Asus BW-16D1HT stoped reading disks suddenly
Re: Asus BW-16D1HT stoped reading disks suddenly
Post by Coopervid » Wed Feb 16, 2022 8:50 pm
brianmw36 wrote:
Wed Feb 16, 2022 5:43 pm
I am having the same issue sort of, my drive is not reading any Discs, DVD or Blue Ray. I have taken apart and cleaned still no joy. Changed cable, tried it on another Mac... no matter what I try Make MKV sees the drive, shows all the info about the drive... but im always getting a no disc inserted. Also when not running MakeMKV no Disc is ever loaded or shows up in any DVD/BR players.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: M6LIBNC5541
Bus encryption flags: 1F
Highest AACS version: 32
Firmware version: 3.10
wondering if it just died, purchased May 2019
Most likely it's dead. Try a CD, try re-flashing. If it doesn't work it's a door stop. My first NH16NS55 which is the identical hardware also died after 2 years.
brianmw36
Post by brianmw36 » Wed Feb 16, 2022 10:49 pm
huh, wont even read a cd...
waldo22
Post by waldo22 » Fri Sep 15, 2023 7:54 pm
Billycar11 wrote:
Fri Jan 29, 2021 3:13 pm
full shutdown the pc flip psu switch hold power button for 10 seconds see if it works then
Just a "me too" on this. I tried restarting the PC several times and it didn't work, but unplugging the SATA power from the BW-16D1HT and plugging it back in forced it to hard reset and it started working immediately.
tvguy7
Post by tvguy7 » Fri Oct 24, 2025 11:35 pm
Hi All,
I’m having this same issue where no disc is found. I’ve tried pulling the PC power and haven’t been able to resolve the issue. The discs are turning. Any troubleshooting help would be appreciated.
Post by Billycar11 » Sat Oct 25, 2025 12:31 am
Hi All,
clean the lasers if that dont work its dead
