LibreDrive for Pioneer drives
TeddyRaspin
#91 Post by TeddyRaspin » Thu Feb 17, 2022 2:18 pm
Here me back. Drive BDR-S12UHT properly mounted and with native 1.01 firmware.
The strange thing is that after a reboot Windows doesn't see drive anymore. I've to turn my PC off
and restart again (I'm investigating this issue).
Furthermore I can't rip at any speed higher than 4x and MakeMKV doesn't add any Pioneer entry
inside regedit (instead of LG drives).
I've also tried to use the "Performance Mode" from Pioneer Utility but it doesn't seem to do anything.
Any help would be really appreciated.
#92 Post by mike admin » Thu Feb 17, 2022 2:20 pm
Chris Kelly wrote: Thu Feb 17, 2022 1:58 pmThis is awesome news, and it looks like it's only six days old! Isn't the latest version of MakeMKV from 2021?
This is one of the design goals of LibreDrive - separate (frequently changing) drive logic from a (rarely changing) library runtime. And the target goal - a fully open-source library runtime that doesn't change in ages...
#93 Post by Billycar11 » Thu Feb 17, 2022 2:24 pm
TeddyRaspin wrote: Thu Feb 17, 2022 2:18 pm Here me back. Drive BDR-S12UHT properly mounted and with native 1.01 firmware.
Not to burst your bubble but 4x is the max speed on UHD for pioneer drives even in performance mode
#94 Post by mike admin » Thu Feb 17, 2022 2:27 pm
TeddyRaspin wrote: Thu Feb 17, 2022 2:18 pm The strange thing is that after a reboot Windows doesn't see drive anymore. I've to turn my PC off
There are several reports that LibreDrive mode manifests insufficient USB power issue - drive disconnects after LibreDrive handshake but works fine with LibreDrive disabled. Almost in all cases it was confirmed (with Pioneer utility) that insufficient USB power was the case, but still it happened only with LibreDrive.
The latest SDF v84 has changes for this, it forces low-power mode and adds some timeouts for capacitors to charge back, please try it and post if this changes anything.
TeddyRaspin
#95 Post by TeddyRaspin » Thu Feb 17, 2022 3:30 pm
Thanks as always my dear friend,
I already have sdf v84 inside my APPDATA dir (inside _private_data.tar file). I've rolled back to a previous bios version on my motherboard
as I was using latest beta (with new AGESA which could have some issues) and bdr-s12uht is working fine now and it is connected via sata
cable inside PC. I'm not using any USB enclosure.
Regarding UHD ripping speed, this drive reads any UHD disc I have instantly, light years better than any LG drive I ever had, but I've seen
on Pioneer specs site 4x is the maximum read speed for UHD 4K TL discs.
#96 Post by mike admin » Thu Feb 17, 2022 3:57 pm
TeddyRaspin wrote: Thu Feb 17, 2022 2:18 pm MakeMKV doesn't add any Pioneer entry inside regedit (instead of LG drives).
You can add it manually - lower-case "speed" + underscore + drive id from sdftool or MakeMKV log file.
#97 Post by Coopervid » Thu Feb 17, 2022 5:07 pm
mike admin wrote: Thu Feb 17, 2022 2:20 pm
A Libredrive runtime sounds great! Any idea Mike regarding timing since all the Pioneer firmwares should be soon supported - so I hope?
TeddyRaspin
#98 Post by TeddyRaspin » Thu Feb 17, 2022 6:17 pm
mike admin wrote: Thu Feb 17, 2022 3:57 pm You can add it manually - lower-case "speed" + underscore + drive id from sdftool or MakeMKV log file.
Already done but, of course, I can't rip higher than 4x speed. :wink:
Anyway, it's a great thing the Pioneer libredrive support. Thanks for your hard work. :D
#99 Post by SamuriHL » Thu Feb 17, 2022 8:31 pm
TeddyRaspin wrote: Thu Feb 17, 2022 6:17 pm Already done but, of course, I can't rip higher than 4x speed. :wink:
You're looking at it all wrong. :) The Pio takes its time reading troublesome discs with extreme accuracy, that's all. :D
#100 Post by Coopervid » Thu Feb 17, 2022 8:57 pm
SamuriHL wrote: Thu Feb 17, 2022 8:31 pm
And you have a fantastic burner for 50GB discs. The LGs all have issues at the layer break. 50GB discs burnt with LGs are all troublesome and video will must likely stutter at the layer break. Even worse if you want to store important data files that can't be read back.
But watch out: You should also burn these at the lowest speed (2x) with your Pioneer drive.
TeddyRaspin
#101 Post by TeddyRaspin » Thu Feb 17, 2022 9:42 pm
When I'll find also a BDR-212UBK at the same price of S12-UHT (which I think they are the same device),
I'll be very happy to change the other LG drive too.
In the meantime, I'm enjoying the precious gift mike give us with Libredrive support also for Pioneer UHD drives. :wink:
#102 Post by Coopervid » Thu Feb 17, 2022 10:01 pm
TeddyRaspin wrote: Thu Feb 17, 2022 9:42 pm When I'll find also a BDR-212UBK at the same price of S12-UHT (which I think they are the same device),
I searched. No chance....
#103 Post by SamuriHL » Thu Feb 17, 2022 10:30 pm
I just grabbed one here in the states but it was not cheap by any means.
#104 Post by Coopervid » Thu Feb 17, 2022 11:16 pm
SamuriHL wrote: Thu Feb 17, 2022 10:30 pm
Yeah the S12 seam to be more affordable than the 212 UHD types.
TeddyRaspin
#105 Post by TeddyRaspin » Fri Feb 18, 2022 7:05 am
Coopervid wrote: Thu Feb 17, 2022 11:16 pm Yeah the S12 seam to be more affordable than the 212 UHD types.
And I can't understand why as 212UBK reads 4K discs at the same speed of S12UHT
as well as it shares same specs.
