I had a look into the users-guide for the x800m2, and on page 36 of the English language version it says;
• The player can support video bit rate up to 40 Mbps
4th bullet point from the bottom of the right hand side column.
Is that a limitation to be worried about? Isn't it normal for a modern 4k+HDR title to have a video bit rate higher than that?
Replaced my switch and cabling today, and the 800M2 seems to fare better so far.
Sometimes I have truehd movies start without audio, but when I FF/RWD a bit, it works.
deadchip12
Hmm why #4 and #5? Cna't the X800M2 play the full-disc backup directly?FubbAyH wrote: Tue Feb 15, 2022 3:23 am #1 Buy a Sony UBP-X800M2
#2 Make a full-disc decrypted backup using MakeMKV
#3 Find the playlist for the version of the movie you want (it's probably 00800.mpls for the English version)
#4 Drop that into tsMuxer
#5 Set it to output M2TS, and select the audio and subtitle tracks you want
#6 Watch the movie
#7 Be free
#8 Live your life
#9 Never think about Dolby Vision ever again
I just checked and Amazon can ship to my country but the import fee is pretty high, adding 40%-50% markup on top of the original price. Same if I ask some 3rd party local company to ship it for me instead. Manufacturer's warranty is another problem. It won't apply abroad I suppose. I'm not sure if all these are worth the improvement over the x700 which I can purchase locally. I live in Vietnam btw.FubbAyH wrote: Tue Feb 15, 2022 3:23 amIs it particularly difficult to import things in your country? There do seem to be lots of places that sell the X800M2 and will ship internationally (but I know there are sometimes a few countries that they can't ship to).deadchip12 wrote: Tue Feb 15, 2022 2:20 am So my hope of getting a x800m2 is gone. There's really no place in my country that sells it.
Ah dang, yeah those import fees suck
Hey everybody first post here
... Wanted to know if the x700 does TV-led DV when playing back .m2ts backups via usb created using latest tsmuxer nightly (using full UHD BD backups), and also why creating a bdmv folder is now recommended for the x700? I never had an issue ff or rw with .m2ts files that i noticed at least, and the green screen bug I just worked around by restarting as I'm not switching between content that often. Sorry if this has been answered already finding a bit hard to read through all the posts.
I've been having more adventures with re-ripping for my X800M2. To cut a very long story short, it turns out that the current nightly builds of tsMuxer are producing corrupted output so I thought I should post a warning about that here. Apparently the last working version is the 23 January nightly, and there's a GitHub issue for the corruption bug.
The good news for me is that that's hopefully the source of all my woes. I've just gotta remux for the four-millionth time now to find out, so please wish me luck.
My Dune 2021 test was with the latest tsmuxer and didn't get the error you're getting but it could explain the issue I'm having when I remux from dual track MKV.FubbAyH wrote: Thu Feb 17, 2022 2:57 pm The good news for me is that that's hopefully the source of all my woes
My BTTF files were made a long time ago with an older tsmuxer.
but thanks for the info, I'll downgrade to the older version.
EDIT:, nop, dual track mkv to ts still doesn't work.
@RESET_9999
I used your tool to create measurements of Smurfs.The.Lost.Village.2017 in many times but received result always is a Smurfs.The.Lost.Village.2017.mkv.measurements.incomplete 71.4MB
So should I use it?
So should I use it?
Great... I just redid a shitload of bdmv folders to .ts with the bugged tsmuxer :/ Any chance of fixing these corrupt .ts files, or do i have to start ALL over? :/FubbAyH wrote: Thu Feb 17, 2022 2:57 pm I've been having more adventures with re-ripping for my X800M2. To cut a very long story short, it turns out that the current nightly builds of tsMuxer are producing corrupted output so I thought I should post a warning about that here. Apparently the last working version is the 23 January nightly, and there's a GitHub issue for the corruption bug.
I don't know enough about the bug to know whether the files would be fixable, but it might be worth checking your M2TS files with:
to see if they're okay. It might be that only DV streams are affected, or something like that.
ffmpeg -i testfile.m2ts -f null -Re: Dolby Vision now possible through MP4 Mux.
staknhalo wrote: Sat Oct 23, 2021 6:24 pmI wrote up how this idiot does it here:mattmarsden wrote: Sat Oct 23, 2021 5:46 pmThanks for that. Is there an idiots guide on HDR10+ to DV conversion?quietvoid wrote: Fri Oct 22, 2021 4:16 pm
You need to demux the video first, and then run the script on the HEVC file.
example: python hdr10plus_remove.py -i video.hevc -o processed_file.hevc
https://www.avsforum.com/threads/author ... t-60952335
Turn HDR10+ metadata into Dolby Vision metadata**
Command 1: 'hdr10plus_tool extract Video.hevc -o Metadata.json' (Extracts HDR10+ metadata and saves to .json file)
>>Next commands go through Dovi_Tool and v0.5.0 minimum required<<<
Command 2: 'dovi_tool generate -j Extra.json --hdr10plus-json Metadata.json --rpu-out RPUPlus.bin' (combines metadata from edited 'Extra.json' - template is below and you need to do one for every title specifically - and metadata from extracted 'Metadata.json' and combines+converts them into p8 RPU metadata format)
Command 3: 'dovi_tool.exe inject-rpu --input Video.hevc --rpu-in RPUPlus.bin' (Injects HDR10+ generated RPU metadata into HEVC stream turning it into single layer Dolby Vision 8 stream)
Blank Template for 'Extra.json'
"length": (title specific framelength here without parenthesis),
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
"level6": {
"max_display_mastering_luminance": (title specific metadata info here without parenthesis),
"min_display_mastering_luminance": (title specific metadata info here without parenthesis),
"max_content_light_level": (title specific metadata info here without parenthesis),
"max_frame_average_light_level": (title specific metadata info here without parenthesis)
Another question: I have a few HDR10+ files i want to "convert" to DV, but the
Maximum Content Light Level & Maximum Frame-Average Light Level lines are missing in mediainfo. Is there some default value to use and hope for the best, or are there some way to find the correct values?
I don't know , is that a seamless branching disc? I think so...Albano wrote: Fri Feb 18, 2022 12:32 pm @RESET_9999
So should I use it?
How did you rip your disc? do not use mkvtoolnix or makemkv when the disc has multiples m2ts. always use tsmuxer.
Yea, 2nd time in 2 months they mess up Dolby Vision. I'll just stop updating tsmuxer unless there's a major update...Epedemic wrote: Fri Feb 18, 2022 12:37 pm Great... I just redid a shitload of bdmv folders to .ts with the bugged tsmuxer :/ Any chance of fixing these corrupt .ts files, or do i have to start ALL over? :/
It's not missing, it's just set to 0Epedemic wrote: Fri Feb 18, 2022 1:02 pm Another question: I have a few HDR10+ files i want to "convert" to DV, but the
Thank you once again. You are awesome
I just tried the same with James Bond: No Time To Die. It's a FEL movie, and it has the same quirk;ArArdin wrote: Sun Feb 13, 2022 8:57 pmThat's weird indeed. Maybe waste of space in MEL that tsMuxer would solve when muxing? I recently had a title with 1.6 GB MEL, of which RPU was 36MB. You can of course investigate by demuxing BL and EL from both mkvs and compare sizes.sickb wrote: Sun Feb 13, 2022 8:06 pm Does anyone have an idea why I get different results...
in the first case I have a 49.3mb/s 42.7gb video track
in the seco case I have a 48.0mb/s 41.6gb video track
Even better of course is what RESET_9999 suggested and convert to Profile 8.1 "BL+RPU". You'll have no EL at all.
- Direct to MKV: 56.6MBPS, 64.7GB, 58,1 GB BL, 6,53 GB EL
- TS-BDMV-MKV: 52.6MBPS, 60.1GB, 58,1 GB BL, 1,93 GB EL
So it removes about 4.6GB of EL somehow..
