Mad Max The Road Warror 4K UHD
mldardy
Post by mldardy » Tue Feb 08, 2022 6:02 pm
I submitted the tgz file for The Road Warrior on Saturday for 'The volume key is unknown for this disc - video can't be decrypted'. Does anyone know how long it normally takes to fix?
Re: Mad Max The Road Warror 4K UHD
Post by d00zah » Tue Feb 08, 2022 6:43 pm
I submitted the tgz file for The Road Warrior on Saturday. Does anyone know how long it normally takes to fix?
UHD FAQ
mldardy
Post by mldardy » Thu Feb 17, 2022 8:57 pm
Thanks for fixing this :D
DeadPixel
Post by DeadPixel » Mon May 16, 2022 5:47 pm
I read this disc was originally faulty and wondered if anyone knows what to look out for to know I get the correct replacement disc?
Post by d00zah » Mon May 16, 2022 7:22 pm
As is often the case, you didn't provide much to go on (like what, specifically, you read & where you read it),,. but google came to the rescue.
blu-raydotcom details particulars of both the "corrected" (Feb 01, 2022 release)/"wrong audio" (Nov 16, 2021 release) versions, along w/ purchase links. Should you desire to purchase elsewhere, there ought to be enough specific info to identify the correct version?
Hope this helps.
jayper
Post by jayper » Tue May 17, 2022 12:08 am
The UPC for the correct disc is: 883929789993
DeadPixel
Post by DeadPixel » Tue May 17, 2022 6:47 am
Thanks, that will help :D
