UHD ripped audio distortion
hardcore_gamer29
#1 Post by hardcore_gamer29 » Thu Feb 17, 2022 10:38 am
when i rip any bluray or 4k uhd first option of 5.1 in audio settings is always having distortion then i select 2nd 5.1 option it works fine. why so?
https://i.imgur.com/ZIdhDUW.jpg
Re: UHD ripped audio distortion
#2 Post by Billycar11 » Thu Feb 17, 2022 10:54 am
because your player or surround sound does not decode it right
hardcore_gamer29
#3 Post by hardcore_gamer29 » Thu Feb 17, 2022 12:59 pm
Billycar11 wrote: Thu Feb 17, 2022 10:54 am because your player or surround sound does not decode it right
i have pc windows 10 wih cyberlink powerdvd 21 ultra. what should i do and why 2nd option works fine then?
#4 Post by Billycar11 » Thu Feb 17, 2022 1:09 pm
hardcore_gamer29 wrote: Thu Feb 17, 2022 12:59 pm
Turn off the audio enhancement in cyberlink and set it to fully passthrough to your suround sound system that hopefully supports Atmos/true hd and dtsx/ dts ma.
hardcore_gamer29
#5 Post by hardcore_gamer29 » Sun Feb 20, 2022 5:58 pm
Billycar11 wrote: Thu Feb 17, 2022 1:09 pm
disabled all enhancement today in cyberlink still has distortion
#6 Post by Billycar11 » Mon Feb 21, 2022 12:12 am
hardcore_gamer29 wrote: Sun Feb 20, 2022 5:58 pm
It's something with your setup man I have no issues with sound sound formats it's not a makemkv issue what receiver do you have
hardcore_gamer29
#7 Post by hardcore_gamer29 » Mon Mar 07, 2022 4:09 pm
Billycar11 wrote: Mon Feb 21, 2022 12:12 am
can you help me with this as i today directly played through wh16ns60 there was no distortion in sound, it is only after ripping
#8 Post by dcoke22 » Mon Mar 07, 2022 6:31 pm
If you use MediaInfo to look at your rips you'll probably see that one of the 5.1 sound tracks is one of the lossless formats Dolby TrueHD or DTS-MA or similar. Those audio tracks require a proper setup to correctly decode. The other sound track is probably the accompanying 'lossy core', which is a much more common Dolby Digital AC-3 or DTS. Those 'lossy core' tracks have been well supported in hardware and software for a long time.
As Billycar11 suggested, there's probably something in your playback setup that can't handle whatever lossless format is in use. MakeMKV makes a correct 1:1 copy of whatever is on the disc, so it is unlikely to be the cause of distortion.
hardcore_gamer29
#9 Post by hardcore_gamer29 » Sun Mar 13, 2022 10:57 am
dcoke22 wrote: Mon Mar 07, 2022 6:31 pm If you use MediaInfo to look at your rips you'll probably see that one of the 5.1 sound tracks is one of the lossless formats Dolby TrueHD or DTS-MA or similar. Those audio tracks require a proper setup to correctly decode. The other sound track is probably the accompanying 'lossy core', which is a much more common Dolby Digital AC-3 or DTS. Those 'lossy core' tracks have been well supported in hardware and software for a long time.
there is a simple confusion that playing directly with disk , why there is no distortion?
