mlala
Post
by mlala » Sat Mar 05, 2011 11:17 am
Hallo here is a question from a newbee,
I'll get this failure directly after starting makemkv 1.6.5
MakeMKV v1.6.5 darwin(x86-release) started
Optical drive "BD-RE PLEXTOR BD-R PX-LB950UE 1.01" opened in DASPI mode.
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'BD-RE PLEXTOR BD-R PX-LB950UE 1.01' at offset '524288'
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'BD-RE PLEXTOR BD-R PX-LB950UE 1.01' at offset '1048576'
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'BD-RE PLEXTOR BD-R PX-LB950UE 1.01' at offset '32768'
This is an external Bluray Drive, but I get the same problem with a DVD and the internal Drive (Macbook pro - latest OS).
By using 1.6.2 it was ok with the internal drive.
Uninstalling and new installation - same problem!
Please help
Post
by mike admin » Sun Mar 06, 2011 11:20 am
Please enable "log debug messages" in preferences and see if any errors show up. Also please make sure that you're running the latest DASPI version, v1.2
mlala
Post
by mlala » Sun Mar 06, 2011 11:57 am
The latest Version DASPI 1.2 is running.
And here is the log (internal drive and dvd)
Debug logging enabled, log will be saved as /Users/markusglagla/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC09" opened in DASPI mode.
DEBUG: Code 4294967295 at K|cLd{ope%9ew1RFdJ:29395885
DEBUG: Code 4294967295 at K|cLd{ope%9ew1RFdJ:121262049
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-898 HC09' at offset '524288'
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-898 HC09' at offset '1048576'
DEBUG: Code 4294967295 at K|cLd{ope%9ew1RFdJ:213132560
Error 'OS error - ERROR_FFFFFFFF' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-898 HC09' at offset '32768'
DEBUG: Code 0 at ?hyY!pY\qW%1 nGi$k?:29393447
