2022 12:44 pm
Mike, how can we "disable" Libredrive?
