unable to decrpyt discs
hescominsoon
Post by hescominsoon »
MakeMKV v1.16.5 win(x64-release) started
Opening files on harddrive at R:/Under Siege 2
Evaluation version, 29 day(s) out of 30 remaining
Saved AACS dump file as C:\Users\william/.MakeMKV/MKB_v3_unkn0wn_3A46.tgz
Opening files on harddrive at R:/hard to kill
Saved AACS dump file as C:\Users\william/.MakeMKV/MKB_v28_Hard_To_Kill_AD8A.tgz
Re: unable to decrpyt discs
"Opening files on hard drive" means that MakeMKV does not have access to the information on the original optical disk to create the decryption keys. When you are doing that, you have to provide the key data separately.
If you have the original disks, you can have MakeMKV extract the decryption information from them.
